91 Z28 350, C&C T-tops
Old 03-10-2015, 07:06 PM
deeznuts94's Avatar
Car: 1991 RS/1991 Z28
Engine: 305 TBI/350 TPI
Transmission: 700 R4
Axle/Gears: 373
Whats up guys? I totaled my 91 RS back in October. I'm in the process of looking for another car. I found a local craigslist ad for a 91 Z28. The guy says that its a 350 car and was special ordered with the car corral t-tops and red leather. Does anyone know if this is possible? The tops are the ones that open like a sunroof. I have no knowledge of these type of tops. Any info would be greatly appreciated. I'll post some pics of my wreck. Also I'm looking for a 91-92. Thanks
Old 03-10-2015, 07:12 PM
deeznuts94's Avatar
Axle/Gears: 373
re: 91 Z28 350, C&C T-tops
Here is a pic of the car from the ad.
Old 03-10-2015, 07:22 PM
TGO - 10 Year Member
Steve86TA's Avatar
Car: To many to list
Those are called "C&C" Cars & Concept T-tops. They were an aftermarket company that did the conversions
Old 03-10-2015, 07:34 PM
deeznuts94's Avatar
Axle/Gears: 373
Thanks Steve. Does this option hurt the value of the car?
Old 03-10-2015, 07:40 PM
Steve86TA's Avatar
You will get opinions from both sides. Me personally, I would rather have the 5.7 hardtop but if you like the tops... I'm sure someone will chime in but I think replacement C&C parts are very hard to find also
Old 03-10-2015, 07:59 PM
deeznuts94's Avatar
Axle/Gears: 373
Yes I would prefer the hard top too, but its almost to good of a deal to pass up. Thanks for your help.
Old 03-10-2015, 08:15 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
I think they look sharp and I wouldn't mind having them as a set, it appears the tops are removable,are they? I don't think it lowers the value.
Old 03-10-2015, 08:24 PM
deeznuts94's Avatar
Axle/Gears: 373
I'm pretty sure that they are removable. Im going to look at it Sunday.
Old 03-10-2015, 08:31 PM
mantaguy's Avatar
Engine: 5.0 EFI
Well I like them,beats taking the tops off and storing them in the bag.
Good Luck,I hope you get it for a good price.
Old 03-10-2015, 08:33 PM
deeznuts94's Avatar
Axle/Gears: 373
Thanks man, me too! I wont feel better until I have a replacement for my RS.
Old 03-10-2015, 08:35 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Yes, they are removable. Its basically a combination of a sunroof and T-tops.
Old 03-10-2015, 08:36 PM
deeznuts94's Avatar
Axle/Gears: 373
Thanks for the info. Are they glass or lexan?
Old 03-10-2015, 09:09 PM
They should be glass.
Old 03-10-2015, 09:18 PM
mantaguy's Avatar
Engine: 5.0 EFI
Here's some more pics of them.
https://www.thirdgen.org/forums/hist...up-t-tops.html
Old 03-11-2015, 06:58 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
Nice looking Z28 hope u take it home I always liked those wheels that are on it.
Old 03-11-2015, 08:20 AM
okfoz's Avatar
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I think right now they probably do not hurt the value a whole lot... However looking down the road 15-20 years they might... it is a hard call, no one can see the future, and T-tops with the 350 was NA on the Camaro from 1990-1992...
I have read where people actually like their C&C T-tops, and have good luck with them. I believe you can still get weatherstripping for them and everything, which would be a big factor... Of course if one breaks, you will spend time looking for another one would be the biggest down side right now.
Old 03-11-2015, 08:26 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
The pop-up C&C t-tops are a VERY rare aftermarket option and a great design if you ask me. Go grab the car if it's a good deal before somebody else does!
The other issues on the car are easily fixed as you drive & enjoy.
Old 03-11-2015, 10:26 AM
okfoz's Avatar
I was at the junk yard and they had a set of the pop-up T-tops... I grabbed one and took it outside to try it on my Factory T-top car and it was a definate no way I would be able to get them to work... I could have picked them both up for $50... wish I would have grabbed them now... 10 year and hindsight go a long way.
Old 04-09-2015, 06:36 PM
deeznuts94's Avatar
Axle/Gears: 373
I bought the car.. Here are some more pics.
Old 04-09-2015, 06:37 PM
deeznuts94's Avatar
Axle/Gears: 373
Can anyone find out production numbers on this car?
Old 04-09-2015, 06:43 PM
JT
Community Administrator
JT's Avatar
As the T-Tops are aftermarket, that information is not going to be documented by GM or researched through channels for GM records. You'd need to get the numbers from C&C - if they even existed - and they probably aren't detailed.
Old 04-09-2015, 06:50 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I said it on MIFB, and I'll say it again...great looking car...very cool tops. Congratulations!
Old 04-09-2015, 06:54 PM
deeznuts94's Avatar
Axle/Gears: 373
Ok, thanks JT! For future reference there is a place called the sunroof doctor that carries parts for them if anyone is searching. As far as I can tell they are the only place in the country that have parts
Old 04-09-2015, 07:07 PM
deeznuts94's Avatar
Axle/Gears: 373
Thanks mantaguy!
Old 04-09-2015, 07:10 PM
deeznuts94's Avatar
Axle/Gears: 373
Thanks Dave! I'm finally learning a little more about it and researching parts. I cant wait to go out cruising!
Old 04-09-2015, 07:15 PM
mantaguy's Avatar
Engine: 5.0 EFI
Thanks mantaguy!
I really like them tops
Old 04-10-2015, 06:40 AM
PurelyPMD's Avatar
Engine: LB9
Leather interior too - nice grab!
Old 04-10-2015, 09:04 AM
You won't be able to find any production numbers for C&C tops. They were installed by local dealers and shops. The shops were merely installing the kits without any central record keeping.
Old 04-10-2015, 11:21 AM
okfoz's Avatar
AFAIK C&C is long gone
If you want to do a search, they were Cars & Concepts out of Michigan... Between Brighton & Novi MI. They were just off of I96 about 5 miles or so to the EAST of US23
C&C was no small company in the day, they actually made several concept cars like the Banshee concept (around 1988) and the dustbuster minivan concept. They also did things with Ford, IIRC they did the convertible conversions for them... But that is a bit more sketchy.
John
Old 04-10-2015, 11:46 AM
okfoz's Avatar
Did a little digging, found this:
http://vb.foureyedpride.com/showthre...rsions-patents
Fine it points to a sister site for mustangs... BUT it gives some patents for C&C.
Also I found that that apparently according to that site, that C&C was bought by Masco industires http://masco.com/
Old 04-10-2015, 12:01 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Didn't Pacific T-Top in Huntington Beach California do a bunch? I remember looking at a 88 GTA 5.7 with tops and the sticker they attached under the hatch said Pacific. IDK?
Old 04-10-2015, 01:54 PM
okfoz's Avatar
Keep in mind that the C&C tops were done either at the dealer or an independent fab shop... So someone in Huntington Beach may have done some for multiple Dealers around the country before the dealer took delivery of car... kind of like some of the convertibles... Before the dealer even saw the car, it was converted then delivered.
John
Old 04-10-2015, 02:13 PM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
John
That makes sense. The dealer had told me it was delivered that way when I questioned the 5.7 and tops..... on a 88 model on the showroom floor.
That dealer was just outside LA.
Old 04-12-2015, 09:47 AM
deeznuts94's Avatar
Axle/Gears: 373
Cool guys. Thanks for all of the info. I found out that by Dads neighbor used to work at Cars and Concepts. He said when he was there all of the stuff that he worked on was Ford stuff, fox body Mustangs. I remember seeing the building when I was a kid. I have family that lives near where the Brighton building was. The neighbor guy couldnt believe it when I showed him the C&C logo on the corner of my ttops. lol
Old 04-13-2015, 07:34 AM
okfoz's Avatar
When I was in High School, my girlfriends step-dad worked down there... he was telling me they would literally break every Fox mustang then weld them back together when they converted them... He said every one you would hear a really loud POW! and then they would repair it...
Old 04-08-2016, 05:47 PM
deeznuts94's Avatar
Axle/Gears: 373
To all of you guys that were so helpful with my questions about the car I figured that I would post an update on the car. It cleaned up really well. I had the front clip shot. The interior and t top seals are next.
Old 04-08-2016, 05:51 PM
deeznuts94's Avatar
Axle/Gears: 373
Old 04-08-2016, 07:02 PM
PurelyPMD's Avatar
Engine: LB9
You are a good steward - fix what needs to be fixed & enjoy the car!
Old 04-08-2016, 07:17 PM
Great work. Now you can concentrate on fixing whatever is causing all that smoke coming from the exhaust pipes.
Old 04-11-2016, 07:28 AM
okfoz's Avatar
Is it Smoke or steam? It appears to be white, which would tend to make me believe it is Steam. Smoke, usually caused by oil, is typically Blueish.
Old 04-11-2016, 09:37 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Sounds like steam esssscaping
Old 04-11-2016, 11:06 AM
  #42
I was just bustin' his ***** a bit.
Old 04-11-2016, 03:41 PM
  #43
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
That is one sweet ride!
Old 04-11-2016, 07:29 PM
  #44
deeznuts94's Avatar
Axle/Gears: 373
It was cold out. That was the day I put it in storage for the winter
Old 04-11-2016, 07:30 PM
  #45
deeznuts94's Avatar
Axle/Gears: 373
Thanks man!
Old 04-11-2016, 07:33 PM
  #46
deeznuts94's Avatar
Axle/Gears: 373
Hey man, Can you change the title of the thread to Cars and Concepts t-tops instead of car corral t tops? So I dont look like an *** for not knowing what they were called. lol
Old 04-11-2016, 07:35 PM
  #47
deeznuts94's Avatar
Axle/Gears: 373
Thanks! It is a fun car so far!
88IROCvertZ
06-20-2016 11:27 AM
1Aauto
Sponsored Vendors
05-04-2016 09:07 AM
adamcgodby
04-01-2016 09:41 AM
SuziQ305
03-31-2016 08:59 PM
caddyescalade
Convertibles
18
03-26-2016 07:31 PM
Quick Reply: 91 Z28 350, C&C T-tops
