84 Z28 RPO Codes Help !
Car: 84 Camaro Z28 HO
Transmission: t5
Axle/Gears: I will check !
So we were able to decode the 84 Z28 with most of th RPO codes but some did not , is there a way to find out ?
Here are the codes.
B3W
B9K
D1C
E6F
G14
WU1
YE4
YT9
11L
11U
17C
Thanks for any help on these!
Here are the codes.
B3W
B9K
D1C
E6F
G14
WU1
YE4
YT9
11L
11U
17C
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 89 GTA/90 Iroc Vert
Engine: 5.7/5.0L
Transmission: 700R4 x 2
Axle/Gears: 3.27/2.73
Re: 84 Z28 RPO Codes Help !
Try this 104 pg RPO list, maybe in there .... BW3 ....
BW3 : ORNAMENTATION, EXTR ROOF WINDOW TRIM, PAINTED
The OP's stated B3W, not BW3. B3W is Preliminarily Price Information.
The problem with those master RPO lists is that they don't account for the fact that GM reused/recycled RPO codes between years. Just look at Y84 for an example of this. Early Y84 ThirdGens was the Special Edition Trans Am while 1987-1992 ThirdGens had Y84 as GTA. Two completely different ThirdGens that shared the same RPO code - just different years.
Transmission: t5
Thanks JT , So is there a RPO list just for the year 1984?
Transmission: t5
Thanks Jersey for the RPO list , I was able to get a few more codes !!
IROCZDAVE (88-L98)
11-19-2015 07:03 AM
MikkoV
09-09-2015 04:25 PM
