pictures of stock engine bay
I'm looking at all kinds of 3rd gens out there.My trouble comes in when I look into a engine bay.I don't know what a stock one looks like for different years and engine types.I've got a 89 iroc w/5.7.So for the most part I know that.I fought my way through a basket case 86 bird with a 2.8.still working the bugs out of it.pulled a 305 truck motor out of a 90 camaro and put a 90 bird setup in it.3.4 block and heads with 3.1 supporting parts.I looked at a 84 camaro and it had a v8 with an air breather cover that had 2 outlets.But only one place on the front to conect to.also had a 4bbl.dont know if it's stock or not.I know if its a 350 its not!Post up everything you can.I think it would help alot of people out.I'll try to get more from the other cars up.
Car: 1985 IROC
Car: 92 Z28
Engine: LS3
Transmission: TR6060
Axle/Gears: Strange S60 3.73
Re: pictures of stock engine bay
1992 with 5.7 and air conditioning. I have many pictures of individual components and connectors during clearing of engine bay. Let me know if there is a specific item and I might have a pic for it.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Engine bay on 1988 GTA. All stock except the distributor cover is a polished aluminum Corvette type.
Thats some good stuff guys!Clean too!I like seeing the difference from the 85 305 to the 92 350.also the 88gta gives a nice view of the firebird side of the thirdgens.Any carbs and cfi pics out there.I got off late today.Hope to have some v6 pics up soon.
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
I'm lookin for pic of battery on passenger side trying to find out where some of my wires go harness I have done away with that junction box by lights
Car: 89 rs
Engine: 2.8 v6
Transmission: M/t
Axle/Gears: 5 Speed Manual
ok look at the earlier post by 92GTA and look at his upload, same picture in there his is just cleaner.
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
I need up by the headlights maybe 92 v8 tune port injection not muti port injection but thanks for pic
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Actually, the issue was there wasn't any IMG tag at all. I fixed the original post.
You need to have a set of [img][/img] tag for each image. The URL of the image goes inside a set of the aforementioned tags.
For example,
[img]https://www.thirdgen.org/forums/picture.php?pictureid=29677&albumid=4292&dl=1326590510=1[/img]
Will do:
For example,
Will do:
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
Does any one have a pic of the wiring harness by battery (right above the battery looking down) I have a harness all it says on it is 3226 I have to wires that look like oxygen plugs by battery on red and one orange don't know if for battery ( that's what I think it's for) and my factory harness has a plug for the electric fan but I can't find it on the new harness or the plug for the power steering pressure switch any one have this harness or knows what year the harness is would greatly appciate the help
Engine: 4++,350 & 305 CIs
I know I had a pic of the other side of this low mile 89 Iroc but I cant find it.
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
Does yours have an electric fan I have a new harness and i haven't seen the fan plugin
Car: 1989 irocz
Engine: 305 ho
Transmission: t5
i need to know what these plugs go to im lost thanks ones by the battery and the other comes out by alt
The cruise and throttle cable go over the runners and the trans TV cable goes under the runners.
#43
LOVE, LOVE, LOVE this thread!!! Thank you to all of you contributing. I'll post some pics myself tomorrow.... 2 specific questions to all of you with the 305 TPI(maybe 350?)... 1- the 2 smaller hoses on the throttle body, what size and which/where do these go? [a picture of this would be worth a $k....... 2- I have a wire loom that has a red wire, starts near the coil, goes pass side, and has a tiny sized glass bus fuse, then continues on to the front battery area, picking up a small gauge black ground wire. WHERE DOES THIS RED WIRE END? right now its just clipped...
thank everyone of you for the help on these sights.
#44
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
The larger hose on the TB is the fresh air supply for the PCV (goes to the right valve cover), the smaller hose is the inlet from the vapour canister.
A wire in the engine compartment with a glass fuse is not stock.
#45
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
#46
Thank you both very much for your help! Assessment of the wire is is probably correct. Previous owner made a mess of spaghetti under the hood... been keeping tpiparts.net wiring catalog in business...lol.
#47
Engine: 5.0 EFI
Got a new camera.Is the f clip for the c/control and throttle cable in the wrong place.
#48
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Here's my stock '89's LB9. Taken in 2000 . . .
Here she is 10 years later (~2010). Still holding her own!
#50
Engine: 5.0 EFI
Thanks TTOP, took notice when you guys started posting your pics.These pics come in handy don't they.
