Camaro 1LE?
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Camaro 1LE?
What is it? I know that they're pretty rare and desirable but what makes a 1LE camaro any better than a regular z28 or something?
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Camaro 1LE?
The thing that makes them "Special" is a liturgy of special parts. IE larger brakes... for better stopping, They handle different, I know I know, they have mostly the same suspension, but I take it from people that have owned both regular Camaros and 1LE's They swear that you can tell the difference, they just drive different. also a special Gas Tank, and all of the other performance goodies... It can't be all that special? Can it?... {insert sarcasm here}
John
John
Re: Camaro 1LE?
Not that rare? According to Camarosource.ca, there were 412,845 Camaros built in the 1988-92 model years. Of those only 1332 were 1LE's - 4 in '88, 111 in '89, 34 in '90, 478 in '91 and 705 in '92. If my math is correct, that comes up to a little over 3/10th's of ONE percent of Camaro production in third gens. If any of these numbers are wrong, someone please correct me.
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: Camaro 1LE?
Canadian Players Challenge Series
Also more stuff here . . . https://www.thirdgen.org/forums/hist...e-players.html
Also using a "search" will find lots more info.
Engine: LB9
Re: Camaro 1LE?
Car: 1992 Camaro Z28 1LE
Transmission: 5-speed
Axle/Gears: G92 Perf. Axle
Re: Camaro 1LE?
To some enthusiasts, handling, braking, and transient response are more important than 1/4-mile times. The third-gen 1LE is one of those rare automotive packages that somehow ended up being more than the sum of its parts.
To the "magazine racer," the 1LE's test-track numbers -- even skidpad G's -- are not really any different from a regular, performance-optioned Camaro or Firebird. The beauty of the package is not what kind of magazine-test numbers it produces, but how well-sorted the components are for road racing, how consistently usable that performance is, and how well the 1LE-specific suspension and brake bits hold up to the abuse.
Try hot-lapping Nelson Ledges repeatedly with a stock "regular old IROC" and see how well the brakes hold up to the heat. The stock brakes (even the regular J65 4-wheel discs) were notorious for poor heat dissipation and under-sized rotors, resulting in substantial brake fade and eventually a soft pedal. Unacceptable for road racing! In a 1LE, the hotter you get the brakes, the better they feel!
The better weight distribution of the "true" (A/C-delete) 1LEs also makes for better handling. Most people would not notice any difference in 7/10ths driving, which is really all you can do on public roads. On a track day you can feel the difference. There is less understeer, and the car feels lighter on its feet.
84z96L31vortec
08-20-2017 12:16 AM
