Engine suffix code 7AB
I'm trying to identifiy the engine that I swapped into my trans am.
Casting number is 14093638 which is 86-94 350
Casting date is G027, so july 2, 1987
the stamped block id is V07067AB, flint engine 07/06, suffix code 7AB, but I can't find that code on any of the online lists. Anyone know what it is? This number is very clear, its definaty 7AB
Under the block id where the vin should be is "T10 3038" there is definately a space there between them, although the last digit might not be an 8.
Any ideas?
Any ideas?
