Talk me out of modifying my all original 82???
#51
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: Talk me out of modifying my all original 82???
Chazman, I do not remember what gear my cuz had in his Crossfire. I would lean towards the 3.23 on a guess, as it was properly set up otherwise. His was a real looker, in black and gold. Had cfi, custom cloth in camel, t tops, the Conteur seat, and 4 wheel disc brakes with g80. I think it stickered around $16k, while my car was like the one in my avatar colorwise, with 4 speed (Saginaw, not BW, as it was a late build) t tops, the $28 cloth upgrade on the maroon interior, and not much else. He figured he'd duplicate my efforts and achieve similar results with the Crossfire. We put a test pipe in, and fabbed up two chrome air cleaners with a custom base plate. The "word" at high school was that he'd gone and put "2 fours" on the little 305! Well, the cfi cat was already a good flowing piece, and the cfi couldn't pass any more fuel, regardless of air cleaners. From a flat punch, it'd just lean out and stall! Not good. Put the stock air box back on, an it ran fine, but not any faster than stock. The q jet on the lg4 had plenty of extra to give if you let it, but the twin tbi's were all in even in a stock application. Oldtimer.
#52
Axle/Gears: BW 3.45
I
At this point in my life, I have zero time or patience to tinker...and that car would likely need tinkering for some time to sort out every little thing. It was/is beautiful, but sat outside neglected for several years (hence my need to redo it). When I fired it up in March from hibernating for the winter, and the cold start issue reared its ugly head (under 70 degrees, it would take 3-4 tries to keep it running when stone cold...but the cold start injector was fine?)...the A/C stopped working...the power locks stopped working...the RH valve cover started leaking oil onto the y pipe, causing a little smoke on start-up...honestly, I said the hell with it
However spending thousands on cosmetic or mechanical upgrades are not aggravating at all. Weird.
#53
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Isn't it something how all of those little fiddley problems can aggravate you enough to make you want to: 1) drive your car into the lake, 2) shoot it in the windshield or 3) sell it to the first guy that comes along.
2) At least with upgrades, you can SEE and FEEL the money being spent, and its rewarding. The most fun thing I've ever done with a car was watch my 86 go from an ugly duckling to a swan. It was worth every penny spent. I even made a small profit when I sold it.
The RS was a money-sucking PITA that I should've had about $9k in...ended up with $14k in it, and sold it for $7,750 Oh well...I learned something at least. And now the new owners have a great car, and reaped the benefit of my hair pulling.
#54
We seem to be fightng the rot factor on the Thirdgens more then breakdowns or mechanical issues. Rubber parts and seals rotting from old age and stuff. The only mechanical repairs I have had to do on the 86 since 2005 is an altenator, and an oil pressure sending unit. Lots of maintenance though. Everything else is more or less cosmetic. I guess that is how it works when these cars are only driven a couple hundred miles yearly, and are stored and transported in an air conditioned trailer... Of course I am so OCD, that everything has to be perfect, or I am stressing over it until it is.
Our daily drivers are an 07 Crown Vic, and an 08 Crown Vic. I run the 07 hard and constant, but that is what I bought it for. Old people go for comfort, and these are just about the only late model full size RWD full framed cars one could buy.
Still working on the 91 RS. Betty is putting up a fuss because I already own four cars, an SUV and an F-350 Crewcab dually. Add the two boats, and Betty thinks that I have plenty of toys already.
That ZZ4 engine does looks like a good choice for the RS.
Charles
Charles
#56
At first I thought about making an exception and making that one mod to the car. Very few people would question that it was not OE. Only the diehard thirdgen fans would know. Since than, I have decided not to make any mods at all, as once it starts it sort of like a snow ball rolling down hill.
As for the wiring, I have not looked to see if there is a provison or not. I just bought a factory service manual for the 82 Firebird. Just for kicks, I will look at it and try to determine if there were provisions or not. Since only the 82 Crossfire cars had that option, it may not.
Charles
Charles
#58
Almost positive that the LG4 cars did not have a functional cowl induction option available until 1983. On the 82 Cross Fire cars it was part of the package. The 82 hood with the dummy cowl induction has all of the holes for mounting the cowl inducation parts, however since it was not a factory option, my car could not have come with it. As much as a functioning cowl induction impresses folks at shows, since it is not a factory item for the 82, it probably should remain a decoration as it was from the factory. On the underside the hood insulation covers everything. Everything is flat and one can't tell that there is a scoop from under the hood. The little black 305 with its flat air filter and single cold air tube looks pretty tame sitting there, but that it just how it is. One thing I have noticed is that the previous owner was using premium E-10 in the car. With an 8.6 compression ratio, 87 octane is a better choice for this engine. I filled the car with fresh 87 octane 100% gas, and the car seems to like it a lot better. The car runs smoother, and actually seems to have more pep to it, or maybe I am just getting used to it, and it seems faster... Either way, I am starting to like the car for what it is, which is a good thing. The Camaro RS is still a possibility. Betty assumes that I want it for a parts car, and is not as resistant to the idea of buying it if that is what it is for. I have not said anything one way or the other, so she does not know that I have plans for a street rod. Is it a lie of omission to let her think that the RS will be a parts source, than have a change of heart and build it? Maybe I ought to tell her that it would make a good base for a street rod, however I have not made up my mind what I will do with it. Leave it at that and see what sort of reaction she has? Seriously, Betty does not care what I do with the cars, she just has one rule. Everything has to fit inside of the garage. She wants nothing sitting outside in the yard.
Charles
Charles
#59
The stock 82 LG4 does not have the functional cowl. It has a standard flat air cleaner with the flex hose and hard plastic intake mounted on the driver side. The cowl hood intake has the black honeycomb screen or the solid plastic one. (At least the MSE does). The MSE engine is stock LG4 without the git kit added. We have that still in all the orig packaging and that has the 14" chrome air cleaner.
Glad you decided to keep her stock. I think "down the road" you wont regret it.
#60
MOD IT ! But make them reversible mods
~DaVe
~DaVe
#61
We drove the car out into the Deep Creek picnic area in the Great Smoky Mountains National Park for a picnic by the creek. The car gets all sorts of attention from people, as it is obviously in perfect condition cosmetically. People actually approach me and ask questions about it. It sounds like quite a trip, however round trip was 10 miles. I stayed on the back roads, 40 MPH, so we would not push those OE Goodyears very hard.
The car reminds me of an elderly person, slow and creaky. Everything works, however everything is stoved up, moves slowly, and makes funny noises. Especially the power windows, power locks and such. Everything fits like new, so it is not a wear issue. The car has not seen much use, but has also not seen much maintanance either. The driveline is all working correctly.
My first projects for the car will include replacing all of the the fuel hoses, fuel filter, heater hoses, radiator hoses, and belts. Then onto the doors, to lube and adjust the window regulators, window channels, lock mechanisms, hinges, and such. I also plan to service the front wheel bearings, diff, and replace the brake hoses. I am going to replace the OE tires, but have no idea what brand and style of tire to use. It would be nice to use a replacment Goodyear, however the GT's available have no resemblemance to the OE tires, and I am not a huge fan of Goodyear. I am thinking about the General Altimax, since it is a decent performer, has an agressive tread pattern, and is an inexpensive tire to purchase. No point to spend a fortune on tires for a car that will be driven between 150 and 500 miles a year. I am open to suggestions though?
#64
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
BFG Radial T/A
They are priced well, last a long time, and always look correct on 80's cars. Of course I like the period correct white letters out, but you can always turn them in if you want black walls.
#65
Thanks for the link. It's cool that Kelsey is making them. Even though they are correct for this car, they are out of my price range.
BF Goodrich tires do look good on our cars, and that is the tire that I ran on my 83 for many years. We also put sets of them several other vehicles, and they did not hold up very well.
When I upgraded the 83 to Michelin's the car drove like a new vehicle, however I hate to spend the money for a Michelin on a car that rolls 150 to 500 miles each year.
#66
That is a key problem here. Would I spend $1,400 on a set of "new" Gatorbacks for my IROC, when it goes 1k a year? Probably not. I spent 1/3 that roughly on my BFGs that are on it. Hard to justify. As long as its an American-made tire, that's what matters to me most.
For $200 each? Sure. $350? No way...
#68
Engine: 2.8/TBI/TPI
I've never had the BFG's not do well for me, but I only run specific sizes and types. On 15" wheels I run the radial T/As and I have gotten well over 40k miles out of the last set of 235/60-15. That's the only 15 I have run.
I run the sport comp 2 on my 88 in 245/50ZR16 and they are just flat awesome, but I think your car is only 14 or 15 right?
The 14s on my other car run BFG Touring T/A black sidewall and they get killer mileage and life too.
#69
On Probation
Engine: several
Transmission: none
Axle/Gears: none
When a car is awesome to drive, and looks right, then I'm a purist. In this case, I'm in favor of all the invisible mods: porting, cam, torque converter if automatic, axle ratio, polygraphite suspension bushings, and everything else that can be hidden. I'd remove and save the original exhaust, then do L69 / B2L exhaust manifolds, Mac y-pipe, Magnaflow cat, and some decent cat-back. Shouldn't be too challenging to hide any desired to the springs and sway bars. Still, save the originals. Likewise shocks & struts. And if the dash pad is cherry, do everything possible to keep it from cracking!
#70
Dash pad looks perfect, as do the PMD seats. The only problems with the interior is that at one point the original owner stored the car in a garage with a window. The sunlight faded the tops of the plastic panels in the hatch area, an the tops of the rear arm rests. The car has the OE roll up blind in the back, so it protected the carpet and storage well door. The plastic is solid and smooth to the touch, just some of the color is gone. the seat fabric looks like no one has ever sat on it, and is not faded. The marroon color is a tough one to match, as they apparently only made it for the one year. I am thinking that a professional quality vinyl/fabric dye may be the best choice? As for mods, I think that the car will remain stock. The gear ratio is a 3:23, so it is not a bad combo for the limited amount of power this thing generates. If I were to do any mods, it would be a WS6 style nine bolt with a 3:27 gear like my 86 has, than a 700R4 trans with an 83 shift plate. The ZZ4 crate engine would fit nicely in place of the 305, however it seems like a bad idea to even start modding this car, as once it starts where does one stop. I still believe that a high mileage rust free car will be my best bet for a street rod...
