decoded the rpo codes
Car: 86 Trans am
Engine: LG4
Axle/Gears: 3.27 9 bolt posi
i decoded the rpo codes of my 87 trans am hard top, what do you all think?
AAA- 4 way manual belt
AK1- Deluxe belt and should harness
AM9- seat rr split fldg
AR9- seat frt bkt, euro style
AU3- lock control, side DR Elec
A01- window tinted
A31- window power operated
A90- Lock Control; rr compt lid, rem cont elec release
BV3- ornamentation intr i/p black
B20- “ “ Luxury
B34- Covering, FRT floor mats carpeted insert
B35 “ Rear “ “ “
B84- Ornamentation Extr MLDG body side
B87-“ “ Emblem delete fender
B97- “ “ lower accent
CD2- indicator, WSWA Jar Fluid
CD4- wiper system
C49- defogger rr window
C67- hvac system, air cond FRT electronic controls
DK6- Console roof, interior
D3W gear speedo driven
D34- Mirror, visor vanity
D35- mirror outside rear view
D81- spoiler rr aero wing
D9A- sensor veh spd
E5Z- speedometer adapter delete
E9Z- speedometer key delete
F41- suspension system frt, rr, firm ride, handling
GU2- axle rear 2.73
G80- axle positraction, limited slip
J42- Brake System. PWR. FRT Disc, RR Drum, Aluminum
J50- brake system power
K34- cruise control automatic electronic
K68- Generator, 105 amp
LB9- Gas 8 Cyl, 5.0L TPI HO
MD8- transmission auto 4 spd thm 700r4
MX0- merchandised trans auto provisions o/d
NA5- emission system federal tier 0
NOD- norwood ohio
NP5- Leather Wrapped, Steering Wheel and shift ****
N24- wheel 15x7 aluminum cast, 5 in bolt circle
N33- steering column tilt type
N64- Wheel Tire Spare Space Saver Aluminum
PB4- lock control wheel
QYZ- tire all p215/65r15
TR9- lamp group
T93- tail stop lamp smoked
T96- lamp fog
UA1- Battery Heavy Duty
UF6- lamp intr console courtesy
UQ1- radio provisions for stereo
UTI- tone generator warning
UW1- Diagnostic system
UX1- Radio, AM/FM Stereo Cassette Equalizer
U25- lamp intr rr compt courtesy
U29- lamp intr i/p courtesy
U52- Cluster Inst, Electronic
U66- speaker system 4 dual frt dash mtd dual extd rge
U75- Antenna, power, radio
VK3- front license plate mount kit
V73- antenna fixed
WS4- model conversion trans am
WW2- appearance package(Silver) Aero #2
W62- aero package
W63- Package, Group 02
YR1- seat front custom
YS1- seat rear custom
YT1-build up dr qtr
YT9- Option Package, Fisher Furnished Parts
Y99- sales handling pkg
1PV- color scheme 21
18P- Wheel Color, Charcoal Met
6ZX- spring computer selected front left hand
7ZX- “ “ “ Right Hand
8NL- spring computer selected rear right hand
81Q- Molding color, Bright red
81U- Primary Color, Exterior Bright red
82C- Trim Combination. Cloth, Med DK Gray
82I- Interior Trim, Med DK Gray
829- Seat Belt Med DK Gray
9NL spring computer selected rear right hand
A01- window tinted
B20- “ “ Luxury
B35 “ Rear “ “ “
CD4- wiper system
D9A- sensor veh spd
GU2- axle rear 2.73
NOD- norwood ohio
TR9- lamp group
T96- lamp fog
V73- antenna fixed
W62- aero package
YT1-build up dr qtr
Received 1,852 Likes
Re: decoded the rpo codes
Fairly typical moderately well optioned car but by no means "fully loaded"...
15" wheels, drum rear brakes, standard gear ratio (yuck). Most of the usual interior type options except I don't see power mirrors or seats.
How much of it is left? (HVAC for example; I hope nobody has hacked that off the car? or stuck an Edelbrock carb on it or something?)
What is this "think" you speak of?
Car: 86 Trans am
Engine: LG4
Actually the only thing that is missing is the overhead console. The digital dash and hvac is all there. What i found different is the fact it is a non gta car with the digital dash. I know they made some but normally the only ones ive seen with digital dash are gtas. Unfortunetly i got it with no engine or tranny so a lt1/4l60e is going in it
