pictures of stock engine bay
#101
Re: pictures of stock engine bay
I have the same.request for a good picture of the egr solenoid and its.connector.
#102
Hello, I have a need for a couple pictures of the MAP sensor and its connector. I'm mainly interested in the color of the wires. Mine seems to.be missing and I bought a replacement connector but need to see which wires they are.
MAF is 5 wires. Depending on how you look at the connector:
1- Black/White wire (Ground)
2- Black (ECM ground)
3- Dark Green (MAF Signal)
4- Dark Blue (12 Volt Burn Off wire power supply)
5- Red (12 Volt MAF power supply)
EGR Solenoid is 2 wires:
1- Gray (Ground from ECM)
2- Black/Pink (12 Volt power supply)
327_TPI_77_Maro
03-17-2011 11:04 PM
