1985 TPI assembly historical question.
Car: 1985 IROC
Asking again since there is a wealth of knowledge here. The reason I ask is that I was told that the 85 TPI motor 305/350 was a very special motor and I read that early production motors were hand assembled.
Thus I ask if it was a common thing for the engine builder to initial the bottom of the pan after assembly. There are wax initials on the bottom of my pan.
Ill take pics
Ill take pics
Car: 1985 IROC-Z
Engine: LB9
Transmission: MD8
Re: 1985 TPI assembly historical question.
Please take pics and I will have to look at mine. Mine is a Norwood car, so if yours is VanNuys, it might just have been something one guy did there are youre the lucky one that got it.
Car: 1985 IROC
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
What kind of shift kit are you putting in? Planning more mods to it? I kinda liked how stock that car was
Car: 1985 IROC
Stock all the way unless there are some internal faults that need correcting. I weighed out so many way of repairing the stuck shuttle valve in the Valve body.
Let me know what you think so far after reading it.
Here is the write up on it.
http://www.nttga.net/forums/showthre...read-with-pics!
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I can't imagine that a hand assembled engine would be viable in a $15k car. These aren't exactly AMG or ZR1 engines.
Transmission: World Class T-5
Axle/Gears: BW 3.45
The only real difference in the '85 LB9s was that they came equipped with the L69 cam and good gears. In later years, the automatic versions came equipped with what is known as the "peanut cam", (which was essentially, the LG4/L03 cam), and standard 2.73/2.77 gears.
In '91-'92, the non-G92 auto LB9s came standard with the bigger cam, but unless you ordered the G92, (which required a stick on the LB9), they came with the more restrictive L03 exhaust.
The '85 is the hottest version of the LB9 that you could get with an automatic trans.
Car: 1985 IROC
I read on my vette board an article talking about the TPI engines for 85 were hand built until they could get production ramped up, There were actually pics taken of some ladies assembling the TPI motors for production.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Well ok then. Any of those ladies holding a micrometer?
There's nothing whatsoever special about "the engine" in a L98 or LB9. It's just yerbasic 305 or 350 long block, as far as assembly is concerned. Requires absolutely no treatment different in any way from any other 305 or 350 long block.
TPI "the intake system" might have been a different matter... they might have had to hack some together garage-like if they couldn't get the production fixtures built in time. Might at least partially explain why there were so many QC problems with TPI in 85. I had 2 friends with 85 Vettes in 85, and both of em spent as much time in the stealership for the first couple of months, as they did on the road...both for TPI-specific issues.
Car: 2003 BMW E46 M3 Vert
Engine: 3.2 I6 M power 333 h.p.
Transmission: SMG 6 speed
Axle/Gears: 3.62 posi
Check out this thread, The 85 TPI may have been under rated. https://www.thirdgen.org/forums/tech...k-85-iroc.html
Car: 1985 IROC
Here are the initials on the bottom of my pan.
By scotiapilot at 2012-01-08
Car: '95 Impala SS
Engine: 350/LT1
Transmission: (Sold my '89 Formula 350)
Are you sure it's not a quality checkpoint before the pan went on, and not initials ? To me it looks like a paint chip was circled and inspected for a leak (inside), then the inspector simply put a checkmark there when he found it OK.
Car: 1985 IROC
Not sure of anything but will accept anything that sounds reasonable like your explination.
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I believe that they were all hand assembled.. All engines in those years... Keep in mind that the Corvette engine was hand assembled with white gloves...
John
John
Fast355
12-02-2016 06:33 PM
ambainb
04-25-2016 09:21 PM
Iroc8t8
08-26-2015 08:14 AM
Sanjay
08-12-2015 03:41 PM
