90-92 140 mph,240 kph speedo cluster
1 Post
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
Curious as to which Camaros came with the 140 mph,240 kph speedo.
I believe the 90 Irocs came with them but was told it was only the 350 Irocs not sure about the 305 Irocs with or without 5 speedsand as for the 91-92 was told only 1LE and B4C Camaros came with them however that being said Ive seen a few 91-92 Z28 with them(US).So not to sure as to which Camaros got them and which ones didnt.
I havent seen any in any other 90-92 Camaros(Canada) any input would be great.
Re: 90-92 140 mph,240 kph speedo cluster
Hey Mike,
My '91 Z with a 305 cid and rpo code G92 has the 240 kph speedo cluster. Those that had the 350 cid would also have the same cluster. The 305 cid without the G92 would have a 180kph cluster. Also the redline on 240 kph cluster tac would be at 5500 rpm, were as the 180 kph cluster, the redline would be at around 6000 rpm.
The cluster in your pic, is that from your '90?
Talk to you soon.
Benny
Talk to you soon.
Benny
1 Post
Thanks Benny and Drew wasnt quite sure which Camaros had them and which ones didnt. That explains why some of the 91-92 Z28`s had them and others didnt. So am I to assume that since they came with the G92 package that the 140 mph-240 kph speedo`s are fairly rare.
-Benny- good to hear from you .The 240 kph pictured came from a 90 Iroc 350 car that was being parted out.
My 90 convertible being a US car from Tampa has the 110 mph speedo. I was thinking of installing the 240kph cluster but at the same time Im trying to keep the car stock . So I have yet to see what Im going to do with it.
darwinprice
17
10-11-2015 11:51 PM
