Pinch Welds
Old 09-08-2017, 08:13 PM
Drew's Avatar
Received 1,054 Likes on 749 Posts
Pinch Welds
I'm working on restoring the pinch welds on the project turkey. Like most, the car was jacked under the pinch welds, so they were a nice mangled mess. I've got a reasonable idea of what I'm shooting for, how they are supposed to look, but it'd make me feel better to lay eyes on a couple unmolested pinch welds. Specifically I'm talking about the front tabs where the fenders mount at the bottom.
So, pic request for the low mileage, un-mangled folks. Let's see some minty straight pinch welds.
A few nice clear photos from the back side of the passenger's fender mount would really hit the spot.
Thanks in advance!
Old 09-08-2017, 09:52 PM
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Transmission: Automatic
Re: Pinch Welds
I will look at mine in the morning, if they are in good shape I will post some pics.
Old 09-09-2017, 05:41 AM
TGO - 10 Year Member
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Re: Pinch Welds
Sorry, Drew. Mine were mangled when I got the car 17 years ago with 6k miles!!!
Old 09-09-2017, 09:52 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Re: Pinch Welds
Are You Referring To The Area Just Ahead Of The Notch For The Factory Jack.
Old 09-09-2017, 12:01 PM
Drew's Avatar
Re: Pinch Welds
Sorta... Except it's less of a notch and more of a flange. Or at least it is until about 5 seconds after the first time someone uses the factory jack, at which time it becomes more of a twisted wad of sheet metal roast beef sandwich.
Kinda like this but the passenger's side primarily... This is less of documentation of how it should be, and more of an artists interpretation sculpted in discarded Mustang fender. I call this piece, Rust-hole Be Gone!
Old 09-09-2017, 12:07 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: Pinch Welds
I'll get some pics when I get home.
Old 09-09-2017, 12:25 PM
Drew's Avatar
Re: Pinch Welds
Much appreciated!
Old 09-09-2017, 12:31 PM
Jbuchanan's Avatar
Car: 1987 GTA
Engine: 5.0
Re: Pinch Welds
Mine is the roast beef sandwich with cheese. Sorry
Old 09-09-2017, 03:00 PM
Drew's Avatar
Re: Pinch Welds
No sweat. I don't recall ever seeing a thirdgen that they weren't mangled. I haven't looked too closely at the Iroc, or the convertible, but I know the Formula's have taken some heat, and the project bird lived a life of adventure and danger, so they were mauled.
I recall the first time I jacked up my first Camaro with the factory jack, and the ensuing body damage and panic to let the stock jack back down, then looking around to be sure no one saw me crush the rocker panel...
I may live to be 80 years old and I'll never understand why GM couldn't pair the car with suitable lifting points and a jack that actually matches those points.
In the back of my mind, I was sure I was the only one with mangled pinch welds, it's kind of comforting to know it's a wider spread issue than I even considered.
Old 09-09-2017, 03:59 PM
chazman's Avatar
Axle/Gears: BW 3.45
Re: Pinch Welds
Hope these help.
Old 09-09-2017, 04:23 PM
Drew's Avatar
Re: Pinch Welds
Thank you, but I need to see the back side of the flange if possible.
Old 09-09-2017, 04:37 PM
chazman's Avatar
Axle/Gears: BW 3.45
Re: Pinch Welds
You're a tough customer, Drew!
Old 09-11-2017, 05:38 PM
Saxondale's Avatar
Car: '84 Z28
Engine: L69
Re: Pinch Welds
Old 09-11-2017, 10:10 PM
GASPEDDLER's Avatar
Re: Pinch Welds
Hope these help, one day I'll get around to removing all that undercoating.
Old 09-12-2017, 09:57 PM
Drew's Avatar
Re: Pinch Welds
Thanks guys! Definitely helps to see a few unmangled. I wouldn't mind seeing more if anyone else feels like contributing. Now just to hammer and dolly the project to match.
Old 09-13-2017, 05:03 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Pinch Welds
Wouldn't mind seeing that before, during and after project documented.
Old 09-13-2017, 10:12 PM
Drew's Avatar
Re: Pinch Welds
It's a little complicated, because the driver's side was both smashed and rusted out. What was left of the fender mounting tab was cut out so I could patch the hole in mostly one piece. It's literally a scrap of junk Mustang fender I beat into submission and welded into the car.
The passenger's side is mostly just crushed, so I've been hammer dollying it back into shape. It's a long way from pretty, but an improvement from how I found the car.
Attached Thumbnails Pinch Welds-drivers-pinch-weld-13a.jpg   Pinch Welds-drivers-pinch-weld-02.jpg   Pinch Welds-drivers-pinch-weld-06.jpg   Pinch Welds-drivers-pinch-weld-24.jpg   Pinch Welds-p3170024.jpg
Old 09-14-2017, 08:12 AM
DynoDave43's Avatar
Re: Pinch Welds
Nice work. Yeah...that's mangled. You do not exaggerate.
Old 09-14-2017, 08:37 AM
chazman's Avatar
Axle/Gears: BW 3.45
Re: Pinch Welds
Wow! Nice work.
Old 09-14-2017, 09:02 AM
82tarecaro's Avatar
Re: Pinch Welds
That looks good. I guess you are trying to figure the best way to trim the metal in the back of the tab?
