Differnt RPO Codes
Old 02-23-2015 | 01:54 PM
bahsarie1's Avatar
Car: 1991 Z28 Convertible
Transmission: 5 speed
Axle/Gears: 3.55
Differnt RPO Codes
Anyone know where I can find the differences between the trim levels of a 91 z vert?
Old 02-23-2015 | 02:01 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: Differnt RPO Codes
There is a SPID sticker, usually located in the console, or maybe on your year, in the cubby hole on the driver's side rear hatch area. That will tell you everything your car came with.
Old 02-23-2015 | 02:42 PM
bahsarie1's Avatar
Axle/Gears: 3.55
Mine are both gone
Old 02-23-2015 | 04:54 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
What is your VIN, I can run it if you like...
Old 02-23-2015 | 07:00 PM
bahsarie1's Avatar
Axle/Gears: 3.55
You can get rpo info via vin code?
Old 02-24-2015 | 07:56 AM
okfoz's Avatar
If you like you can go to www.compnine.com and they should have your RPO's for your VIN. It is a 1991, and everything I have looked up from 1990-1992 has been there.. . Unfortunately 82-89 cars are not listed... crossing fingers that some day they will be, but my hope is fading.
89-IROCZ-5.0TPI
02-22-2022 09:26 PM
Falcon50
08-22-2020 03:26 PM
racereese
10-03-2015 03:46 PM
Luigytico09
10-01-2015 08:46 AM
dusterbd
09-29-2015 08:40 AM
Quick Reply: Differnt RPO Codes
