Converting To A 1LE, Help!
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Hey Everyone,
Ok I currently have a 1991 Z28. Im just wondering what is that I need to convert my car to a 1Le? Any ideas parts that you guys might know of would be helpful.
Thanks. Tony.
Thanks. Tony.
Re: Converting To A 1LE, Help!
Do a search on the History forum for 1LE and you'll get all the differences and you'll know what you need to locate. It's mostly just the brakes.
Engine: 3.0L 2JZGE
I thought the 1LE came with a better suspension. Cause im currently looking in buying a wonder bar since mine dont have one.
Thanks. Tony.
Thanks. Tony.
Engine: 3.0L 2JZGE
I did but I typed something like converting to 1LE. And nothing usefull though.
Tony.
Tony.
What exactly is your goal? If you're just after the increased performance, get yourself an A/C delete pulley, and larger front brakes. That's assuming you already have dual cats, decent gears, and the FE2 suspension. About the only other thing improving performance of 1LEs is potentially weight reduction. Really when you get right down to it, the 1LE option adds bigger front brakes over the top level Camaro. You can get better performance for your money while keeping your air conditioning. A clone is going to be a clone and will probably be worth less then if it were all original, in good clean condition. So why would you really want to clone a 1LE?
Engine: 3.0L 2JZGE
Thanks. Tony.
Engine: 3.0L 2JZGE
Coo. I currently have edelbrock headers, 2 cats and 2 dynomax bullet racemufflers waiting to be thrown on and I already have the A/C delete pulley.
Tony.
Tony.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I got the Baer Brakes...IIRC the "12" Sport" It was a reasonably easy swap, they included spindles, Rotors, Braided hose, Everything I needed except the tools... It made the swap really easy honestly...
The only thing that I remember being a PITA was the brake hose clips... They were a bear to clip on. But I got them with a little persuasion...
Car: '92 Camaro RS
Engine: 305 TBI
Transmission: Richmond Gear street 5 speed
Chevrolet built 478 Z28 Coupes with "1LE" equipment for 1991. As in 1989 and 1990, RPO G92 triggered the build. RPO G92 required one of two engine combinations, the 305ci LB9 V8 with 5-speed manual, or the 350ci B2L V8 with automatic transmission. When ordered with air conditioning, RPO G92 ($466) included engine oil cooler, 4-wheel disc brakes (except for a brief period when 4-wheel discs were deleted with a $287 credit), and dual-converter exhaust. When ordered without air conditioning, RPO G92 ($675) added heavy-duty front brakes, aluminum driveshaft and spare wheel, special shocks and fuel pickup, and gas tank baffle. Fog lamps were deleted for weight savings and improved cooling
http://www.camarosource.ca/php/camar....php?year=1991
this second page is pure 1LE history and data
http://www.camarosource.ca/main_new_...s/rare_1LE.htm
Keep in mind that the majority of those 478 1LE's were installed on the B4C "Special service" typically Police cars...
John
John
Engine: 3.0L 2JZGE
Thanks for all the info peeps.
Thanks. Tony.
Thanks. Tony.
Car: 1992 Camaro Z28 1LE
Transmission: 5-speed
Axle/Gears: G92 Perf. Axle
Is the statement on the Camaro Source page inaccurate in that it should read "478 Camaro coupes" were built with 1LE? Or were 478 Z28s actually built with 1LE, with an additional number of Camaros built as RS/B4C/1LE?
Engine: 3.0L 2JZGE
Hey Everyone,
As far as I know I'm not trying to build a clone thats stu-pid. If I really want an original one well I'll try looking for one I just want the performance most of you guys have directed me to the right sources.
Thanks. Tony.
Thanks. Tony.
If I recall, the B4C and 1LE combo was a 1992 thing, not a 1991 thing. Get your facts straight mister John!!
Car: 87 GTA
For the $ you put in it building a 1LE, you coulda built something better, for the same price, or for just a very few bucks more.
Not to mention, getting some of the 1LE specific parts might be difficult.
Engine: 3.0L 2JZGE
The plan is to build it like as the 1LE I dont want the original parts cause thats gonna be $$$ so yeah. LIke for example if it came with dual piston calipers well I'll get dual piston calipers too as well thats what I mean. Does anyone know of like a part list that these cars had to make them a 1LE?
Thanks. Tony.
Thanks. Tony.
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Look at this website flynbye.com he has the 1LE brake set up and others too and he is in this website too.
Check the link in the first post of the following thread for a how-to on converting to 1LE fronts (It's the one I used). The rest of the thread details converting the rears to the so-called 1LE set-up.
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
Spohn also offers parts and/or a 1LE kit:
http://www.spohn.net/shop/1982-1992-...es-Components/
JamesC
JamesC
Engine: 3.0L 2JZGE
Thank you guys for all the info really appreciate it.
Thanks. Tony.
Thanks. Tony.
Not to hijack the tread but I believe sometime in 91 the B4C cars were switched to include the 1LE options. I know of at least one 91 B4C car w/ 1LE RPO. Can someone confirm? (or should I just do some research myself?)
That is correct. You could get a 91 B4C with or without the 1LE. I have had 3 1991 B4C's. 2 were 1LE cars. The 3rd was not a 1LE and it was a late build car. All 1992 B4C's came with the 1LE.
when i told the dealer what i wanted.. and looked at what the cars came with. and what i was going to do (Drag Race)
the only thing i did was. not order was the 1LE Brakes..
(you could better aftermarket ones).
I orderd My car with
Artic White paint
flame red intr
CD Playr
5.7
700R4
2 cats
4 wheel disc brake
3.73 posi
all the other Z28 ricky race parts.
then about 6 months later it came in.
then 8 months later It was at Lingenfelters
getting the Good stuff..stage 5 383.
all that factry stuff back then was soso.. makes for a nice driver.
but lets face it. when you want to go fast.. anything stock is Just OK.
Add the parts you want.all it is is parts.. you add them now..it's new.
Artic White paint
flame red intr
CD Playr
5.7
700R4
2 cats
4 wheel disc brake
3.73 posi
Car: 87 GTA
With all you changed on a brand new car, you shoulda bought a stripped V6, then sent off to Lingenfelter. Woulda saved you a good bit of change too.
No..
would not be a Z28 (was so glad they stopped the IROC) only 9.000.000 sold...lol
would have not been a true 5.7 car
springs all wrong
cats would not be right.
would not get the exact things i wanted.
i wanted the 25th anvry Z28.
with the lowest gears
and ricky race parts they sold.
a V6 car would cost way to much to try to add a V8 to with all i Had Lingenfelter do.
back in the 90's was running 11.70's and 12.00 without NOS.
turn that on. and 10's it was.. now with up grades we will see. what she will run..
always wanted a Z28 that would run 10's and you can drive on the street.
it's not a V6 car.. Its a true 5.7 Z28 that pulls the wheels. runs in the 10's
and i can drive to anyplace USA..(on a sunny day only) never have driven it in the rain.
alot of guys talk about the 1LE..but lets face it.. what it all comes down to is a tad bit bigger front brakes..on the 92 5.7 cars.
is it cool now...yes..
my 92
5.7 HARD TOP
big swaybars (had them)
4 wheel disk (love mine pizza cutters up front) 1LE..NOPE
2 cats (Had them)
lower gears (i had lower) 9" now
miles on car now 34.000 but its a Hot rod and geting it's 3rd eng.
power seats (had them)
power everything (still have it)
a true Lingenfelter Z28 5.7 Stage 5 car.
some times i see stock Z28's and think for a sec.. thats what i had for a few weeks back in 92...
my 92
5.7 HARD TOP
2 cats (Had them)
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
didn't they have radio and a/c-heater delete?
i read an article in which they had it
not sure.
the only hot rod upgrade would be
No A/C
and Bigger brakes
and 2 cats.
and the 5.7 (305..not so much)
and the larg sway bars.(if your doing the street thing)
not many would keep them without radios.
fog light's.. i added them to my order.(standard)
along with 1 grill painted to match the artic white body color
and the black grill that comes on the Z28.
passed on the stipe thing....had some hand pin stripes and color inlays to the grnd efx.
(wanted it to stand out from any other Z28 at the time..and to this day!
iv had my car now for over 17 years. and would never let it go.. it's my money pit...
No A/C
and Bigger brakes
and 2 cats.
Engine: 3.0L 2JZGE
On my Z I already did the A/C delete well in the process just need to gut the a/s stuff. I have the 2 cats already need to get them installed but I do need a 350 though.
Tony.
Tony.
Car: 1990 IROC-Z 1LE
Engine: 5.7 TPI
Axle/Gears: G92 3.23
If you want to convert your car over to be a true 1LE clone you are going to need to change out all the non-1LE parts. I have a list for you to get started on. Thanks and credit goes out to the guys who used to run 1LE.net. This list was pulled from thier website before it was taken down.
Good luck to you sir:
1988-1992
Fuel tank: 10121026
Fuel sender unit (longer): 25094804
Fuel strainer (double screen): 25121120
Fuel Pump: 25116163
Aluminum driveshaft: 10085375
AC delete pulley: 10115875
Suspension
Front strut: 22064153
Front sway bar (36mm): 14094344
Front sway bar bushing (36mm): 14094388
Front brace (frt end sheet metal radiator opening): 14039401
Front coil spring (code CDB): 14029396
Front steering knuckle LH: 18016737
Front steering knuckle RH:18016738
Rear lower control arm: 10164151
Rear lower control arm bushing: 10164152
Rear shock absorber: 22064149
Rear sway bar (24 mm): 10035033
Rear sway bar bushing (24 mm): 10037105
Rear coil spring (code NNL): 10018091
Brakes
Master brake cylinder: 18014286
Master brake cylinder piston (secondary): 18006832
Proportioning valve (2nd design, 1.5 tube nut threads): 10136840
Proportioning valve (1st design, 1.0 tube nut threads): 14089496
Front caliper bolt: 14084051
Front caliper bracket: 18016034
Front caliper retaining clip: 10132842
Front caliper LH: 10132827
Front caliper RH: 10132828
Front caliper guide pin: 10140666
Front caliper anchor plate LH: 10132829
Front caliper anchor plate RLH: 10132830
Front caliper bolt washer: 14080254
Front caliper hose LH: 10113075
Front caliper hose RH: 10113076
Front brake hose to caliper bolt: 14047782
Front brake hose to caliper bolt washer: 14076180
Front rotor (w/ hub and studs): 18016035
Caliper bleeder cap: 14089150
Front caliper bleeder: 14071826
Front caliper piston: 10104482
Front brake caliper guide pin boot: 14067552
Front hub outer bearing: 457049
Front brake pads: 10104485
Rear caliper plate and bracket bolt: 10112649
Rear caliper guide pin bolt: 14067559
Rear caliper mount bolt: 10097602
Rear caliper housing w/ piston LH: 10132831
Rear caliper housing w/ piston RH: 10132832
Rear caliper guide pin: 14067560
Rear caliper anchor plate: 10112652
Rear brake caliper guide pin boot: 14067552
Rear brake hose: 17688596
Rear brake hose to caliper bolt: 14047782
Rear brake pipe bracket: 10097601
Rear brake hose to caliper bolt washer: 14076180
Rear disk brake mounting plate: 10080876
Rear rotor: 10087702
Rear caliper bleeder cap: 14089150
Rear caliper bleeder: 14081826
Rear caliper piston: 10112643
Rear caliper piston seal: 14067562
Rear brake pads: 10132836
Please keep us updated on your progress
Engine: 3.0L 2JZGE
Hey Krik,
Thanks for the info very usuable information going to copy to my computer.
Thanks. Tony.
Thanks. Tony.
