Least common color?
Car: 1985 Iroc Camaro, 1974 type LT Z28
Engine: modified L98 corvette, L82
Transmission: 700r4, Turbo 400
Axle/Gears: 3.42, 3.42 posi
Least common color?
What is the least common color of the 1985 to 1990 IROC's.
Re: Least common color?
The following numbers are from the Camaro White Book.
85-88 (neither silver or yellow were offered thereafter). Here are the numbers, though I don't think it's possible to break them down into particular models.
85 silver 11684 / yellow 4599
86 silver 11750 / yellow 3915
87 silver 4997 / yellow 3052
88 silver 1574 / yellow 922
Silver = 30,005
Yellow = 12,844
Apparently, silver met. was a one-year IROC color in 85, yellow went from 85-87. Since I've never seen another silver met. IROC in person (I have seen a handful online), I'd guess it's the rarer color of the two, but I wouldn't bet much on it either.
Here's a list (from my 85 Camaro brochure) of IROC colors. These colors were divided between 21,177 IROCs:
Silver Met.
Black
Bright blue Met.
Yellow
Red
I've seen many black, blue, and red IROC's, but far fewer silver met. and yellow ones.
Check out medium orange or medium gray in 88.
JamesC
Silver = 30,005
Yellow = 12,844
Silver Met.
Black
Bright blue Met.
Yellow
Red
JamesC
Car: A lousy LS1 car
Engine: 347 Cu. In.
Transmission: Which One?
Just to clarify the white 85s. I was told that white 85 IROCs was available in the spring of 85. This would make sense because the 85 brochure (printed sometime in 84) does not list white. My white 85 was built in May.
Engine: 347 Cu. In.
You guys are listing colors that weren't available on the IROC-Z, which is what the OP asked. The least popular IROC-Z color by year are below:
1985 - yellow
1986 - yellow
1987 - yellow
1988 - Medium Orange
1989 - Bright Blue
1990 - Dark Red
The yellow was only available from 85-87 on the IROC-Z. It was available in 1988 only on the Sport Coupe. The majority of the colors were available on non IROC-Z cars, so we can't be certain what the count is for the IROC-Z only. The least popular color has to be the 1988 Medium Orange with only about 3k made for the IROC-Z and the Sport Coupe.
1985 - yellow
1986 - yellow
1987 - yellow
1989 - Bright Blue
1990 - Dark Red
Interesting choice of words. I believe the correct statement should be least produced you have no personal data on popularity.
Ive seen the Medium Orange IROCs before around, and for sale and i can say even though it might the least common, its a very ugly color in my opinion on the IROC. But my answer would have been grey though if not orange. I dont hardly see any grey or gunmetal metallic which ever of the two it was called.
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Medium Grey Metallic 88 IROC checking in
Its the only one I've ever seen in person. Seen a couple on eBay...that was it.
If this one gets crushed, that means I'm dead and my wife disregarded one of my final wishes
Most do not believe it is the factory color. 3,010 cars produced and was available on the IROC or Sport Coupe. However, I have only seen one Sport Coupe car ever with the color and it is owned by rsmith085 on this board. https://www.thirdgen.org/forums/memb...re22643-a.html
There is another IROC in mint condition in NY. Like most thirdgens the other remaining cars have been run into to the ground.
The color was reused by GM in 2001 to 2002 Camaros and renamed Sunset Orange Metallic.
Here is my 88 Medium Orange Metallic. I had it out last weekend at the cruise night and had a crowd of 15 to 20 people around the car taking photos and asking questions. I cannot even get gas without being approached or getting a thumbs up.
If this is true, if I could find an orange LB9 5 speed t-top to go with my grey one?? Hehehehehe....
Are you absolutely 100% positive its the SAME color as SOM? If so, I just changed my mind and I want another 88 instead of a Firebird. My father has an SOM 2002 Formula, and its the best damn color ever.
I actually use Sunset Orange Metallic touchup paint for my front nose and body rock chips because I can buy it right off the shelf at the local auto parts store and it is a direct match.
I am not sure if they made any production LB9 5-speed cars in Medium Orange. All the cars I have seen have been 5.0 or 5.7 autos.
However, I do know that a GM Engineering test car was made in Medium Orange in 88 in a 5-speed, with a posi, 3.45 gears, an oil cooler and 4 wheel disc brakes. This attached Road and Track article from 1988 featured the Medium Orange 5-speed car. Also, had no A/C or radio. Wonder if it was a 1LE car? Stripped down cars usually did not get these go fast parts and brakes.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I like the orange... Almost bought an Orange Metallic Formula 350 with almost zero options... No AC, No power windows, no cruise, nothing but a factory Cassette and power antenna...
John
John
Transmission: World Class T-5
Axle/Gears: BW 3.45
Yes, it is the exact same color. My friend has a 2002 Sunset Orange SS Camaro and we can park side by side and the paint color is exactly the same!! Exactly the same!!
Brian, I remember when you lived in Chicago and the Camaro club had a show and we parked your car next to a 4th gen Sunset Orange Metallic car and we all looked at them both - and honestly I couldn't tell the difference in color.
That '88 in the R&T story, is a car that has always stuck itself into the back of my head. Sometimes I cruise CL, wondering if I'll ever run across it. Knowing GM though, I'm sure it was crushed long ago.
Oh, BTW, the least common color has got to be the beige on your dad's '85!
It would be really cool if that 88 in the R/T story showed up. I still think that car was an early prototype for the 1LE package that GM Engineering was working on. It sure is packaged like a 1LE car but you are probably right that it was crushed.
The actual color of my dad's car is "light yellow" GM code 54 - WA8525 http://paintref.com/cgi-bin/brochure...age=10&scan=10
The "light yellow" only came on Z28's and sport coupes no IROC's
1 Post
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
I remember an orange SC from back in the day...looked a lot better with silver gfx vs. gold, IMO...
Just had the IROC out today for a ride to lunch and back (wonderful 97 degree weather here in Western MA). Glad my R12 AC is ice cold in that bad boy
Other than a small stumble on initial throttle tip in at idle when its really hot out, I seriously cannot find a thing about this car that strays from a brand new one. Frankly, with the way my old RS drove when it was brand new, I would say this trait was probably present the day it left Van Nuys
Car: '88 Camaro
Engine: L03 TBI
Transmission: WC T-5
Axle/Gears: 7.625 10 bolt stock 3.08's
I really love the color. When it's been polished and waxed it looks really, really good.
COTM Editor
Just stumbled on this while trying to search for the number of medium orange cars produced with a stick. I wish GM would of kept better track of production numbers. I can attest that people do not believe it's the factory color, I didn't believe it myself. I usually just show them the door jams that still have the gm stickers on it.
Pac J
05-17-2020 10:44 AM
gixxer92
05-18-2017 11:20 AM
1Aauto
Sponsored Vendors
10-19-2016 08:50 AM
1Aauto
Sponsored Vendors
10-13-2015 03:06 PM
Dragonsys
09-25-2015 03:51 PM
