I'm missing 4 RPO [definitions]
Car: 1992 Firebird
Engine: 3.1
R6A
R8I
v1B
1SZ
1SC
^these are the 5 I need help with.
9UY: SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
81U: PRIMARY COLOR, EXTERIOR, BRIGHT RED (91)
81Q: MOLDING COLOR, BRIGHT RED (91)
8UY: SPRING, COMPUTER SELECTED, REAR, LEFT HAND
7XS: SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
6XS: SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
199: SEAT BELT COLOR, BLACK (91)
19I: INTERIOR TRIM, BLACK (I) (91)
19C: TRIM COMBINATION, CLOTH, BLACK (C) (91)
18P: WHEEL COLOR, CHARCOAL MET (91)
1SZ: ???
1SC: PACKAGE, OPTION 03
W68: MERCHANDISED PKG, FIREBIRD, SPORT APPEARANCE
V73: ANTENNA, FIXED
VK3: LICENSE PLATE, FRT MOUNTING PKG
VAN: ASSEMBLY PLANT, VAN NUYS, CA
U62: SPEAKER SYSTEM, DUAL COAXIAL
UX1: RADIO, AM/FM STEREO CASSETTE EQUALIZER
UQ1: RADIO PROVISIONS, FOR STEREO
UB3: CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
T96: LAMP, FOG
QPH: TIRE ALL, P215/65R15/N BL R/PE ST TL AL2
N36: STEERING WHEEL, 4 SPOKES, SPORT
N24: WHEEL I5 X 7 ALUMINUM CAST, 5 INCH BOLT CIRCLE
NA5: EMISSION SYSTEM, FEDERAL, TIER O
MXO: MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
MD8: TRANSMISSION, AUTO 4 SPD, THM 700 R4
LH0: ENGINE, GAS, 6 CYL, 3.1L, MFI, V6
K60: GENERATOR, 100 AMP
K34: CRUISE CONTROL, AUT0MATIC, ELECTRONIC
J41: BRAKE SYSTEM, PWR, FRT DISC, RR DRUM, CAST IRON
IPC: TRIM- INTERIOR DESIGN
GU5: AXLE REAR, 3.23 RATIO
FE1: SUSPENSION SYSTEM, S0FT RIDE
E9Z: SPEEDOMETER KEY (DELETE)
E5Z: SPEEDOMETER ADAPTER (DELETE)
D80: SPOILER, RR END PNL
D8N: SENSOR, VEH SPD
D3V: GEAR, SPEEDO DRIVEN
DG7: MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
DE4: SUNSHADE, REMOVEABLE HATCH ROOF
DC4: MIRROR I/S, R/V, TILT, DUAL READING LAMPS
C60: HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
C49: DEFOGGER, RR WINDOW, ELECTRIC
CC1: ROOF HATCH, REMOVABLE PANELS, GLASS
B84: ORNAMENTATION, EXTR MLDG, B0DY SIDE
BC8: ORNAMENTATION, INTR, DR MAP POCKETS
A90: LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
A31: WINDOW, POWER OPERATED, SIDE
AU3: LOCK CONTROL, SIDE DR, ELEC
AR9: SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AJ3: RESTRAINT SYSTEM, FRT SEAT, INFLATABLE, DRIVER
AAA: 4-WAY MANUAL SEAT ADJUSTER
R8I
v1B
1SZ
1SC
1SZ: ???
V73: ANTENNA, FIXED
T96: LAMP, FOG
Car: '89 RS vert
Engine: 305 TBI
Re: I'm missing 4 RPO [definitions]
Sorry, not a lot of help...
R6A ??
R8I ??
v1B ?? V1C : EXHAUST, SINGLE OUTLET EXHAUST
1SZ ?? 1SV=Option Package 20
1SC Option Package 03
Link to GM RPO codes here:
http://www.nkyfba.com/showthread.php?t=24655
R6A ??
R8I ??
Car: 1992 Firebird
Engine: 3.1
R6A ??
R8I ??
R6A ??
R8I ??
My car has dual exaust. Thanks for your help and the link. I don't know what option packages are. I'll have a look.
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
I found r6a, it says value package
https://www.thirdgen.org/forums/hist...-code-r6a.html
http://www.3rdgenformula.com/92/92options.htm
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
R6A
R8I
v1B
1SZ
1SC
1SZ: ???
V73: ANTENNA, FIXED
T96: LAMP, FOG
R8I
v1B
1SZ
1SC
1SZ: ???
V73: ANTENNA, FIXED
T96: LAMP, FOG
V1B = Discount Value Package
R6A = Control Sales Item No. 01
R8I = Control Sales Item No. 59
1SC = Option Package 03
1SZ = Discount Option Package
These are of course subject to change, as RPO's can and do change after awhile, and can have different meanings from different years/eras!!
P.S. Your RPO meaning for V73 is wrong, V73 means "Vehicle Statement US/Canada", U73 means "Antenna Fixed, Radio"
Car: 1992 Firebird
Engine: 3.1
Hello sw33tp34!!
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
Option Value Packages are simply groups of individual options offered by GM at a reduced price when bundled. Your 1SC Value package on a 1991 V6 Firebird consists of seven individual options that you already have listed (C60, B84, DC4, A31, AU3, DG7, and A90).
The 1SZ code is the package savings value for your Option Value Packages that would have shown on the window sticker as a credit value. Example - you bought the car with Option Value packge 1SC at, say, $800 and it shows as $800 on the sticker. Then, on another line on the sticker, they show a credit of $500 coded as 1SZ-Option Package Savings. In effect you were invoiced only $300 for buying the seven options as a group.
Hope this helps. These 2 codes do not add any options to your car.
Car: 1992 Firebird
Engine: 3.1
Well you know how that goes... One person transcribes material from a book onto the internet. The next thing you know that material and the typo find their way all over the internet, and people are spreading bad info, and that bad info dies hard.
Car: 1992 Firebird
Engine: 3.1
Several people were debating that code on a different forum.. Yeah, bad info dies hard.
You could tell them that, but it really takes a long time for the good info to make it into circulation once the bad info has spread!!
Just a note, usually the RPO U73 "Antenna Fixed, Radio" is not listed on the SPID label, as it's part of the radio components package, but if your Camaro comes with a power antenna, then it will have the RPO U75 "Antenna Power, Radio"
