B4C 1le production numbers
Old 12-13-2016 | 08:16 AM
field70's Avatar
Hello, I purchased a 1992 RS camaro that has been sitting for many years, it is an ex highway patrol car in Canada and inside the storage compartment it has 1LE codes and BC4 codes. I just trying to figure out how many were built in 92, it is a 5.0 5 speed, thanks.
Old 12-14-2016 | 05:24 AM
3rdgenparts's Avatar
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
Re: Bc4 1le production numbers
Correct Police package Code is B4C, NOT BC4
1LE is good lol
PLEASE POST PICS OF CAR !!! AND THE RPO CODE STICKER
Dave
Old 12-14-2016 | 07:26 AM
field70's Avatar
Thanks for the reply! Sorry I got the b4c backwards. I will put some more info and pictures up when I get it out of storage. Any idea on the production numbers of a b4c 1Le car? Thanks
Old 12-14-2016 | 09:54 AM
Drew's Avatar
Search.
Seriously production numbers have been discussed to death. All 92 B4Cs had 1LE brakes, being a 5spd makes it a bit more uncommon (there were a lot of 350 autos), but it's not a really rare combo.
Old 12-14-2016 | 10:10 AM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
702 1le packages were made in 1992.
Data from PurelyPMD.
Old 12-14-2016 | 12:43 PM
KMK454's Avatar
Car: 1991 Camaro B4C
The numbers I've seen thrown out are always:
B4C Production:
1991: 592
1992: 589
I have no idea how accurate those are.
In 1991, not all B4C cars had 1LE. I'm fairly sure all 1992 B4Cs came with 1LE. As for 5-speeds, it's probably very rare. Maybe 200 per year, but probably lower. Very few are left.
Please share some pictures! Was your car used in service in Canada, or did it just make its way up there after decommissioning in the US?
Old 12-14-2016 | 01:05 PM
rarebmx's Avatar
This is probably the best spot to get some solid answers.
https://www.thirdgen.org/forums/hist...91-1992-a.html
Old 12-14-2016 | 05:45 PM
field70's Avatar
B4C Production:
1991: 592
1992: 589
I will do that in the next couple weeks, it was used in Canada. It was a highway car for the rcmp for 4 years.
Old 12-27-2016 | 07:30 PM
B4C5.7's Avatar
Car: 1989 IROC G92 LB9 MK6
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
What a cool car, post pics as soon as you can.....My favorite color scheme on service cars! Welcome.
Old 12-29-2016 | 11:04 AM
field70's Avatar
here is the 92, it has been sitting in heated storage since 1997. We drained and replaced all the fluids, installed a complete new fuel system including tank, fuel pump, sending unit, filter, pressure regulator
and new injectors. Put a new battery in and it runs 100%.
Old 01-18-2017 | 11:24 PM
KMK454's Avatar
Re: B4C 1le production numbers
Wow, I love this car!
Old 01-21-2017 | 08:44 PM
B4C5.7's Avatar
Engine: LB9
Transmission: MK6
Axle/Gears: 3.45
Still digging this car, wow.
Old 02-07-2017 | 03:56 PM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
B4C Production:
1991: 592
1992: 589
To expand on this - 1992 Production broke down as follows:
305/5spd: 216
350/Auto: 360
(Compnine is only showing production of 576 B4C in 1992)
Old 02-07-2017 | 04:01 PM
PurelyPMD's Avatar
Engine: LB9
What color code is that?
TKO500
Members Camaros
27
07-22-2017 07:32 PM
m14mike
04-28-2017 10:10 PM
adambros
01-24-2017 05:41 AM
KMK454
Wheels and Tires
12-17-2016 01:59 PM
Drew
Brakes
10-17-2016 11:22 AM
Quick Reply: B4C 1le production numbers
