Question about t-top shades.
Old 12-30-2012 | 05:29 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
Were the t-top shades a dealer add-on accessory or were they shipped in the car from the factory as an option? If they were shipped from the factory, was there a rpo code for them?
Old 12-30-2012 | 06:50 PM
jez3941's Avatar
Car: 1984 Trans Am- L69, WS6, J65, W62
Engine: 350 .020 over
Transmission: auto 700R4
Axle/Gears: 4.11 Limited Slip
Re: Question about t-top shades.
These are questions i would like to know as well. i am guessing that if they are factory they did not have an RPO and just came with the t-tops as part of the package.
i found some in a 89 firebird that i parted out a few years back and hung on to them and i was wondering, if they are factory is this the original box they could have come in, it fits them perfectly
Attached Thumbnails Question about t-top shades.-dscn3466.jpg   Question about t-top shades.-dscn3467.jpg
Old 12-30-2012 | 07:39 PM
82tarecaro's Avatar
Were they in the box? It is a shame that the foam falls apart on those shades even if they are kept away in the box.
Old 12-30-2012 | 08:26 PM
jez3941's Avatar
They were in that box in the back seat when i got the car, and yes i wish they were made with better padding material.
Old 12-30-2012 | 08:52 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
DE4 is the RPO for the sun shade option.
Old 12-30-2012 | 09:55 PM
jermdm's Avatar
Car: 1989 Iroc-z
So the shades are a factory shipped with the car item and not a dealer bought add-on accessory?
Old 12-30-2012 | 10:08 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
correct. if they came with your car it will be listed in your RPOs.
Old 12-30-2012 | 10:35 PM
jez3941's Avatar
so i looked at the option list for 82-84 and cant find DE4, does anyone know what year they were first available?
Old 12-30-2012 | 10:43 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
cant say anything about firebirds as my 83 is a HT but my friends 85 Z had a plastic version of the sun shade.
Old 12-30-2012 | 11:10 PM
jermdm's Avatar
Car: 1989 Iroc-z
Unfortunatly my iroc didnt come from the factory with DE4 rpo. Always wondered if my iroc had them or not but didnt know if there was a rpo for them. Closest rpo I have is DE1 which is the rear window louvers.
Old 12-31-2012 | 08:44 AM
2007xl50's Avatar
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
I will have to look at my RPO codes, My car came with the shades.
Old 12-31-2012 | 10:08 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
The TTop sun shades weren't an option on the Camaros. If you find a set for the Firebirds, they will work in your Camaro. I have a a few brand new in the box, never opened, from CoverCraft. They used to make them for the aftermarket using the correct GM headliner material. Unfortunately, I did take one out of the box and it was deteriorating also. I used it to have new ones made. They came in handy during the Hot Rod Power Tour when my AC decided not to work.
Old 12-31-2012 | 11:04 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
i thought it was an option on the camaros. you mean they werent avail unless someone got them from a bird?
Old 12-31-2012 | 11:07 PM
jermdm's Avatar
Car: 1989 Iroc-z
Hey scott. Not wanting to start a war here but so far were are getting they are a factory option and not a factory option. I also did a search for the DE4 rpo and it comes out to say its t-top shades. Dont know what to believe. I've always like reading your posts and I know you know what your talking about. So if they are not an option from the factory, will you still have the DE4 rpo? If you dont have the rpo, were they just part of the t-top package or did you just buy them at your dealership as an accessory? I'm just curious if my iroc could of came with them because when I bought it, there was a few parts missing like the rear louvers and all accessory bracket braces since the previous owner(i'm the second owner) installed crap headers and exhaust system. Plus there was a few other things missing also but since then, I found all the parts needed to make everything correct. I can see the shades coming from the factory but being stuffed in the garage in the corner with the rear louvers and when the previous owner sold the car, he didnt put them back on or in the car.
Old 12-31-2012 | 11:41 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
what Scott said is most likely tru. remember, there were some options that came on the bird the camaro didnt get and vice versa.
Old 01-01-2013 | 08:51 AM
scottmoyer's Avatar
They were an option for 3rd gens, Firebirds only. The Camaro did not receive the ttop sun shades to my knowledge. Unless someone can produce a window sticker from a Camaro that shows otherwise, I need to maintain my original thoughts that they were not available for the Camaro.
Old 01-01-2013 | 12:21 PM
FormerL69's Avatar
Car: 1982 Camaro Pace Car
Engine: LU5 Crossfire
I'll back Scott on this one. I don't recall every seeing an option for shades on a 3rd gen Camaro (can't speak about Firebirds).
GM did eventually offer them as an option on 4th gens Camaros, but never on a third gen AFAIK.
Old 01-02-2013 | 01:26 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
My 89 formula 350 came with the shades from the factory.
Old 01-03-2013 | 07:30 AM
jlarsson's Avatar
Car: 1989 TTA
Engine: 3.8L Turbo V6 - VIN 7
Transmission: 200R4
If you look at the STRIM sheet I just posted about here https://www.thirdgen.org/forums/hist...rim-sheet.html you see the CC1 code for the t-tops AND DE4 for the sunshades, this is for a 89 TTA, and STRIM is the sheet used for the assembly line to stuff the car with the bits as shipped to the dealer for the dealer prep ... looking at the other codes on there you see wheel caps, wheel lock kit, wheel nut covers, front airdam etc.
So yes defenitly put in there @ the factory ... if they did the same for the Camaro I don't know.
Old 01-03-2013 | 08:30 AM
scottmoyer's Avatar
It's already been said that these are factory options for the Firebird only.
Old 01-03-2013 | 08:35 AM
KuroNeko's Avatar
Car: 1986 Firebird, 1992 camaro
Engine: 79' 350, 89 305
Transmission: TH400, 700r4
yeah, my 86 bird had them but they werent with the car so i took the Velcro pieces off of the t-tops.
Old 01-03-2013 | 09:10 AM
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
Sorry did not see any proof of that as the Window sticker for the TTA don't call them out only listed on the buildsheet ...
Old 01-03-2013 | 09:28 AM
IMissMy86TA's Avatar
Car: 1988 GTA 5-spd TPI
Engine: 5.0 TPI
Transmission: T-5 baby
Axle/Gears: 3.45
had mine reupholstered. the stitching is not factory correct but the headliner material is. looks really nice
Old 01-03-2013 | 10:49 AM
TTOP350's Avatar
It could be on the console RPO sticker also.
Old 01-03-2013 | 10:55 AM
dctrouant1995's Avatar
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
I had some made for 20-30 dollars and there great. I guess you could say mine came with shades later. So what is the correct RPO code? DE4 or DE1? What is DE4 and what is DE1?
Old 01-03-2013 | 02:25 PM
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
Forgot about the SPI (RPO) sticker in the console and just double checked on mine (TTA) and yes it lists DE4 on there :-)
Old 01-03-2013 | 05:58 PM
scottmoyer's Avatar
DE1 are rear window louvers
Old 01-03-2013 | 06:57 PM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
So DE1 is window louvers and DE4 is t top shades, correct?
Old 01-04-2013 | 04:03 AM
jlarsson's Avatar
Car: 1989 TTA
Transmission: 200R4
Yes correct
Old 01-04-2013 | 08:40 AM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Ok thanks!
Old 01-07-2013 | 04:59 PM
85firebird89gta's Avatar
Car: 85 Firebird - purchased new
When my Dad purchased his 89 GTA new it did come with the shades direct from the factory. He did not purchase them as an add on. They had small velco tabs in the corners closest to the center support. Some time after I purchased the car from him the material became a big sagging bubble that rested on my head. So, I had to have them redone at a trim shop. They came out ok but not exactly the same as the original material. Recently however I purchased a set of black ones from covergrl "Princess" for my other GTA that did not have the shades in it when I purchased that car. I can testify that they are every bit as nice and just like the originals. I was really impressed with her work. They were reasonably priced and she completed them and shipped them within a few days of my order. She also had the velcro tabs on the shades she made. Although her velcro tabs are a little larger then the factory originals, they work great and look perfect in the car.
To be honest I prefer the shades in the T-tops. I like the way they look and in the Summer time you really do appreciate them. If I want to take the TTops off I do take them off but if they are in I have the shades in year round.
Old 01-07-2013 | 05:50 PM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
So the factory put velcro on the t tops for the shades? If so then mine actually did come with them, I have just a few of the velcro pieces on the t tops left
Old 01-07-2013 | 07:51 PM
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
this keeps the shades from sliding over the T bar area even tho they slip into the T top trim by the latch.
Old 01-07-2013 | 07:57 PM
Yes, There would be two small squares on each corner closest to the center support. The side next to the outside/handles did not have velcro.
Old 02-25-2013 | 01:09 AM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
wasn't there a company on here selling new T-Tops Shades ones that matched your interior color. i lost their email
Old 02-25-2013 | 01:15 AM
KITT1983's Avatar
http://www.lethalinteriors.com/t-topshades.html
http://www.1aauto.com/1A/Interior/Po...SV00100/336514
1Aauto
Sponsored Vendors
08-26-2015 02:14 PM
1Aauto
Sponsored Vendors
08-24-2015 03:40 PM
Penultimo
Camaros Wanted
08-20-2015 08:42 PM
qz6lwp
08-20-2015 08:10 PM
redmaroz
08-16-2015 11:40 PM
Quick Reply: Question about t-top shades.
