235 vs 245 tires on 16"
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
This seems like a history question so posting here. My 92 RS came from the factory with the Z28 wheels. As a result I always thought I had the 245/50R16 tires until I went and looked the other day and see 235/55R16 is what is actually on it. Tirerack confirms this as a factory size possibility. Now with these two tires you have a difference in height of over 1/2". This would put the speedo off from one car to the next by a little over 2%.
My questions would be, were the transmissions fitted with different speedo gears depending on the factory tire size? Did I get the 235 because it is an RS and not a Z? Did they calibrate the RS gauge cluster to account for this height difference? I had the upgraded RS suspension as well so I am not sure why 235/55R16 would have ever been on my car
Re: 235 vs 245 tires on 16"
I have no idea what an "upgraded RS suspension" is but RS models in 1992 came with one of two tire sizes -- P215/65R15 or the ones you have when the 16" wheel option was ordered. Your tire size was also standard on Z28s except convertibles. Z28s with the G92 package and Z28 'verts got the P245/50ZR16 Goodyear GSCs. The P245 tires were not available on the RS.
The upgraded RS suspension was something like FE41 code or something like that.
Does anyone know what the two speedo gear part #'s were? I am actually putting new rims and tires on and 275/35R18 is within .2% to the 245/50R16 height
According to the Camaro White Book, F41 was not available after 1985. Also it does not list any suspension options for a 92 RS. Slater126 looks to be correct. All RS's that were ordered with factory 16's came with 235/55/16's; apparently you couldn't get 16s in a V6 RS.
Interesting since I thought most 92 RS's were V6's with 16's. Guess I was way off. I actually also thought that 16s were standard on all Camaros from 1991-02. Oh well. Now I know that 15s on an RS always means V6!
Can anyone clarify this issue? Need to keep the 1991-92 tire saga straight. You practically need a flow chart, LOL!
Hmmmmm, I have my build sheet at home, will have to take a look at it again.
Question still remains, how did they account for the taller tires on the z28 rims? Almost would make more sense that the speedo gauge itself would have been were the adjustment was. Seems like a pain if it was different gears in the trans. If anything for the fact it would be impossible to tell the RS 700R4 from the Z version on the outside
quick calc on height the 15" with the tires mentioned above would be 26" and the 235 on a 16" would be 26.17" or just over 1/2 a % larger so probably no significant reading difference in speed with either. this further would make me believe the adjustment was in the calibration of the RS gauge. cluster.....thoughts?
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
yes, the RS with the 16" wheels did come with the 235-55-16 tires, even harder to find today than the 245-50-16 ones...
Yup, it's an oddball tire size. Tire Rack has three versions, but none of them are high performance. There's 20 versions of the 215-15 and 11 versions of the P245-16.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
1992
1) the 245-50R16 Tires were ONLY available with the FE2 (Handling)
2) The 235-55R16 Tires Came with the F41 (Firm Ride)
3) The 215-65R15 Tires Came with the FE1 (Soft Ride)
John
John
To clarify, that''s for Firebirds. No performance suspension options appear on the option sheet for Camaros. You got the P245-16 tires with G92 and 'Vert Z28s, P235-16s with regular Z28s and RS models with 16" rims, and the P215-15s with regular RS models.
I knew I wasn't crazy. here is a shot right from my build sheet which was inside the center console. F41......
Also here is the coding for wheels and tires
CAMAROS, 1991 & 1992
NOTE: Not ALL of the Z28 Convertibles got the 245-50R16 Tires. (About 95 + in 1992 and 2134 + in 1991 Got FE2 with the 245 Tires)
FIREBIRD, 1991 & 1992
1) the 245-50R16 Tires were ONLY available with the FE2 (Handling) GTA & Formula, & Optional on Trans Am.
2) The 215-65R16 Tires Came with the F41 (Firm Ride) Trans Am Only
3) The 215-65R15 Tires Came with the FE1 (Soft Ride) Firebird only
Car: 1987 IROC-Z
Engine: Vortec 350 crate #12530282
Transmission: 700-r4 Auto
thank god i found this thread! haha. I'm in a bit of a pickle and need some help, my situation is this...
I drive an '89 IROC-Z, I have the 16" iroc rims off an '87 IROC with 235/55 tires on them, and a rebuilt 700r4 transmission out of a '91 Z28. (long story short, my '89 was stolen from me, wrecked and i am in the middle of rebuilding it) so my problem is that my speedometer reads around 5 miles off....says I'm going 55 MPH when im actually going 60 MPH.
now, what speedometer gears do i need to put in the trans to make the speedometer read accurately? I still have the original transmission from my '89 (its stuck in first gear, need to do some valve body work) would using the gears from the original transmission fix my problem?
There are other factors to consider, such as what is the rear axle ratio on your car. Also considering that a 1991 transmission would have the electronic speedometer, whereas I thought that the 89 was the last year for the cable driven speedometer in the Camaro.
John
Car: 1987 IROC-Z
If at all possible, i'd like a straight "This is the gear you need" answer.
If you could do that for me, it would be MUCH appreciated since I've been doing research on this problem for a month now and haven't found a straight answer. Every answer i find is for people swapping from 2:73's to 3:23's or something else, seems to me like nobody is running 235/55 tires and nobody likes the stock 2:73's. If you guys could get past my inability to do somewhat complex math, i'd greatly appreciate it! hahaha.
my specs are: 235/55r16 tires, 700r4 transmission, 9 bolt 2:73 rear gears. I do not know what speedo gears are currently in the transmission and I don't currently have the luxury of taking it apart to check.
Engine: 4++,350 & 305 CIs
John, whats the word on 92 Trans am verts with 16" wheels and non WS6? My friends car had the 235/55? 16s on it when he bought it. I'm fairly sure They were org tires. I'm getting the door sticker info as I type this.
when I bought it I was told it was from a '90 or '91 Z28, but it does have the speedometer cable connection, otherwise i'm sure it wouldn't be compatible, so maybe they had the year wrong. in any case, I have the stock 9 bolt, 2:73 rear end. To be perfectly honest, the math behind finding the proper speedometer gears is a bit over my head and I don't have the money to keep buying different ones to see if they work or not.
I need a few questions answered.
1) What engine do you have, LB9 or L98, those would be the only two with the 9 Bolt B&W
2) Do you have G92 or not?
3) At 70Mph what does your Tach read? (that would answer question 2)
As a rule of thumb, A...
2.73/2.77 gear @ 70 Mph is Tach reads: 1750 RPM
3.23/3.27 gear @ 70 mph is Tach reads: 2000 Rpm
3.73/3.70 gear @ 70 mph is Tach reads: 2250 RPM
or there about.
Tony,
As per the 1990, 1991 & 1992 dealer brochures:
Level I: P215/65R15
Level II: P215/60R16
Level III P245/50R16 (WS6)
Car: 1987 IROC-Z
It might not be a straight as you want answer
There in-lies another problem, the Borg & Warner was 2.77 not 2.73...
or there about.
or there about.
Every now and then I am made to eat crow...
I just learned that the Firebird had the following
Level I: P215/65R15 (FE1)
Level II: P215/60R16 (F41)
Level III P245/50R16 (WS6 FE2)
And the Camaro had the following:
Level II: P235/55R16 (F41)
Level III P245/50R16 (FE2)
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
