84 Trans Am window switches
Car: 1984 Trans AM
Transmission: TH 350
Just bought an 84 Trans Am yesterday and it has electric windows but no switches. Where can i find these? Called all salvage yards within 100 miles but no luck.
Re: 84 Trans Am window switches
Try the dealer... For some reason I want to say a 84 T/A would be the same as most thirdgen Camaros. I haven't bought any recently, but they were only about $11 each 6 years ago.
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
All 82-92 camaro and firebird are interchangeable, it's just the button color and style thats slightly different. 82-84 firebird is all black, 85-92 firebird is grey. Check out hawks, or ebay.
These are the correct ones, but again, you can use any 82-92 camaro or firebird switch if you're not concerned about originality.
http://www.hawksthirdgenparts.com/fi...dowswitch.aspx
Car: 89 Iroc Convertible
I have those exact switches in both of my irocs.I love the ones that say up/down on them.Problem is I can only touch them on the edges so as not to have the print wear off
I always assumed they were the same, since I've never seen an early Firebird that had anything printed on the switches.
On Probation
Car: 84 Z-28
Engine: 305 HO
Transmission: r-700
Axle/Gears: 3:73
If you don't want to spend the $37 bucks EACH from Hawks you
should check out thirdgen ranch for some used ones cheap!
Look here for $7 bucks each !!!!!!!!!!!!!!
http://thirdgenranch.com/-strse-240/...dow/Detail.bok
I have had good luck for some small part needs reasonable from them.
Ive actually seen those switches in some early camaros 82-83.The early ones have flat ends as opposed to the later style which have an indent and a raised part.Mine were swapped in and are not original to the cars.I have some mint camaro switches in white and yellow but much rather have the up/down ones.All third gen window switches originally came with some sort of print including the 85-92 grey firebird switches.I know most of them had the print fade away from use and its kinda rare to find them used with the print intact like the ones I have
On Probation
Engine: LU5 305 CROSSFIRE
Transmission: TH-350
Axle/Gears: Limited Slip 3:23
I bought new ones for my own 82 T/A from a local Pontiac dealership 2 years ago,Paid $30 for the pair
Dave
Dave
1992 Trans Am
05-10-2023 07:19 PM
colton_carlson
03-08-2019 12:21 PM
The_Phoenix
02-04-2016 07:10 AM
