1987 Yellow Iroc with TPI, t-tops, manual, and G80/G92 mini-restoration
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
I know there are tons of threads on here on this and that combo, but I've only seen 1 other combo like this?
Any other TPI yellow sticks out there?
Hopefully this will be my forever cruiser after missing ny yellow 85 I sold
It has 69k miles, im the 3rd owner, and a perfect carfax.
It needs lots of little things, but runs OK and we are loving it already!
Car: 92 RS Heritage Edition
Engine: LG4 305
Axle/Gears: 3.73 10 bolt posi
Re: 1987 Yellow Iroc with TPI, t-tops, manual, and G80/G92
Nice! I have always liked yellow IROCs.I’ve never seen that combo.Congrats on your purchase👍
Car: 89 Firebird
Engine: 355 TBI
Very cool car and I bet it's a blast to drive
Car: 93 Trans Am
Transmission: T56 Street Twin
Axle/Gears: 12 Bolt 3.90
Great find, they all need little things after all these years. Thats the fun part.
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Thanks guys! yes, I have already started fixing the little things
-refurbed the steering wheel
-ashtray lid
-better shift ****
-hood struts
-trunk struts
-electric pull down repaired.
I'll post some pictures of the repairs as I do them, so I can have a running restoration thread. It will be a slow process though!
-ashtray lid
-better shift ****
-hood struts
-trunk struts
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Painted steering wheel and redyed the leather
Dyed and cleaned console after repairing lid
Reapinted t top edges and new weatherstripping/trim
Fixed electric rear hatch!
The main things so far....
Updating with pictures so I can lool back on them!
chazman (06-14-2022)
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Removed the Old T-top bar to clean around it and install a new Hawks T-top bar after figuring out mine is too far gone!
New Hawks T-top bar
Luckily underneath the bar was in GREAT shape. We are only planning on painting the nose and hood, keeping the rest of the paint as-is
Along with new T-top bar, we added new weather stripping, an ABS headliner, and my Fiance recovered the rear speaker grills. It made a HUGE difference in the interior. The gas station lights always hit differently, LOL. I had not cleaned the interior after working in and around it for weeks.
Finished. Just need a dash pad and a console lid and I'll be happy with the inside... (and Bluetooth the factory radio)
Refinished steering wheel looks GREAT
Refinished the shifter boot, fixed the ashtray lid, and installed new window switches. I also want to get a stock shift ball.
She loves to help......... SOMETIMES. Here she is cleaning all of the old weatherstripping and installing the new!
Also, I redid the rear brakes and started adjusting the E-brake as well!
New Hawks T-top bar
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Last weekend we were able to get it to the Charlotte Autofair. Even though the rain showed us every place we need to fix on the weatherstripping, we had a great time.
The following 2 users liked this post by NufNuffZ28:
dmccain (09-13-2022), DynoDave43 (09-16-2022)
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Great pics. Cars look great.
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Re: 1987 Yellow Iroc with TPI, t-tops, manual, and G80/G92 mini-restoration
Spent some time tackling the intermittent misfire and overall poor performance!
-Changed plugs, wires, cap, rotor, oil, fuel filter and after pulling the old stuff off 2 plugs were barely firing and 2-3 wires burnt! After replacing that the misfire was gone, but still had bad idle characteristics and would sometimes "misfire" at idle still. The distributor was making a noise, so we pulled it and the teeth were VERY worn out and obviously OEM. Replaced that and it was nearly perfect. the whole trip to Myrtle Beach was great, but it still had a small miss from 2-2500 ONLY after the car warms, so we put a new coil on it and so far so good! This car is quick now. Surprisingly quick!
-found a burnt vacuum line causing the HVAC to not move position from the defroster, so fixed that.
-fixed the floppy center vents
-Converted and charged the AC, it WORKED, but leaked out from the high pressure switch on the compressor. I have a new one to put on now
-The hanging idle was simply some buildup in the TB near the blades. I literally can not believe that was it!
-Got some new Lloyds mats for it (black, no logo)
-Resealed the weatherstripping on the T-tops, getting much better rain protection
-Traded for a flow master muffler and had it and some stock style tips welded up on it. Love how quiet it is now(still has a little rumble)
-Previous owner had keep tthe smog pump on (which I am OK with), but has an aftermarket cat on it that doesn't have the pipe on it, so the smog pump was just throwing exhaust fumes in the engine compartment. Sounded like a horrible exhaust leak all the time! Removed all of that and plugged the Smog pipes coming off of the manifolds. At some points I may remove the manifolds completely and plug all of the air tubes there, but that's a lot of work. For now, it is good!
Here are a couple pictures...
A little sunrise picture at the beach!
The following 3 users liked this post by NufNuffZ28:
Transmission: auto
Very nice
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Thanks guys. Its a project, but coming along nicely!
Car: 1987 Iroc
Axle/Gears: 3.50 9"
here’s mine with spid tag. I’m sure not too many out there
dagwood (11-27-2022)
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Nice...Only major difference I see is mine has GM t-tops and yours are the CC ones. Looks like you are gonna get her right as well!
Congrats
Congrats
DavidSYellow87 (12-06-2022)
Car: 1987 Iroc
Axle/Gears: 3.50 9"
That was his RPO codes posted in here. I haven't shared mine yet.
Sent my radio off for cassette repair and adding bluetooth, will update with more pictures and a video then!
DavidSYellow87 (11-21-2022)
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Axle/Gears: 3.90 Currie 9 inch
I can tell by the pics that your t-tops are also factory code CC1 t-tops. His SPID has CC1, and yours will too. CC1 is the rpo code for factory t-tops. Not to be confused in any way with C&C t-tops, which there is no RPO code for since they're aftermarket.
Car: 1988 Trans Am GTA
Engine: 5.7 L98
I just found this thread and I really like your mini-resto, I love the yellow IROCs with black interior and the car is nicely optioned. Keep up the good work!
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Ahhhhhhhhhhhhhh, OK. I got it now.
Thank you!
Thank you!
Car: 1987 Iroc
Axle/Gears: 3.50 9"
I was able to get the broken AC compressor switch out, so hopefully my AC will stay charged now!
Also, I spent a couple hours putting in the aftermarket fog lights.
Man, the fit like CRAP! The brackets are not the right shape, the adjusters for the angle of light pattern work for the 1st 1/4 then they just strip (meaning they don't adjust p or down). I ended up having to get nut that fir the adjuster screw and then tighten to my desired angle. Also, the brackets would angle them at the ground if you don't bend them to the proper angle first. Lastly, the bulb hole does not offer a secure feel at all.
They look proper once installed, but were not fun to install at all.
I also just dropped it off to have the nose, hood, and front fenders painted/blended in and got some matching Iroc stripe tape from Hawks. Hopefully it matches well!
Here is a history question for you! The car has the gold wheels/stripes/decals, but has the black interior. This mismatch was only possible on yellow Irocs, correct? With that being said, what color would the emblem on the rear (TPI) and front grill be?
dmccain (05-31-2023)
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Had to take the qhole hood down as it had 1 dent and someone previously repaired it incorrectly!
Car: 1987 Iroc
Axle/Gears: 3.50 9"
My buddy is making some great process getting the front back in shape!
chazman (06-02-2023)
Transmission: auto
Great progress.
NufNuffZ28 (06-05-2023)
Car: 1987 Iroc
Axle/Gears: 3.50 9"
THANK YOU!
Got it back and really happy. Had some damage under the bra from a previous repair. Also got the bottom of the hood dusted in so when I add a hood liner it will be finished looking!
My fiancé painted the camaro gold as I felt that matched the striping, emblems, and wheels.
chazman (06-04-2023)
Transmission: World Class T-5
Axle/Gears: BW 3.45
Looks great!!!
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Thank you! Trying to knock out a lot of the little things for the Summer!
Debating on sanding the clear and reclearing the factory Irocs or getting some Hawks 17s with new tires and just putting these off to the side.
I also fixed the leaking AC Compressor high side sensor, so HOPEFULLY it will hold a charge now.
chazman (06-06-2023)
Car: 1987 Iroc
Axle/Gears: 3.50 9"
New hoodlimer and push pins
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Put a new high pressure switch in the compressor and charged the AC Before heading out to a local cruise in. Hopefully it hangs in there this time! It held a vacuum for 20 minutes, so I have failth. Lol
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Well. The AC was short lived. Its still leaking from the pressure switch on tbe compressor after a day. I replaced the switch and O ring when I replaced it. I didn't score the sides or anything when removing the old one, so not sire why the new one is leaking. I have to replace my belts anyway, so I'll look into it more this week.
Any ideas?
Any ideas?
Car: 1987 Iroc
Axle/Gears: 3.50 9"
I just keep doing small things to this car.
Detailed the engine(pictures coming soon) and added some new centercaps and new lug nuts with black caps for a pretty close OEM look
Got parking lights coming and may get some new door tops (inside) to replace my cracked ones. Then console and gotta figure out what Im going to do with the dashpad corner...
#42
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Not that anyone checks in here much, but found some GM parking lights at a great price so threw those in!
#43
Transmission: auto
I like it.
#44
Car: 1987 Iroc
Axle/Gears: 3.50 9"
#45
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Got it lined up and the steering wheel is FINALLY straight. Yah! AC compressor still leaking from the switch, so have another one coming...
#46
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Either we are very lucky or smart!
Horn hasn't worked as the white plastic tube in the steering wheel was brokem. We used a file to cut a new slit in it, butvit didn't work too well.
My fiance found on of the plastic inserts that go on metal rods to lock them into things and we put a slitvin it to get it over the wire. We worked it in(not using the black tube with the two lugs on it at all) . It stays in GREAT and keeps enough tension on the spring for the horn to work. Its straight with a working horn now!
#47
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Replaced the ac pressure switch again... this one had some good pressure going in hopefully resulting in a tighter fit and had a little ac oil on it, so I'm hopeful this time.
Also pulled off the TPI snorkel and cleaned/painted it satin black. I normally wouldn't do this, but it had some rub marks that were showing grey underneath. Bumper satin black looks great!
NufNuffZ28 (07-14-2023)
#50
Car: 1987 Iroc
Axle/Gears: 3.50 9"
Thanks guys. Little by little getting it dialed in. Thankfully its a fun car to drive, so we get to enjoy it through the whole process
