Heritage stripe spacing?
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
Could somebody with a 92 with heritage stripes please measure a couple of different things for me?
First, I need the distance of each stripe from each other, in other words, measure the distance in the middle of the hood between each stripe, both at the front and back of the hood (if different)
secondly, could you measure the thickness of the pinstripe, and the distance between the pinstripe and the main body of the graphic?
thanks a lot!
thanks a lot!
Re: need help from somebody with factory heritage stripes
ttt
come on, give a guy a hand
Car: '92 Z28 Convertible
Engine: 305ci TPI
Transmission: 700R4 shifted
Axle/Gears: 2.73 (for now)
I don't know the measurements but here's a company selling the kit... I bet they could hook you up with the specs...
http://www.phoenixgraphix.com/gm/9192h.htm
that's possible, but it's not going to tell me how far apart to place them
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
If i can get back to my car this week, i can make measurements. Can also check my '92 service manual as i believe there were some specs, but not sure. I'll try and make it this week and get you some if someone else can't come through for you.
thanks, I did write an aftermarket place to see if they could help, but they admitted that there stuff is not to factory specs.
Sorry for my lame graphics, but I thought a drawing would be easier to understand than a description. I'm curious to see if everyone has similar dimensions, or if the factory had a wide tolerance. For this diagram, the hood centerline is the right margin.
Joel
Joel
very cool.... exactly what I needed, thanks
