Car TechSpecs
Car TechSpecs
Hello everyone, just new in here.... Always wanted a third gen Pontiac and I just found one in Costa Rica. It's quite difficult to find them there, so they are not in the best shape however it can be saved. I'm still in negotiations with the current owner and I wanted to know if there's any way of finding out what were the original specs the car came out of the factory. I've decoded the VIN and it's a 1990 Firebird with the V6 (doesn't have the original engine anymore) made in Van Nuys.... but really wanted to see what else came with that car..... Color, Options, etc etc
Here's the VIN....
1G2FS23T7LL206963
Any additional info will be highly appreciated!!!!
Here's the VIN....
1G2FS23T7LL206963
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Re: Car TechSpecs
Report for..
1G2FS23T7LL206963
Vehicle:
FIREBIRD 2 DR
Year: 1990
Build Date: Unk.
Found 20,553 vehicles matching that year and model in our database.
RPO Description Matches
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER)(USED WITH DELUXE SPORT PKG W32) GA(UB3) 20,553
UM6 RADIO,AM/FM STEREO,CASSETTE,ETR,INCLUDES CLOCK STEREO CASSETTE(UM6) 15,440
UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1) 20,553
U62 SPEAKER SYSTEM,4,DUAL COAX FRONT,DUAL COAX PACKAGE SHELF 4 SPKR SYS(U62) 19,465
VAN Unknown 20,553
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3) 16,647
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73) 19,698
WW4 AERO PACKAGE(BLACK)(USED WITH AERO PACKAGE W62) AERO PKG(WW4) 2,468
W62 AERO PACKAGE AERO PKG(W62) 11,433
W68 PACKAGE,FIREBIRD SPORT APPEARANCE APPEARANCE PKG(W68) 8,926
1SC PACKAGE-OPTION 03 (1SC) 11,837
1SZ PACKAGE OPTION- (1SZ) 9,892
18P WHEEL COLOR,CHARCOAL METALLIC (18P) 13,789
19Q MOLDING COLOR,BLACK (19Q) 4,413
41U EXTERIOR COLOR,PRIMARY,BLACK (41U) 4,481
6XS COMPONENT FRT LH COMPUTER SEL SUP (6XS) SUSP(6XS) 3,975
7XS COMPONENT FRT RH COMPUTER SEL SUP (7XS) SUSP(7XS) 3,975
8UY Unknown 10,513
82C TRIM COMBINATION,CLOTH,MEDIUM DARK GRAY (82C) 16,383
82I INTERIOR TRIM,MEDIUM DARK GRAY (82I) 16,654
829 SEAT BELT COLOR - MED DK GRAY (829) 16,654
9UY Unknown 10,513
AAA Unknown 19,999
AH3 ADJUSTER,SEAT,4-WAY MANUAL,DRIVER 4-WAY MAN D/SEAT ADJR(AH3) 12,011
AJ3 RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS(AJ3) 20,553
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9) 19,106
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3) 16,301
A31 WINDOW,ELECTRIC OPERATED,SIDE(USED WITH SE Z7M) ELEC SI WDO(A31) 16,301
A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90) 13,571
BC8 ORNAMENTATION,INTERIOR,FRONT DOOR MAP POCKET RH AND LH DR MAP PKT(BC8) 16,301
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING(USED WITH APPEARANCE PACKAGE Z12) BODY SI MLDG(B84) 20,269
CC1 ROOF,HATCH,REMOVABLE PANELS,GLASS HATCH RF(CC1) 11,423
C49 DEFOGGER,REAR WINDOW,ELECTRIC(USED WITH SPECIAL EDITION WA4) ELEC RR WDO DEFG(C49) 13,301
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60) 20,362
DC4 MIRROR,INSIDE,REARVIEW TILT,DUAL READING LAMP(USED WITH ASTRO ROOF CF5) I/S DUAL READING LP RR VIEW MIR(DC4) 13,570
DE4 SUNSHADE,REMOVABLE HATCH ROOF HATCH RF S/S(DE4) 11,423
D3V Unknown 11,200
D35 MIRROR,O/S LH REM RH DIRECT CTL,PAINTED PAINTED O/S MIR(D35) 13,055
D8E SENSOR (D8E) 17,557
D80 EXTENSION,REAR END PANEL(SPOILER) R/END PNL MOUNTED RR SPLR(D80) 12,938
E5Z ADAPTER - SPEEDO - DELETE 20,553
E9Z KEY - SPEEDO - DELETE 20,553
FE1 SUSPENSION SYSTEM,SOFT RIDE(USED WITH SPRING SPECIAL PKG YP9) SOFT RIDE SUSP(FE1) 13,212
GU5 AXLE,REAR,3.23 RATIO 3.23R(GU5) 13,103
IPC TRIM,INTERIOR DESIGN (IPC) 19,106
J41 BRAKE SYSTEM,POWER,FRONT DISC,REAR DRUM(CAST IRON) CAST IRON FRT DISC/RR DRUM BRK SYS(J41) 17,579
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC(USED WITH SE Z7M) CRCONT(K34) 13,532
K60 GENERATOR,100 AMPERE 100 AMP(K60) 16,080
LH0 ENGINE,3.1L(3.1T),V6(EXPORT) 3.1T(LH0)(EXPORT) 11,206
MD8 TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD A/TRANS(MD8) 19,460
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION)(MD8) A/TRANS PROVISIONS(MX0) 19,460
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS(USED WITH CALIF SEVILLE YP1) FEDERAL EMIS(NA5) 18,532
N24 WHEEL,15X7,FIVE INCH BOLT CIRCLE(CAST ALUMINUM) AL WHL(N24) 13,789
N36 STEERING WHEEL,SPORT-4 SPOKES SPORT STRG WHL(N36) 18,439
QPH TIRE ALL- P215/65R15/N BL R/PE ST TL AL2 (9591591)(USED WITH RS PACKAGE Y86) TIRE(QPH) 13,212
R6A CONTROL - SALES ITEM NO. 01 10,569
T96 LAMP,FRONT FOG(LAMPS ARE HANG-ON WHEN USED WITH STE, LAMPS ARE PART OF HEADLAMP WHEN USED WITH LE OR SE) FRT FOG LP(T96) 11,433
The first three digits are the RPO option, then the description and the numbers at the end tell how many cars matched that option in 1990.
1G2FS23T7LL206963
Vehicle:
FIREBIRD 2 DR
Year: 1990
Build Date: Unk.
VAN Unknown 20,553
8UY Unknown 10,513
9UY Unknown 10,513
AAA Unknown 19,999
D3V Unknown 11,200
Re: Car TechSpecs
Thanks for the reply Scott!!! Unfortunately that car is not an option anymore. Current owner is going crazy however found a way better option now. Would you mind running this one:
1G2FW21H3HN227629 (Pretty sure I'll get this car!!!)
Thanks again!!!!
Thanks again!!!!
Re: Car TechSpecs
Look for, or request the owner provide a picture of, the white SPID sticker on the inside wall of the center console that contains a bunch of 3 character codes. Those are RPO codes and would be the same type of codes that Scott posted for the previous car.
Of course this only tells how the car was built from the factory.
The last VIN posted is for a 1987 Trans Am with the LG4 carburated 305.
JRoy91RS
04-25-2003 07:06 PM
CWIROC
08-16-2001 08:41 AM
F-Messenger
03-12-2001 05:07 PM
brent walden
08-01-2000 12:29 AM
