Survivor TPI people, need a few pictures
Car: 1987 Camaro IROC-Z
Engine: LB9
I am looking for pictures of how the spark plug wires are routed from the factory for 1987 TPI. my wires are a mess now and have been burned a few times as they are routed wrong, I'd like some pictures of how it goes from the factory so before I ruin another set of wires this would be helpful and give me an idea of what wire guides I need to purchase first.
thanks in advance
thanks in advance
Re: Survivor TPI people, need a few pictures
Engine: LB9
Not really, my manifolds are different, would melt the plug wire in a minute routed the way it shows there.
Car: 1985 Trans Am/WS6
Engine: 5.0 TPI
See if you can find some pix from Jaguars that Run's TPI swapping book. Great pictures of engine out of car. Driver's side wires were routed from underneath exhaust manifold and passenger side over.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I saw this beautiful 6k mile 1LE at a car show and specifically took pics of the ignition wire routing. This thing was an unadulterated gem, I'm certain the wires hadn't even been touched since it left the factory:
Car: 1991 Camaro Z28
Engine: 305 cid
Transmission: 5 speed
Axle/Gears: Posi/3:42
Wow. Thats clean. This is a Players Camaro with RPO R7U, based on the yellow paint seen on the bolts on the valve covers, throttle body, runners, and thermastat housing. Was this car at the Camaro Nationals show in St, Catharines?
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Camaro show and plant tour of 5th gen factory in Oshawa -June 10th, 2011. Guy said he has 2 more 1LE's.
Engine: 4++,350 & 305 CIs
These are from about 88 or 89 I think but the routing should be close to the same.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Car: `86 SS / `87 SS
I'm a fan of routing the driver's side wires against the block on the driver's side (under the exhaust manifold exit, rather than over like those pics. It needs some effort to make sure they're secure to be away from the heat, but I've had the best luck with avoiding burnt wires with that routing.
NBrehm
08-25-2015 11:49 PM
Sanjay
08-12-2015 03:41 PM
