Find all options and build date by vin number
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Car: 1983 Z28
Engine: 355 SBC Vortec heads
Axle/Gears: 3.42 Posi
Re: Find all options and build date by vin number
I just ran my canadian non cc equiped car and got the list of RPO codes?
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
That's sweet! It says I have this option: 81PWHEEL COLOR,BRIGHT RED (81P)
15,098
yet my wheels aren't red at all?
15,098
Car: 1991 Z28
In the factory photos thread there is a ton of red Z28's with red wheels. Mine has no red on them at all, and they never have. Since I've had the car the wheels are just silver or gray or whatever that color is.
There are a couple different accent colors for the 91-92 16" wheels. Silver/gray is the most common, but red and white are also common. The most uncommon have a gold tint.
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
I ran my old 86 and it came up. Sorry didn't know it was posted.
Other colors might be:
33P Driftwood metallic
34P Light mesa brown
36P Yellow
37P Bright teal metallic
40P White
41P Black
42P Turquoise metallic
43P Bright aqua
50P Blue, white
52P Gold metallic
57P Beige metallic
72P Garnet red metallic
81P Bright red
Car: 1991 Z28
RPO code in the center console says 81P, so they should be bright red. Yet my car has no trace of red on any of the 4 wheels and I've owned it for a year now.
Quick cell phone pic of the wheels in my garage attached.
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Some red 91-92 camaros did not come with the red accent rims. I have seen a few over the years.
Chances are someone repainted them or swapped them for wheels without the painted accents. The red (pink) got old really fast.
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
Are there any other websites that I can check? I input my VIN# (both uppercase and lowercase) but it cant seem to locate my car. I dont have the RPO sheet (its missing from my console) and would love to go thru all my options.
Car: 86' IROC-Z....and 5 other 3rdgens
Engine: 383 hsr
Transmission: built 700r4
Axle/Gears: stock 3.23, 10bolt
yeah i used it and my 86 came up normal...but my 85 didnt. and one of my 92's didnt work but the other 92 did. and so did my brothers 90. oh and my buddys 87 wouldnt come up either.
Most of the cars in the database older then about 1990 are export cars. Most domestic market cars before 90 aren't in the system.
Car: 1990 camaro RS
Engine: 305 TBI
youve ownd a 19 year old car for one year and dont think someone may have changed the rims in those 18 other years? lol i know people who swap rims cuz buying used rims with used tires is cheaper then buying new tires.... im not suprised they have been changed....
Car: 1992 pontiac firebird
Engine: 305 v8 lo3 201.5hp and 268.2 tq
Transmission: 4speed 700r4 corvette servo
Axle/Gears: 3.42 disk posi 4th gen rear swap
it says my car is rare heres the link http://www.compnine.com/vid.php?vin=1g2fs23e3nl210321 yall tell me what u think
My car is really common, why does this indicate that it's rare?
If you parked your car next to one of the hundreds or thousands of similar cars in our database you probably couldn't tell them apart, but that doesn't mean they aren't different.
For example, some may have an RPO listing for the plant in which they were built. If yours was one of only a few that came out of that plant with a given list of options, it would come back as rare. Another car may have all the same options but was built at a different facility and thusly it's considered different.
For example... You've got a 92 Firebird base model, with the W68 aero package, CC1 T-tops, L03 305 TBI, MD8 automatic transmission, and FE1 soft ride suspension. That's about as specific as most anyone is going to care, anything more minor is just not that important.
Answer: Of the 22,334 vehicles in our database matching the year and model, 3,910 have all of those rpo codes.
Now if you knock it down to how many were this color with that radio, and power windows, and were built on a Tuesday, it sounds rare... But that's bench racing logic that doesnt really hold water, even with muscle cars from the late 60's.
I think (actually I know) it says every VIN is rare. Don't take it personally, but it seriously always says each car is 1 of 10 or less. The explanation is right below the figure...
Now if you follow the link to check option combinations that matter, the big options, you'll get a more realistic number.
Make's a lot more sense why there are a ton of cars that are pretty much the same when there are 4,000 instead of two. Also consider that 1991 was pretty much exactly the same, you can do the same search and find another 6,000 cars with almost identical major options. So in other words, aside from year, color, insignificant options, etc your car is 1 of about 10,000 similar cars.
Car: 13 Ford Focus SE / 90 Camaro RS
Engine: 122 I4 / 305 V8
Transmission: DCT / 700R4
Axle/Gears: 3.895 / 2.73
All the RPO codes listed when you put in you VIN are what's currently on the car or all the possible ones? I'm kind of confused on how to read the charts. Anyone explain it a bit for me please?
The top section contains the RPO codes for that specific VIN. There's a break (where "Rarity" heading appears) and everything below that is RPO codes possible for that Year, but not specific for the provided VIN.
Now, if only it had my build date... My build date sticker is too faded for me to read it. Maybe a high tech digital camera and some photoshop magic can recover the date...
Vehicle: CAMARO RS 2 DR
Year: 1990
Build Date: Unk.
Year: 1990
Build Date: Unk.
There are 21 1990 CAMARO RS 2 DR vehicles (0.064%) matching your exact options list. There are 51 (0.155%) with at least as many options.
The rarity thing on there should be done away with as it is misleading. All it does is find 100% matches based on all that information. Look at all the fields that are administrative and not about the physical car itself. It checks for matches there as well.
xbmx89
South Central Region
10-31-2015 11:59 AM
