Newby Question....
Newby Question....
I recently purchased a 1983 black TransAm with 43,000 miles from the original female owner. I'm not questioning the mileage - I believe it is accurate, I am questioning the originality of the paint. The car appears to have been repainted in some areas.
My neighbor owns a 1982 Corvette with 16,000 miles. He bought it from the original owner that swears the paint is original, but same exact issues - sanding scratches and over spray visible. We posted pictures of some of the areas on the Corvette forum and we were told that it was a common issue with cars that were painted at that factory location.
Is the same true with the TransAm?
I did try searching this answer.
Thanks in advance.
Thanks in advance.
Car: 1983 Z28
Engine: Forged 355
Re: Newby Question....
You could look up your paint code #'s and know for sure. Is your SPID sheet in the center console?
Car: 89 formula 350 & 2001 ws6 ta
Engine: 350 tpi & ls1
Transmission: 700r4, t56
Axle/Gears: 9 bolt ? & 10 bolt 3:42
It could be factory over spray
did you score and aluminum hood with that 83?
1 Post
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
can you post some pictures on here? there are several people with low mile original cars that could probably tell you if the overspray area matches what they have.
1 Post
Car: 1984 Camaro 'Vert
Its hard to tell without pics. But on one hand, it easily could have been a bad factory job. Especially the Van Nuys plant cranked out some terrible paint jobs.
On the other hand, it also wasn't uncommon for some of these cars to get repainted/partially repainted at the dealership due to factory defects or paint work shortly after the sale under warranty.
So, its entirely possible, based on your description that it is a factory paint job. Its also possible that the car had paintwork done to it, without the 1st owner even knowing.
Thanks.....that's kinda what I was thinking, based on the Corvette information I found.
I'd post pictures, but the issues/flaws are really subtle and unless you are as **** as I am - probably would not even see anything. I'm used to modern day paint jobs that are nearly perfect.
rubblerubble
03-13-2016 06:57 PM
