Original paint/s for my 86 TA
Car: 86' Trans Am
Hey guys,
Is there a way to know or find out, EXACTLY, what paint/s were used on my car originally. Like, if I wanted to have it repainted and cleared with the exact same colors used originally? It's an 86 and while it's in great shape, I've been considering having it repainted and cleared since a buddy of mine is an excellent painter. I like the originality of the car, even the paint but the time is probably coming. Anyway, If I did get it repainted, I'd want the exact colors used originally. Since it was born in 1986, I don't know if it's even possible to find that info and if it is.....would I even want that same paint?(I'm sure there have been many advancements in paint over the years.) Any help/suggestions appreciated.
Thanks,
Jason
A photo for example of colors. It is clear coated. In fact, I believe that's the main issue for me. Some swirls and a little peeling by the door handles.
Thanks,
Jason
Re: Original paint/s for my 86 TA
My 82 was originally painted with enamel. I just had it repainted in urethane bc/cc and the painter used the color codes on the car to get a great match to the original colors. It is black and gold and I was worried about the gold matching, but the modern paints are able to be mixed to the same colors as what was on our cars when they were new.
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
What the paint codes are, I don't know. I just don't want you to have the wrong information.
I'd look at who the paint supplier was for GM at the time; I bet they kept records of what paint corresponded to what GM color. Also, I bet that exact paint no longer exists due to EPA regs changing how paint is made/sprayed over the past 20+ years.
Car: 86' Trans Am
Modern urethanes are worlds better then the original GM paint from the 80's. The BC CC was brand new technology at the time, and many of them suffered from peeling issues. The older single stage paints sucked too, and most are not available today. Don't be afraid to use modern paints on your car. Chances are they are better then what was on the car, and will give you the same, if not better look then original. Just make sure you go to someone who preps the car right. Black is very unforgiving.
Car: 86' Trans Am
It's a tough call between great original paint and a perfect repaint... It's only original once, but original paint won't look perfect forever. The good news is you have time on your side because your car looks good now and will continue to look good for some time.
Car: 86' Trans Am
Good luck with it. I know you have had the car a long time. Mine has been around since I was a kid too so I wanted it done right. I probably put more money into it then what it's worth, but she is a part of the family.
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Beautiful 86!! I had a blue hardtop version of your car I sadly sold in May. Is yours TPI? Mine was a TPI with a 2.77 rear...most gutless V8 F body I've ever owned, but with the base suspension and the creamy automatic it was smooooth. A great cruiser. I miss it...wish I hadn't sold it.
Mine had 34k miles on it, but was a full respray because it sat outside for some time. I say repaint it...it'll be a knockout shiny
Car: 86' Trans Am
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Well,Pontiac only used 1 Black Color for the 86 Fire Bird/TAs,Code 41.Your RPO list should have WA8555 BC/CC.And the fad dot stripes
and decals are available from http://www.phoenixgraphix.com/gm.htm#trans_am
Engine: 5.0 EFI
No,I have a 1986 Pontiac Firebird car order worksheet.
Car: 86' Trans Am
Wow. Thanks guys. Amazingly helpful. Much appreciated. Will update if/when I decide to have it painted.
84 TA NV
09-06-2015 08:02 PM
