My RPO codes?
1 Post
Car: 1985 camaro Z28
Engine: 305 5.0 V8 carburated
My RPO codes?
I figured out what most of my rpo codes mean, but soem of them either don't show up on the decoder (camarosource.ca) or on any lists.
The codes are:
FE1
GU2
IPB
MD8
N90
Y86
739
I really wish there was just a complete list somewhere out there. I know this website has a small list for 87-92, but it only showed 87 and 88 codes. Maybe we can recreate a full organized list?
The codes are:
FE1
GU2
IPB
MD8
N90
Y86
739
Re: My RPO codes?
Straight off of Camaro Source:
FE1
SUSPENSION SYSTEM SOFT RIDE
GU2
AXLE REAR 2.73 RATIO
IPB
TRIM INTERIOR DESIGN (PB)
N90
WHEEL 15 X 7, ALUMINUM CAST, 4.75 INCH BOLT CIRCLE
Did you download the RPO decoder from this site? A complete list isn't anywhere near as easy as you make it out to be.
FE1
GU2
IPB
N90
1 Post
Re: My RPO codes?
Thanks! Where did you get those? I used the decoder at camarosource.ca. And yeah your right there are hundreds of codes out there, probably more.
Now I just need MD8, Y86, and 739.
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: My RPO codes?
Y86 is Merchandised Package Camaro RS
739 is Seat belt Colour Flame Red (91)
MD8 AmorgetRS told you already!!
The 91 means for 1991 it was Flame Red, should carry over to 1992
Found these on www.marshu.com
