interesting special edition decals
Car: 1983 Camaro Z28
Engine: 305 cu.in
Transmission: stock
Axle/Gears: stock
Hey guys,
this was posted on super chevy looking for some feedback on the car. He says it's an 82 and it has some interesting special edition decals, please see below. I was under the impression the only special edition in 1982 was the Indy pace car, but this is not the correct decal. At this point I can't confirm anything other than what he says and the pictures. Will be trying to get more info such as VIN
Car: 1992 Camaro Z28 1LE
Transmission: 5-speed
Axle/Gears: G92 Perf. Axle
Re: interesting special edition decals
Those decals are not factory. They are aftermarket, probably dealer-installed. Decal kits and striping like that were all the rage with car dealers in the 1980s. Dealers would install stripes and decals at customer request or (more often) to pad profits further on hot-selling cars.
IMO the decal kit on that car is among the tackiest I have seen. No offense intended.
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello 3rdGenSuperman!!
I'd have to agree with TOM-1LE, those are some of the tackiest decals that I have seen also!!
Why is it that the words are reversed from one side to the other????
Does the article say???
Reminds me of the 1970's back in Quebec, everytime my dad, and I would see something like that, we would say there's a "Pepsimobile"!! Kind of an inside joke between my dad and me, but meant that it was probably a French guy, who put on the CanadianTire junky car gizmos, (stickers, dingleballs, naked lady air freshener, etc!!!
No offence meant, like I said, it was an inside joke between my dad, and I!!
Engine: 305 cu.in
Transmission: stock
Axle/Gears: stock
well, I also agree with TOM it's abosolutely horrid. It must be some french thing. I was just trying to figure out if it was an actual special edition. It's just a reader's rides post on super chevy....hey I'm just glad to see a 3rd gen on there.
HAHA canadian tire, they have everything,
CajunTire has almost everything, except for what your looking for, that you need, right now!!!
Engine: 305 cu.in
Transmission: stock
Axle/Gears: stock
yeah exactly, what you need right now any and every time you need it.
I agree IMO the nose looked newer as well. I don't have to much information. They said nothing about the nose swap, but there is a cover or bra of some type over the nose to it's hard to see the gfx and some of the defining features.
That's an 82-84 nose with a bra on it. Look at the turn signal opening. It's recessed, not flush.
HAHAHA IMO this is a terrible thing to do to any Camaro, if you look close at the third pic I think I see a mud flap installed there, wanted to keep those decals clean I suppose .
But back in the 70's and early 80's nothing was taboo. I remember putting a cowl induction hood scoop on a Datsun, hahaha.
There's nothing wrong with mudflaps per se for that exact reason (mine had them from the factory), but they do look a little hillbilly. Being on a Camaro of all vehicles doesn't do anything to mitigate that.
That aside, I actually am not a fan because they just ruin the paint surface of the inner wheel well and ground effect that they rub up against, and trap moisture and crud which hurts those areas further. Also where they are mounted to the wheel wells is a very good place for corrosion to gather.
I don't ever spin the tires though, so not having them and just being careful with the car has worked well for the duration of my ownership of the vehicle.
Also, if you look at the older fox body mustang GTs, you will see the opening in the ground effects forward of the rear wheels is almost always worn away and the yellow shows through. I can guarantee you the owner wasn't spinning the front tires causing the paint damage! There is so much garbage on the roads these days that sand and small gravel *will* get thrown at the side of the car when you have tires that stick outside the body, like the Camaros and Firebirds.
Mudflaps are also not just a thing of the 70s and 80s. I have them on my 2006 Chevy Silverado also and after 100k miles, I don't have hardly any stone chips. Many people on the truck boards are looking for the factory mud flaps to protect the paint on their trucks. If you don't like them, don't use 'em, but don't call people hillbilly for using them. I know alot of people that use them only when they drive and remove them at shows. They use binder clips to hold them on while driving.
Received 1,857 Likes
EEEeeeeewwwwwww........
That "Special Edition" thing is about the most utt bucking fugly thing I've seen all day. :barf: Goes to show how tastes change over time. Somebody probably bought that from JC Whitney or something and thought it was an "upgrade" back then.
It CERTAINLY isn't factory.
Glad I don't have to peel that off my car.
I remember buying a 78 Z28 once, musta been in about 86 or 87, came to me with whitewall tires and mud flaps. ALL FOUR no less. It was BEYOND hideous. I chiseled the guy down like $100 extra because it had those .... things .... on it and looked so .... ummm,,,,, .... yeah. I don't think they lasted 5 whole minutes after I got the car home. It amazed me how much better the car looked without .... that ..... on there. The whitewall tires didn't last much longer.
Gotta love the FEAR THIS! decal in the middle of the windshield too... Someone was a couple cans short of a six pack. Check out the factory glass hood leaning against the wall... It's probably worth more then the entire car. LOL
As mentioned "Special Edition" or "S/E" accessories were all the rage in JCWhitney junk several years ago. You could buy them at Kmart. They were in the next row over from that Ricky-Racer flex fan. Those huge decals are the largest, most obnoxiously lame example I've seen yet. The door handle inserts, key guards, hubcaps/center caps, mud flaps, etc are all more common. Even most people with bad taste didn't have bad enough taste to stick a ginormous hideous decal on the side of their car.
A little work with a heat gun and scrubbing with a soft towel and naptha would probably get it off without killing the paint. However if it's been on there since the late 80's, I'd be concerned that the image will be burned into the paint under the decal. It might look like a ghost image when the decal is removed. A rattle can repaint might look less tacky. Maybe, you could tape butcher paper over it?
You know to each his or her own, I think your car is as nice as I have ever see, well except for the mud flaps of course, just my opinion. Now if you just had those "Special Edition" decals maybe they wouldn't look sooooo out of place, lol. Just kidding, your car is immaculate.
Hotrodboba400
12-10-2019 07:07 PM
WhteRbt
09-21-2015 09:48 AM
