305 LG4 145 HP vs. 150 HP
Car: 1983 Z-28.. Owned since 1985
Engine: LG4 (H) Vin Code
Machanically (parts), what makes the difference between the LG4 145 HP and the LG4 150 HP ? I am not sure if its different pistons..heads or what.
Any Info would be great !
Rod
Phoenix, AZ.
Rod
Phoenix, AZ.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 305 LG4 145 HP vs. 150 HP
i think the only difference is improved(better flowing)catalytic converter-possibly revized ECM programming.There is no difference with the engine.
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
The difference was in the catalytic converter. The 145HP used the old pellet style converter while the 150HP used a modern monolith style.
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
GM used old hot-rod tricks to increase performance on the L69 engine - which was a factory hot-rodded LG4 motor.
The later LG4 motors got some minor updates that others have mentioned but they were not too much to write home about. The LG4 can be made to perform well but you are going to have to be willing to do a lot of work.
The good news is that many of the same speed parts that you can use to upgrade the 305 you can move over to a 350 motor if you choose to at a later date.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
85 brought the KS to the LG4 along with more aggressive timing and more compression. 87 brought the roller cam to the motor.
Car: '84 Z28
Engine: L69
Also don't forget that in '86 the LG4 got an electric cooling fan. Less parasitic drag. I think that was the majority of the 10hp increase from '85 to '86.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
'87 also had new heads with a more efficient combustion chamber design. That alone is worth at least 5 HP stock, and at least 10 HP in a more serious build. The LG4, as used in '82-'84, actually arrived for 1980. In the '80 Z28, with a single 2.25" pellet cat, it offered 165 HP. I suspect it was still using the LG3 cam, which I think was gone after '81.
Hotrodboba400
12-10-2019 07:07 PM
86CamaroDan
09-29-2015 10:08 PM
