RPO code at Compnine.com
Car: 1991 Formula
Engine: 350TBI
i put in my vin and let it all load up. well i dont understand it. there are 2 sections. One with as a table with check marks and the other table without the check marks. Which table are the RPO codes for my car?
Car: 1991 Formula
Engine: 350TBI
Re: RPO code at Compnine.com
ok this is the top table. So my car has all of this?
Is any of this good or rare to have on my car?
because i just got this car last week for $1700
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER) GA(UB3)
CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER)(USED WITH BERETTA GT PKG Z21) GA(UB3)
CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER)(USED WITH DELUXE SPORT PKG W32) GA(UB3)
47,612
UM6 RADIO,AM/FM STEREO,CASSETTE,ETR,INCLUDES CLOCK STEREO CASSETTE(UM6)
17,942
UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1)
47,612
U62 SPEAKER SYSTEM,4,DUAL COAX FRONT,DUAL COAX PACKAGE SHELF 4 SPKR SYS(U62)
47,612
VAN PLANT CODE VAN NUYS, CA, CPC VAN NUYS,CA PLANT CODE(VAN)
47,612
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
37,477
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
44,388
WS6 PERFORMANCE PACKAGE,SPECIAL(MERCHANDISING OPTION) SPECIAL PERFORMANCE PKG(WS6)
10,360
W66 FORMULA OPTION(MERCHANDISING OPTION) FORMULA(W66)
5,464
1SA PACKAGE-OPTION 01 (1SA)
3,375
15P WHEEL COLOR,MEDIUM SLATE GRAY (15P)
WHEEL COLOR,SILVER METALLIC (15P)
5,382
19C TRIM COMBINATION,CLOTH,BLACK (19C)
7,941
19I INTERIOR TRIM COLOR (19I)
INTERIOR TRIM,BLACK (19I)
8,499
199 SEAT BELTS COLOR BLACK (19) (199)
8,499
41U EXTERIOR COLOR,PRIMARY (41U)
EXTERIOR COLOR,PRIMARY,BLACK (41U)
7,965
6ZW SPRING COMPTR SELECT FRT LH SUSP(6ZW)
7,587
7ZW SPRING COMPTR SELECT FRT RH SUSP(7ZW)
7,587
8NL SPRING-COMPTR SELECT RR LH SUSP(8NL)
11,102
9NL SPRING-COMPTR SELECT RR RH SUSP(9NL)
11,102
AAA Unk. 46,052
AJ3 RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS(AJ3)
47,612
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9)
44,743
CC1 ROOF,HATCH,REMOVABLE PANELS,GLASS HATCH RF(CC1)
27,277
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
46,946
DE4 SUNSHADE,REMOVABLE HATCH ROOF HATCH RF S/S(DE4)
27,277
D35 MIRROR,O/S LH REM RH DIRECT CTL,PAINTED PAINTED O/S MIR(D35)
17,468
D7C GEAR-SPEEDO DRIVEN (25513045) (D7C)
5,358
D8E SENSOR (D8E)
8,706
D81 SPOILER,REAR,AERO WING RR AERO WING SPLR(D81)
13,733
E5Z Unk. 47,612
E9Z Unk. 47,612
FE2 SUSPENSION SYSTEM,RIDE AND HANDLING RIDE & HANDLING SUSP(FE2)
SUSPENSION SYSTEM,RIDE AND HANDLING(USED WITH DELUXE SPORT PKG W32) RIDE & HANDLING SUSP(FE2)
SUSPENSION SYSTEM,RIDE AND HANDLING(USED WITH PERFORMANCE PACKAGE WS6) RIDE & HANDLING SUSP(FE2)
SUSPENSION SYSTEM,RIDE AND HANDLING(USED WITH SSE Y85) RIDE & HANDLING SUSP(FE2)
SUSPENSION SYSTEM,RIDE AND HANDLING(USED WITH STE Y92) RIDE & HANDLING SUSP(FE2)
SUSPENSION SYSTEM,RIDE AND HANDLING(USED WITH TOURING YP6) RIDE & HANDLING SUSP(FE2)
10,360
GU2 AXLE,REAR,2.73 RATIO 2.73R(GU2)
16,938
IPC TRIM,INTERIOR DESIGN (IPC)
44,743
J41 BRAKE SYSTEM,POWER,FRONT DISC,REAR DRUM(CAST IRON) CAST IRON FRT DISC/RR DRUM BRK SYS(J41)
41,181
K60 GENERATOR,100 AMPERE 100 AMP(K60)
38,777
L03 ENGINE,5.0L(5.0E),V8(T.B.I) 5.0E(L03)
ENGINE,5.0L(5.0H),V8(T.B.I.) 5.0H(L03)
ENGINE,5.0L,V8(T.B.I) 5.0(L03)
15,058
MD8 TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD A/TRANS(MD8)
43,399
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0)
TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION)(MD8) A/TRANS PROVISIONS(MX0)
43,399
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5)
43,196
N36 STEERING WHEEL,SPORT-4 SPOKES SPORT STRG WHL(N36)
41,430
N65 WHEEL AND TIRE,SPACE SAVER SPARE(STEEL) STOWAWAY SPARE(STEEL)(N65)
WHEEL AND TIRE,SPACE SAVER SPARE,STEEL STEEL SPACE SAVER SPA(N65)
2,566
PE0 WHEEL,16X8,ALUMINUM,LIGHT WEIGHT STYLED LGT WT AL WHL(PE0)
5,382
QLC TIRE,ALL P245/50ZR16/N BL R/PE ST TL HWY TIRE(QLC)
47,612
17,942
47,612
47,612
47,612
37,477
44,388
10,360
5,464
3,375
5,382
7,941
8,499
8,499
7,965
7,587
7,587
11,102
11,102
AAA Unk. 46,052
47,612
44,743
27,277
46,946
27,277
17,468
5,358
D8E SENSOR (D8E)
8,706
13,733
E5Z Unk. 47,612
E9Z Unk. 47,612
10,360
16,938
44,743
41,181
38,777
15,058
43,399
43,399
43,196
41,430
2,566
5,382
