1991 Formula 350 75Kmi $5990 deal
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I found this at a dealership... it looks pretty clean, and the price is really right for the miles and the car itself...
http://www.cars.com/vehicledetail/de...3377/overview/
1G2FS2381ML200430
Vehicle:
FIREBIRD 2 DR
Year:
1991
Build Date:
1990-02-21
Found 47,612 vehicles matching that year and model in our database.
RPO Description Matches
1SC PACKAGE-OPTION 03 (1SC) 24,569
15P WHEEL COLOR,MEDIUM SLATE GRAY (15P) 5,382
6ZW SPRING COMPTR SELECT FRT LH SUSP(6ZW) 7,587
7ZW SPRING COMPTR SELECT FRT RH SUSP(7ZW) 7,587
8NL SPRING-COMPTR SELECT RR LH SUSP(8NL) 11,102
81Q MOLDING COLOR - BRIGHT RED (81Q) 12,546
81U EXTERIOR COLOR,PRIMARY,BRIGHT RED (81U) 12,730
82C TRIM COMBINATION,CLOTH,MEDIUM DARK GRAY (82C) 31,438
82I INTERIOR TRIM,MEDIUM DARK GRAY (82I) 31,861
829 SEAT BELT COLOR - MED DK GRAY (829) 31,861
9NL SPRING-COMPTR SELECT RR RH SUSP(9NL) 11,102
AAA Unknown 46,052
AH3 ADJUSTER,SEAT,4-WAY MANUAL,DRIVER 4-WAY MAN D/SEAT ADJR(AH3) 13,751
AJ3 RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS(AJ3) 47,612
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9) 44,743
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3) 41,671
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31) 41,671
A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90) 28,389
BC8 ORNAMENTATION,INTERIOR,FRONT DOOR MAP POCKET RH AND LH DR MAP PKT(BC8) 41,671
B2L ENGINE PACKAGE-V8 5.7L, PFI ENG PKG(B2L) 3,489
B8M VEHICLE GM - PROD WEEK 01 888
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING(USED WITH APPEARANCE PACKAGE Z12) BODY SI MLDG(B84) 46,790
C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49) 33,076
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60) 46,946
DC4 MIRROR,INSIDE,REARVIEW TILT,DUAL READING LAMP I/S DUAL READING LP RR VIEW MIR(DC4) 46,761
DG7 MIRROR,OUTSIDE,RH AND LH REMOTE CONTROL,ELECTRIC(PAINTED)(USED WITH SE Z7M,STE Z7N,LE Z7K) O/S ELEC R/CON PAINTED MIR(DG7) 27,108
D5X GEAR-SPEEDO DRIVEN (D5X) 3,489
D8F SENSOR (D8F) 1,221
D81 SPOILER,REAR,AERO WING RR AERO WING SPLR(D81) 13,733
E5Z ADAPTER - SPEEDO - DELETE 47,612
E9Z KEY - SPEEDO - DELETE 47,612
FE2 SUSPENSION SYSTEM,RIDE AND HANDLING(USED WITH PERFORMANCE PACKAGE WS6) RIDE & HANDLING SUSP(FE2) 10,360
GU5 AXLE,REAR,3.23 RATIO 3.23R(GU5) 26,461
G80 AXLE,REAR,POSITRACTION,LIMITED SLIP POSITRACTION L/SLIP R/AXL(G80) 9,171
IPC TRIM,INTERIOR DESIGN (IPC) 44,743
J65 BRAKE SYSTEM,POWER,FRONT AND REAR DISC 4-WHL DISC BRK(J65) 3,474
KC4 COOLING SYSTEM,ENGINE OIL KC4 4,569
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34) 30,237
K68 GENERATOR,105 AMPERE 105 AMP(K68) 8,835
L98 ENGINE, 5.7L, (5.7-8) 350 CID, V8, TPI 5.7-8(L98) 3,489
MD8 TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD A/TRANS(MD8) 43,399
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION)(MD8) A/TRANS PROVISIONS(MX0) 43,399
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5) 43,196
N10 EXHAUST SYSTEM,DUAL(USED WITH TOURING YP6) D/EXH(N10) 4,569
N36 STEERING WHEEL,SPORT-4 SPOKES SPORT STRG WHL(N36) 41,430
N64 WHEEL AND TIRE,SPACE SAVER SPARE(ALUMINUM) STOWAWAY SPARE(ALUM)(N64) 7,327
PE0 WHEEL,16X8,ALUMINUM,LIGHT WEIGHT STYLED LGT WT AL WHL(PE0) 5,382
QLC TIRE,ALL P245/50ZR16/N BL R/PE ST TL HWY TIRE(QLC) 10,360
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER)(USED WITH DELUXE SPORT PKG W32) GA(UB3) 47,612
UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1) 47,612
UX1 RADIO,AM/FM STEREO,WEATHER,CASSETTE,EQUALIZER,ETR,INCLUDES CLOCK STEREO AM/FM W/CASS & EQLZR(UX1) 28,268
U62 SPEAKER SYSTEM,4,DUAL COAX FRONT,DUAL COAX PACKAGE SHELF 4 SPKR SYS(U62) 47,612
VAN PLANT CODE VAN NUYS, CA, CPC VAN NUYS,CA PLANT CODE(VAN) 47,612
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3) 37,477
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73) 44,388
WS6 PERFORMANCE PACKAGE,SPECIAL(MERCHANDISING OPTION) SPECIAL PERFORMANCE PKG(WS6) 10,360
W66 FORMULA OPTION(MERCHANDISING OPTION) FORMULA(W66) 5,464
1G2FS2381ML200430
Vehicle:
FIREBIRD 2 DR
Year:
1991
Build Date:
1990-02-21
AAA Unknown 46,052
Engine: 4++,350 & 305 CIs
Re: 1991 Formula 350 75Kmi $5990 deal
Its not far from me and I have a friend looking at it.
Car: 88 GTA Notch/01'WS-6 VERT
Engine: 5.0 LB-9/5.7 LS-1
Transmission: 700R-4/4L60
Axle/Gears: borg warner 3.27's
too far away for me but nice car and great price!!!
Car: 91 Z28 Coupe
Beautiful ride. Too far away. Good thing they have a picture of the keys. I wasnt sure if the car came with them.😅
Car: 92 Formula WS6, T-top
Engine: 5.7L T.P.I.
Axle/Gears: Limited slip, 3.23 10 bolt
I'm gonna be sick. Close enough for me, but I can't afford another car..... Have a 92 Formy now, but I could easily drive that car right home from where I am. I paid $1300 less than that for mine 15 mo's ago, but it had twice the miles (it's also one of only 200 92 ttop/350 combos, so I can't complain...) What makes it worse for me is that this is EXACTLY what I bought when I was 20 years old. Red 91 Formy 350 hardtop with 74k on it. Unbelievable......
Car: 1992 Formula 350
Engine: 5.7 L98
If that was traded in I wonder what they the dealer gave for it
