Do you have Cars and Concepts T-Tops? If so, Need Your Help!
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 84 Trans Am
Engine: V8 305 4bbl
I recently acquired a 1984 Firebird with the C&C t-tops. With the company out of business for many years, I realize that there's no way to find out when the t-top conversion took place, but I'd like to try.
I do have the stickers under the trunk lid, but the date of the conversion was never written on them. All I can go by, I assume, is the serial number on the C&C label, which is: 102736. So, I am asking if anyone out there has C&C t-tops and know when they were installed, please post the serial number and date of installation. Alternately, if anyone has any contact information for anyone that worked at Pacific T-top in California, please let me know.
![](http://img694.imageshack.us/img694/4821/dscf0033cq.jpg)
Thanks,
Joe
Thanks,
Joe
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Do you have Cars and Concepts T-Tops? If so, Need Your Help!
C&C did T-top conversions for many car models, from Mustangs, to Camaros, Firebirds, I want to think even Lincolns, and some other models.
More or less, if I understand how it worked, was C&C made a kit, and they would send it out to either dealerships to have it installed or qualified installers...
There should be some things that I have scanned in from original C&C Brochures.
John
John
1 Post
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
i have some C&C t tops in my 88 camaro !!
were can i find that sticker??
His is on the back hatch.
John
John
1 Post
Car: 1988 IROC Camaro (RHD)
Engine: 350 ci L98 SBC
Transmission: T700
Axle/Gears: 9 bolt BW, Disk, Posi-traction
I guess they had a specific kit for Camaros?
I have C & C T-Tops on my 1988 Camaro and am also looking for more information, as well as a set of seals!
Here is the Brochure if anyone is interested, I thought I posted it in the past...
Car: 85z28(sold),91 rs, 15'Mazda3GT
Engine: 5.7L V8 350 (ZZ4)
Transmission: 700r4 rebuilt with kits+ vette serv
Whats the difference between the original t tops and these? Just curious
The C&C tops are about 1.5 or 2" shorter front to back than the factory ones, it might be as much as 3" I do not know exactly, I just know they are shorter.
That and the Factory T-tops have RPO CC1
John
John
Any way we could document miscellaneous sales multimedia for our cars, like this brochure? Perhaps a General/Assorted Multimedia section where anything like this could be posted. Could also use that section to put in any other conversion information/packages like Mecum, VHO, etc. that people come across.
1 Post
Transmission: T700
The C &C T-Tops are 1" shorter. You can tell the difference because there is more sheet metal at the front of the car.
Other differences:
May rust less due to better water dispersal.
Stronger with better reinforcement.
Other differences:
The difference between stock ttops and C&C? One had a roof stamped for T-tops, the other started as a hardtop and had someone cut the middle of the roof with a Sawzall. C&C used rubber trim to cover the cut steel, GM did it all with weatherstripping. GM t-tops look like they're part of the car, C&C look tacked on like an aftermarket sunroof.
carlos64030 (03-10-2020)
1 Post
Transmission: T700
The C & C implementation is pretty good.
I only found out my T-Tops were C & C rather than factory when I needed to replace the rubber seals.
I will say one thing about the C&C Tops is they had some options that the factory units did not.. . For example they offered a pop up type, like a sunroof, which I thought was a really neat idea.
John
John
Car: '88 GTA, '89, '94 Firebird, '84 T/A
Engine: 5.0L TPI (GTA); '89 -2.8; '94 -3.4
Transmission: 5 speed (for all 3),auto for T/A
Axle/Gears: 3.45 (GTA only)
In reply to another thread on this site and also at gtasourcepage.com, I posted some pitures of the difference between C&C and CC1 t-tops.
The C&C t-tops, from the example I saw, had a very extensive "butterfly" rivetted into the hardtop roof to accomodate the t-tops.
The C&C apparently (annecdotally speaking) seem to be stiffer than the CC1 t-tops.
1 Post
Car: camaro iroc-z
the seals from sunroofdoctor are great.
i searching for these parts for a long time!!
are they rare parts or what? never found a good set of them.
![](http://i10.photobucket.com/albums/a123/Dennis-325i/cid_tie_8CC8D9416EC8B0C_5EBC_7A9E.jpg)
Transmission: Pro-built 700R4
If you got the seals from sunroofdoctor, why didn't you get the pillar caps as well? They have brand new pillar caps that look way better than the set you posted a pic of.
1 Post
Transmission: T700
Anyone here ever removed a C & C T-Top for restoration?
1 Post
Car: 89 rs vert/88 t/a GTA
Engine: 355 tbi/350 tpi
Transmission: 700r4 w/megashifter/700r4
Axle/Gears: 3.73/???
My gta has tht c&c logo in the tops.haven't noticed a sticker anywhere for them.
I m curious about something now tho.
are c&c ttops factory authorized like an asc convertible conversion was? Or did some random person drive a hardtop there and have the roof cut? Reason I ask is I have no spid stickerto check for an rpo code.
With all that said, C&C Sold Conversion kits to Dealers and some specialty shops for installing T-tops in Firebirds and Camaros, and several other models, there is a list I do not have it on me right now.
John
I think you should leave the conversion intact and paint in place. There has to be some sacrifice in strength by drilling out all those rivets to remove the frame. It's probably worth it to leave it in place when you have it painted.
1 Post
C&C did do some factory conversions for GM, for example C&C actually made the Banshee Concept car in the late 80's, they also maintained a fleet of Show Cadillacs at one time. C&C made convertible conversions for the Ford Mustang back in the 80's, They also converted the Olds Cutlass Convertible and the few Beretta Convertibles, which never made it into production.
John
John
1 Post
Transmission: T700
In some years T-Tops were not factory option for L98 IROCs due to body flexing, so instead C & C T-Tops were bought instead.
Car: 1991 Camaro
Engine: 5.0L
Transmission: A4
This looks like an old thread but I have then on my car and selling the seal kit and the tops if anyone is interested, please PM me
Asking $400 for the tops and the seal kit (used but in good shape)
Thanks Mark
located in Toronto Canada.
Thanks Mark
Car: 1991 Camaro
Engine: 350 5.7 L
Car: 1991 Camaro
Engine: 5.0L
Transmission: A4
Car: 1991 Camaro
Engine: 350 5.7 L
Car: 1991 Camaro
Engine: 350 5.7 L
I studied for a few days and came to that conclusion but really needed an expert opinion before i started spending 💰 and another thing i bought new t top trim moldings for them but the old broken trim pieces have no t top lock holes but the new ones have lock holes so confusing
Car: 1991 Camaro
Engine: 350 5.7 L
do you still have the seal kit for the c+c t tops? My son just bought a 79 Camaro and I can’t find the seals anywhere
Axle/Gears: 9-bolt/3.45
As already posted in this thread, this is the company that supposedly still services C&C t-tops and sunroofs. They only show seals for 3rdgens, but if you contact them maybe they can provide some type of information or assistance.
The Sunroof Doctor
Car: 84 camaro w/ 87 rs body kit
Engine: v6
Transmission: auto
Hi. This forum relates only to 82-92 Camaros and Firebirds; 3rdgens, not 2ndgens. And the person you're replying to appears to be showing a 3rdgen, unless I've missed something elsewhere in the thread, so his parts wouldn't fit your 79.
The Sunroof Doctor
The Sunroof Doctor
Linson
08-21-2015 02:12 PM
3rdgenparts
08-06-2015 09:03 AM
