You're gonna pay more for yellow my fine fellow!
Engine: 4++,350 & 305 CIs
Re: You're gonna pay more for yellow my fine fellow!
Wish the headliners would last longer.
Transmission: 5-Speed Manual
Is That TPI Emblem In The Correct Location.
That's rough. His yellow at nearly no miles doesn't look as good as yours.
It's something, not sure how much is the yella vs mileage and option combo. T-top, 350, blk interior. Reserve not met kinda seems like someone knows the reserve and stopped just short of it.
This is a beautiful car,I have always liked the yellow Iroc's.
Two hours left and $35,600.
I wish I could buy it,it is only an hour up the road from me.
awesome car and im sure its worth over 30k but you see this all the time on ebay when the reserve hasnt been met .. i can put a 100,000 mile iroc on ebay and put the reserve at 30k and have my friends bid it to 29k and some people will think that the car actually got bidded on to 29k ..
Location: *member since 1999, I think - just can't remember my old name, and the big site crash...*
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
TPI emblem should line up with the furthest left perpendicular line of the tail lights..
Don’t know why folks can’t get it right... it’s like when they “accidentally” order the 5.7 badge and put it on, because why not?
It was the 80s, not many cars were built to perfecting specs then.
most of mine and the ones ive seen are a little more to the right .. the end of the n should line up with the last line of the tailight to the right ..
Axle/Gears: G80 GU2
Here’s a Black IROC with 9k miles and original paint and a Red one with 29k and original paint.. the photo above was my car with original paint and that emblem was the original faded and cracked..
As someone mentioned above, they could vary a little bit 1/4” or so because I don’t think it was an exact science back then..
It didn't sell, the owner relisted the car on eBay saying the reserve was almost met, the price was already really high so im wondering if the seller had friends bidding the car up now.
Axle/Gears: G80 GU2
Here is the placement on that super low mile 1LE that went for big bucks a while back.. It’s probably a half inch off on one side from the edge of the contour.. mine was like that too
Axle/Gears: G80 GU2
That looks like it would line up perfect with the badge on the other side.. maybe that one was put on by someone with OCD from When it was built..
They vary, but if it’s obviously too far either way it really stands out IMO..
Axle/Gears: G80 GU2
Yeah that doesn’t look off to me.. it looks like it would be lined up like the badge on the other side.. most of the 88-90 that I found are lined up a half inch to the left..
The ones that look really bad to me are the ones that are all the way to the left..
I think the whole “Tuned” should be under that brake light section.. if you get your car painted or remove a badge to freshen it up definitely take pictures and measure if you want it exactly where your car had it.. I gave my painter pictures and measurements of everything
I wonder if that is what they did - the gap between tuned & port would line up with the line in the lights and the 5.7 would shift left as necessary.
That way the N in injection would always end at the gap between reverse & black.
Axle/Gears: G80 GU2
It could be that the 88-90s were over more. I mean, they changed the IROC decal those years.. I found examples without the 5.7
Here’s my 88 again 30k Miles with original badge and paint (below)
Here’s chazman’s 89 with 7k miles (below)
Here’s an 89 with 9k miles and original paint (per seller) (below)
Here’s an 87 that went through an auction with 246 miles and all original
(below)
And here’s an 85 with 12k miles..(below)
I’m beginning to think that the placement for 88-90 was slightly different upon more research.. interesting
(below)
Axle/Gears: G80 GU2
That photo gives me more questions and uncertainty.. ha ha
thats funny you say that about the later year irocs cause i was thinking the same thing .. most 85's i see, they are over like my white one ..
Now I gotta go check my cars this weekend, lol! The IROC is original, but the 92 was repainted at some point. Gonna check emblem location on both. Can I bring this back to the first post and throw out the following question(which should maybe start another thread?) Where do we draw line between buying an (in this case) original color car that we may want, and just buying any decent body to make into the car we really want? That's where my personal conflict is... Like I have posted in the classifieds. I really want an original yellow or purple car, but if color is more important than originality, what does it really matter? As far as this car goes tho, way more than I'd ever spend on something I really wanna drive.
Depends on why you want it. If you're after bragging rights and "it's one of none" obscurity, you probably want the real thing. If you just want what you want, then build up the whatever and turn it into what you want.
Very very true. Those were “eyed” and placed. No ruler, no template. Most guys used the light line. A replacement worker may have been off a little to the left or a little to the right or if you were rushing and back lining to get out to lunch or end of shift a little early. All while the car was moving and bumping along on the body truck conveyor.
Transmission: World Class T-5
Axle/Gears: BW 3.45
I have also noticed some slight variation in the position of the TPI emblem.
ambainb
LSX and LTX Parts
07-16-2019 02:31 PM
Kingtal0n
11-11-2009 12:32 PM
speedingpenguin
05-25-2007 07:47 AM
