my vin is rusty looking can i clean it with a wire brush
Car: 1992 camaro rs
Engine: 3.1 v6 MFI
Transmission: 5 speed
Axle/Gears: poss rear end
i have a 92 camaro rs 3.1 v6 5 speed poss rearend. when i got the car it had no windshield. i have had the car 2 years now and got the car running great. my vin tag is rusty looking but you can read the tag. my question is can i wire brush it and repaint it/ or is that a no no.. i know not to remove it. there is no reason to. dont want to mess anything up..
Car: 1987 TA GTA, 1987 IROC 1988 Formula
Engine: 350 tpi/305 tpi/350 tbi
Transmission: All have 700r4's
Axle/Gears: 10 bolt with 3:73's
Re: my vin is rusty looking can i clean it with a wire brush
put some por15 on it, mine is rusty too almost rusted in half
Car: 1992 camaro rs
Engine: 3.1 v6 MFI
ok, but is it against the law to do wire brush it and paint? the tag is sturdy . i was wanting to clean and paint it as long as i dont get in trouble. read alot about not removing it.but nothing on cleaning & painting it . can anyone give me a good answer..
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can't tamper with it or alter it in any way. That includes cleaning it and/or painting it.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
well here in tn as long as the VIN tag on the dash is redily readible you can paint it any color you wish,HOWEVER you must check your states particular laws for peace of mind!!
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
If it is just a surface rust you can probably remove it with just some metal polish. I have had really good luck using a turtle wax product that sells for about $3 bucks at autozone. Worked great at removing surface rust from chrome wheels and metal surfaces without any damage to the metal. Give it a try it could not hurt.
http://www.autozone.com/autozone/acc...questid=598266
Also, if the polish does not do the trick then try a little steel wool. It will not leave deep metal scratchs like a wire brush would.
db057
08-11-2015 10:11 PM
