How to Determine
Car: 1985 Firebird S/E
Engine: SBC 350, mild cam Vortec heads
Transmission: Rebuilt 700R4 vette servo+shift kit
How to Determine
How do I find out if my car is a Z28 or an RS doing paint soon so will have emblems off groundeffect and want to correct if need but i have both markers on my car z28 dash and such and rs ground effects emblems also i know in my yaer there were only about 10k rs made has limited availability so would be nice to know
2011 Norwood Gathering
ThirdGen Firebird Rep
Car: 99 WS6 / 00 SS / 11 CTS-V / 13 300
Engine: LS1 / LS1 / LSA / 5.7 Hemi
Transmission: 4L60E / T-56 / 6L80E / W5A80
Axle/Gears: 3.23 / 3.42 Auburn / 3.23 / 2.62
Re: How to Determine
Welcome to the board. Comments:
1) There is no such thing as a 1987 RS, unless you count a few thousand, V6-only models produced for the CA market, specifically. The chances of finding a real RS, 23 years later, across the US is pretty slim. Not impossible, but slim.
2) I would assume you have a Z28 based on the fact you have ground effects and the dash badge. An 87 base coupe would not have ground effects.
Do you still have the RPO sheet in the center console? Its a white sticker with a bunch of 3 digit codes.
dont remember a sticker in there and the ground effects have the rs logo on them
...which is easily swapped with a Z28 logo. If the engine is original, there is no way its an 87 RS because as I said, RS was V6-only in 87. Do the ground effects have "scoops" in them? Its possible someone swapped ground effects long ago.
The car is 23 years old...anything could've happened to it.
no its not original i have the reciept for the motor from napa
Post up all but the last 6 digits of your VIN and we can tell you what engine originally came in the car... It might help.
You might have to just take your best guess, become an expert on the subject and look for clues.
bubbaz28
09-18-2015 02:09 PM
LiquidBlue
09-13-2015 02:24 PM
