Original battery group size?
Hello, I have a 1991 Z28 with the 350 TPI. What size battery belongs in my car? When replacing the ground wire (which was bolted to the exauhst manifold), I found that the battery did not fit in the battery box. It currently has a group 78 which is to big. Looks like the more you dig the more you find.
Thanks!
Thanks!
Re: Original battery group size?
Thankyou very much! This should help with the starting problem and I won't have to worry about the battery falling out during sudden acceleration or braking
Do you have a hold down bolt on the battery? Might be wrong but IIRC, they are close to if not the same width, 78 is just longer.
colton_carlson
03-08-2019 12:21 PM
toronto formula
11-10-2015 06:17 AM
Zachattack0925
08-12-2015 09:52 PM
knight72
08-10-2015 09:32 PM
