Identifying a 91 1LE Camaro Z28
Old 02-10-2011, 01:10 PM
1badnova's Avatar
Car: 71 Nova / 91 1le z28
Engine: 406 sbc / 305 lb9
Transmission: 700r4 / t5
Axle/Gears: 4.11s 8.2 / 3.42s
I have sourced a camaro and I wondered if I post the last few of the vin # can someone help identify it as an actual 1LE car. Its a 305 5 speed, no t-tops manual everything no a/c either.
Old 02-10-2011, 01:22 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Identifying a 91 1LE Camaro Z28
Vin itself won't be helpful. Check the RPO's for 1LE.
https://www.thirdgen.org/forums/hist...y-car-1le.html
Welcome to TGO. BTW, a search on site will generally provide the info you're looking for. As you can imagine, there's not much that hasn't been asked an answered.
JamesC
Old 02-10-2011, 01:26 PM
TGO - 10 Year Member
yo soy el warg's Avatar
Go to compnine.com and enter your vin.
Old 02-10-2011, 01:27 PM
1badnova's Avatar
I was told www.compnine.com would be helpful if I put the vin in but I guess not, dang oh well.
Old 02-10-2011, 01:37 PM
JamesC's Avatar
To eliminate the car as a 1LE, you could always check the brakes, which look like the ones in my vbGarage (click on the icon next to my online status to see pics if you're interested). The 1LE would also have an alum drive shaft. If the car doesn't have those....
JamesC
Old 02-10-2011, 02:07 PM
1badnova's Avatar
I tried compnine and it doesnt seem to tell you exactly what you're car is just what it could possibly have, is that about right?
Old 02-10-2011, 02:41 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
How about providing us some details about the car. What year, what model, etc. Just because it's a hardtop, manual with no options does not make it a 1LE. Especially if it doesn't fall in the 1LE manufacturing years. Check the center console (84-91) or rear lockable compartment (91-92) for the SPID label that has all of the RPO codes. Look for the RPO 1LE. If the car isn't an IROC-Z or Z28, then it isn't a 1LE.
Old 02-10-2011, 02:45 PM
Drew's Avatar
Received 1,054 Likes on 749 Posts
1LE means dual piston aluminum calipers with almost 1" larger rotors on the front brakes. If the brake calipers are rusty, they're cast iron and the car isn't a 1LE.
Old 02-10-2011, 06:06 PM
1badnova's Avatar
I checked the center console and rear compartment and nothing was in either, it didnt even look like something was removed. Just bare plastic honestly. Its a 91 z28, w/o a/c, 145mph speedo, 5500 tach, has the large wing.
Old 02-10-2011, 07:07 PM
JT
Community Administrator
JT's Avatar
Compnine will/should work for this. If you want, send me a PM with the VIN and I'll look it up for you.
Old 02-10-2011, 07:17 PM
1badnova's Avatar
PM sent.
Old 02-10-2011, 07:33 PM
JT
JT's Avatar
Received the VIN. Yes, according to the records, the vehicle is in fact a 1LE.
Old 02-10-2011, 07:35 PM
1badnova's Avatar
Call me crazy but I dont understand that site, all I see is how many vehicles had each option. What tells you that is a 1le?
Old 02-10-2011, 07:43 PM
JT
JT's Avatar
1LE is part of the RPO codes associated with your specific VIN.
As far as the Compnine site, it is showing RPO codes associated with your particular VIN and showing a rough quantity of production per RPO code. The top section that lists all the RPO codes would be applicable to your specific VIN. The bottom section lists all RPO codes for that model year. There is a difference between the two! The top section shows the vehicle is an 1LE without C60 (A/C).
They are showing about 469 1LE equipped Camaros for 1991, while our data shows 478 1LE equipped Camaros. Compnine's data is not 100% complete.
If you still have doubts, you can order a report (for a fee) that should also show it as a 1LE equipped Camaro.
Old 02-10-2011, 07:46 PM
1badnova's Avatar
Much thanks! I'm definetly getting this as it only needs a clutch w/ 70k on it and in very good shape for 500 bucks.
Old 02-10-2011, 09:04 PM
JamesC's Avatar
A 91 1LE with 70K for $500? Hummm. Have you verified the braking system? I'm unconvinced and suggest caution. However, if you've found a needle in the haystack, congrats.
JamesC
Old 02-10-2011, 09:16 PM
JT
JT's Avatar
Hi James I could understand such reserve. However, he gave me the VIN and it does have the 1LE RPO code attached to the VIN. Also does not show A/C and shows a few other deletes. As long as the VIN is of the car he is looking at, it appears authentic.
JamesC
Old 02-10-2011, 09:33 PM
1badnova's Avatar
I verified the brakes, driveshaft, dual cats tonight and they all seem to match.
Old 02-10-2011, 11:23 PM
Sleepy Z's Avatar
Car: 97 Camaro
Axle/Gears: 9" w/3.50 gears
When do you plan to replace the clutch? Katie works till 230 sat and 2 on sun. So after that I can help if you're doing it that soon.
Old 02-11-2011, 07:44 AM
Leo1le's Avatar
Car: 92 Trans Am 1LE JY
Engine: 305/5.0
Transmission: 5spd
What a score.
Good luck , have fun with it.
Old 02-11-2011, 04:16 PM
BlownZC's Avatar
Congrats! I found mine sitting in the weeds needing a clutch also. Best $225 I've ever spent.
Vintageracer
01-10-2020 05:33 PM
Linson
08-21-2015 02:12 PM
GVMV
08-16-2015 08:01 PM
GVMV
Exterior Parts for Sale
08-16-2015 07:08 PM
greeny
Wheels and Tires
08-12-2015 03:55 PM
Quick Reply: Identifying a 91 1LE Camaro Z28
