L69 engine bay pics
Old 03-11-2016 | 02:13 AM
1987 T/A GTA's Avatar
Car: 1985 IROC-Z
Engine: l69
Transmission: m5
L69 engine bay pics
Hey guys, I have an 85 iroc with the l69 and I'm about to restore it. Im looking for pictures of original engine bays so I can try and determine where everything goes since my engine bay looks like a birds nest. Any pictures will be greatly appreciated. Thanks.
Old 03-11-2016 | 06:54 AM
Saxondale's Avatar
Car: '84 Z28
Engine: L69
Re: L69 engine bay pics
Attached are two '85 former eBay auctions. Not great pics, but a start. I have more '84 and '83 underhood reference photos than '85. '85 did have a different air cleaner lid and nut than '84 '83. I will post '84 photos in a thread titled "L69 AC Hose Zip Tie."
https://www.thirdgen.org/forums/hist...-hose-zip.html
File Type: pdf
Old 03-11-2016 | 11:01 AM
gt4373's Avatar
Transmission: 5-Speed Manual
Windshield Washer Hose Should Run Through Notch In Tank And Along Inside Of Fender.
Old 03-13-2016 | 01:20 PM
z28cop's Avatar
Car: 1985 IROC-Z
Engine: L69
Axle/Gears: 373 Limited Slip
Old 03-13-2016 | 01:48 PM
Saxondale's Avatar
Car: '84 Z28
Engine: L69
Is your car the California plate car listed above? I say yes because of the upper AC hose coming off the dryer, and the GM sticker on the radiator cover. Nice car.
Old 03-13-2016 | 02:01 PM
z28cop's Avatar
Car: 1985 IROC-Z
Engine: L69
Lol, just realized the California blue one is mine when he was trying to sell it. Haha didnt notice cause the engine bay was dirtier than I would have ever let it get. Knew there was a mark on the rear fascia of mine, so i zoomed in and saw the mark. Wow, a lot of dust for 6 miles. Im thinking his "climate controlled" storage facilty wasnt as climate controlled as should be. Oh well, supposed to be here tues or wed. A little detailing, and she'll be back to perfect.
Old 03-13-2016 | 02:07 PM
Saxondale's Avatar
Car: '84 Z28
Engine: L69
I saved all the photos from that auction as a reference car. Wonderful car. A pinnacle in all the years of IROC Camaros. When one considers the progression of the Z28 from 1980 through 1985, the '85 L69 and LB9 LS was an amazing progression. After '85 there were improvements in drivetrain performance, but never any more gains in styling, and even losses depending on options/packages.
File Type: pdf
Old 03-13-2016 | 03:23 PM
RamIt's Avatar
Car: 1984 z28
Engine: 93 LT1 350
Axle/Gears: 7.625" 28 spline 3.23
Is your color California blue or WA8587Bright blue?
Old 03-13-2016 | 03:39 PM
z28cop's Avatar
Car: 1985 IROC-Z
Engine: L69
Yep thats it. Glad you posted it. That was the giveaway.
Old 03-13-2016 | 03:40 PM
z28cop's Avatar
Car: 1985 IROC-Z
Engine: L69
30 Bright blue
Old 03-13-2016 | 03:42 PM
z28cop's Avatar
Car: 1985 IROC-Z
Engine: L69
86 was the more purple blue
Old 03-13-2016 | 03:43 PM
z28cop's Avatar
Car: 1985 IROC-Z
Engine: L69
Before I sold it, I took over 100 photos of every inch of the car. If you ever need any to use, let me know.
Old 03-13-2016 | 03:44 PM
z28cop's Avatar
Car: 1985 IROC-Z
Engine: L69
I also have a lot of photos of one of the very first Norwood Iroc 350's
Old 03-13-2016 | 07:38 PM
RamIt's Avatar
Car: 1984 z28
Engine: 93 LT1 350
It would be nice to see some pictures in your VB garage. That color is certainly my fave. I had a 70 z28 that had a similar blue. Mulsanne blue.
Old 03-14-2016 | 04:53 AM
Saxondale's Avatar
Car: '84 Z28
Engine: L69
Check out how your blue '85 has an LG4 type AC hose connected to the dryer. You walked the line with that car, correct? Do you recall the situation?
[/QUOTE]
Old 03-14-2016 | 07:29 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Mine has that same line (with the short straight hard line) but in my case it's going over the air hose.
(Figured we could take this discussion out of the PM's. )
Old 03-14-2016 | 08:08 AM
z28cop's Avatar
Car: 1985 IROC-Z
Engine: L69
[/QUOTE]
Yea, left it for 30 minutes. Came back for start of 2nd shift and the guy who put on the ar cleaners decided to start back lining ( a term we used when the line was stopped, you put the part you were responsible for on cars as far back as you could. You then would have an extra 45 seconds per how every many cars you did, to sit or read etc) He of course didnt put his apron on and scratched my left front fender.##%£¥! So after getting to the end of the line.. It was built perfect, Except for the fender. So off the final line and out to the Blue Building (Final Audit) and was taped up, prepped and re spayed the fender. Ahhhh but this L69 shared so much with the LG4.
Old 03-14-2016 | 10:03 AM
gt4373's Avatar
Originally Posted by PurelyPMD
PurelyPMD Just Curious,Why Do You Run Your A/C Hose Over The Air Cleaner Ducting Instead Of Under It.
Old 03-14-2016 | 12:40 PM
PurelyPMD's Avatar
Engine: LB9
That's how it was when I got it, and that's how I left it.
Old 03-14-2016 | 01:43 PM
z28cop's Avatar
Car: 1985 IROC-Z
Engine: L69
Mine too. Thats the way it left Norwood. Makes it easier for me to clean, and doesn't rub the duct work.
Old 03-14-2016 | 02:12 PM
gt4373's Avatar
Hodge
05-01-2016 07:42 PM
85@IRocZ
04-03-2016 07:01 PM
kleetis
03-14-2016 08:10 AM
87fbodyy
03-10-2016 08:08 AM
jim mcgrew
03-09-2016 09:49 PM
