Translated my RPO codes
I translated the RPO codes on my 84 T/A, found them on a sticker under the center console.
Some of the neat things I found is that the car was original black on black with gold striping and the DE1, rear window louvers.
It was also a factory WS6 model! YEEHAW!
One of the wierd things it htat one of the codes says it has 14x6 wheels, but the very next code says 215/65/15 tires??
It also says that i"m supposed to have a "full sized spare"?
I also am supposed to have a "fixed" antenna, but it's power, possibly after market because the fenders have the "Vent" which I believe is from 85 and later years. Previous owner also mounted an 85+ front nose and rear tail lamp assembly and spoiler which, to be honest, I like better than the original 84 look.
Anyway, I've included the full list below. Some of the RPO codes didn't pull up unfortunately. II've listed them under the "Unknown RPO" thread.
9NB: SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
8NB: SPRINT, COMPUTER SELECTED, REAR, LEFT HAND
7ZX: SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
6ZW: SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
55A: STRIPE COLOR, ACCENT, GOLD (91)
19U: PRIMARY COLOR, EXTERIOR, LAMP BLACK (91)
19Q: MOLDING COLOR (BLACK)
19L: SECONDARY COLOR, EXTERIOR, LAMP BLACK (91)
179: SEAT BELT, COLOR CHARCOAL (91)
YT1: BUILD UP DR & QTR YS1: SEAT,RR CUST
YR1: SEAT,FRT CUSTOM
W62: ORNAMENTATION, AERO PACKAGE
WS6: PERFORMANCE PACKAGE, SPECIAL
WS4: MODEL CONVERSION, TRANS AM
V73: ANTENNA, FIXED
VK3: LICENSE PLATE, FRT MOUNTING PKG
VAN: ASSEMBLY PLANT, VAN NUYS, CA
U25: LAMP, INTR, RR COMPT, COURTESY
U23: CLUSTER, INST, TRIM ODOM
U21: CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
UU6: RADIO, AM/FM STEREO, SEEK/SCAN AUTO REV CASS
UT1: TONE GENERATOR, WARNING
UQ7: SPEAKER SYSTEM, 5, DUAL I/P, SAIL MTD STD SPEAKER
UP8: STEREO RADIO INSTALLMENT PROVISIONS
UA1: BATTERY, HEAVY DUTY
T93: TAIL & STOP LAMP, SMOKED
TR9: LAMP, GROUP
QYZ: TIRE ALL, P215/65R15/N BL R/PE ST TL HWY
N78: WHEEL, I4 X 6, ALUMINUM, HUB CAP, WHEEL NUTS
N81: TIRES, SPARE FULLSIZE
NA5: EMISSION SYSTEM, FEDERAL, TIER O
MXO: MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
MD8: TRANSMISSION, AUTO 4 SPD, THM 700 R4
L69: ENGINE, GAS, 8 CYL, 5.OL, 4BBL, HO
K34: CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K22: GENERATOR, 94 AMP
K19: REACTOR SYSTEM, AIR INJECTION
J65: BRAKE SYSTEM, PWR, FRT & RR DISC
G80: AXLE POSITRACTION, LIMITED SLIP
GT4: AXLE REAR, 3.73 RATIO D42: SHADE, RR COMPT SECURITY
D27: COVER, RR COMPT, TRUNK STOW
D1T: GEAR, SPEEDO DRIVEN
D03: PAINT, PROCESS, WATER BASE
DX1: STRIPE, FRT END, HWD
DG7: MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
DE1: SUNSHADE, BACK WINDOW
C95: LAMP, INTR, ROOF, COURTESY AND DUAL READING
C60: HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
C49: DEFOGGER, RR WINDOW, ELECTRIC
CD4: WIPER SYSTEM WINDSHIELD, PULSE
CC1: ROOF HATCH, REMOVABLE PANELS, GLASS
B35: COVERING, REAR, FLOOR MATS CARPETED INSERT
B34: COVERING, FRT FLOOR MATS CARPETED INSERT
B20: ORNAMENTATION, INTR, LUXURY
BV8: ORNAMENTATION, EXTR DR HANDLE, LOCK CYLINDER,
A90: LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
A31: WINDOW, POWER OPERATED, SIDE
A01: WINDOW, TINTED, ALL SHADED, W/S
AU3: LOCK CONTROL, SIDE DR, ELEC
AR9: SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AM9: SEAT, RR, SPLIT, BACK, FLDG
AC3: ADJUSTER, FRT ST, POWER, 6 WAY, BKT, DRIVER
AAA: 4-WAY MANUAL SEAT ADJUSTER
Codes that did not pull up:
E6N
WS3
WS8
WU1
17I
55P
V73: ANTENNA, FIXED
TR9: LAMP, GROUP
E6N
WS3
WS8
WU1
17I
55P
