88 IROC without B4Z on spid.
1 Post
Car: 2003 BMW E46 M3 Vert
Engine: 3.2 I6 M power 333 h.p.
Transmission: SMG 6 speed
Axle/Gears: 3.62 posi
Check out this 88 IROC on ebay. It's doesn't have the B4Z rpo code on the spid. It also has the IROC decal but doesn't have the stripe. B6Q,DX3. It's optioned as close to a 1LE as you can get with out being a 1LE. Very cool. wish I had $18,000. http://cgi.ebay.com/ebaymotors/1988-...item3ef9258574
Car: 88 IROC
Re: 88 IROC without B4Z on spid.
in 88 all Z28's were irocs so the SPID is Z28
Nice car
Nice car
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Not really if its really got only 11k miles on it. He might get that to the right buyer.
Car: 1992 Camaro Z28 1LE
Transmission: 5-speed
Axle/Gears: G92 Perf. Axle
First thing I'd do is lose those yellow plug wires, though. This one should be kept completely original.
Engine: 355 TPI
LOL thats the least of its non-original things. If someone was to put it back they would need to ditch the headers for manifolds again and put the original shifter and rear-end back in. Apparently everything is included though which is funny.
On Probation
The car is all COBBLED up with aftermarket junk and that fool is dreaming
thinking hes gonna get anywhere close to $18k !
Heck..........The 4 mile untouched 85 Z went unsold for what $25k?
Almost identical to mine, only mine has power windows but also for the rest it has all perf. options and only 50K original miles and it's a metric car (km/h speedo and kpa oil press. gauge). I didn't pay anywhere near what that guy is wanting and mine is almost pristine and 100% bone stock.
AR9: SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
A01: WINDOW, TINTED, ALL SHADED, W/S
A31: WINDOW, POWER OPERATED, SIDE
A90: LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
B34: COVERING, FRT FLOOR MATS CARPETED INSERT
B35: COVERING, REAR, FLOOR MATS CARPETED INSERT
B6Q: DECAL PACKAGE, 02
CD4: WIPER SYSTEM WINDSHIELD, PULSE
C41: HVAC SYSTEM, HEATER OUTSIDE AIR, WITH FAN
C49: DEFOGGER, RR WINDOW, ELECTRIC
C95: LAMP, INTR, ROOF, COURTESY AND DUAL READING
D34: MIRROR, VISOR VANITY
D35: MIRROR, OUTSIDE REAR VIEW
D7J: GEAR, SPEEDO DRIVEN
D80: SPOILER, RR END PNL
D88: DECAL, STRIPE, SPORT
E5Z: SPEEDOMETER ADAPTER (DELETE)
E7Z: SENSOR VEH SPD (DELETE)
E9Z: SPEEDOMETER KEY (DELETE)
FE2: SUSPENSION SYSTEM, RIDE HANDLING
GM3: AXLE REAR, 3.45 RATIO
G80: AXLE POSITRACTION, LIMITED SLIP
G92: AXLE REAR RATIO, PERFORMANCE
J65: BRAKE SYSTEM, PWR, FRT & RR DISC
KC4: COOLING SYSTEM, ENG OIL
K68: GENERATOR,105 AMP
LB9: ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
MK6: TRANSMISSION, MAN 5 SPD, B0RG WARNER, 2.95 1ST, O/D
MM5: MERCHANDISED TRANS, MAN 5 SPD PROVISIONS
NA5: EMISSION SYSTEM, FEDERAL, TIER O
NP5: LEATHER WRAPPED, STEERING WHEEL AND SHIFT ****
N33: STEERING COLUMN, TILT TYPE
N65: WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
N96: WHEEL, 16 X 8, CAST ALUMINUM
PB4: LOCK CONTROL, WHEEL
QDZ: TIRE ALL, P245/50VR16/N BL R/PE ST TL HW4
TR9: LAMP, GROUP
TT4: HEADLAMPS, HALOGEN, 4
T93: TAIL & STOP LAMP, SMOKED
T96: LAMP, FOG
UM6: RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV CASS,
UQ1: RADIO PROVISIONS, FOR STEREO
U25: LAMP, INTR, RR COMPT, COURTESY
U26: LAMP, INTR, ENG COMPT, COURTESY
U29: LAMP, INTR I/P, COURTESY
U79: SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
VAN: ASSEMBLY PLANT, VAN NUYS, CA
VK3: LICENSE PLATE, FRT MOUNTING PKG
V73: ANTENNA, FIXED
WW1: APPEARANCE PACKAGE(WHITE), AERO #l
W62: ORNAMENTATION, AERO PACKAGE
X06: CANADIAN GROUP
Z28: MERCHANDISED PKG, SPECIAL PERFORMANCE
Z31: ADVANCE PRICE SHEET
Z49: EXPORT, CANADIAN MODIF MANDATORY BASE EOUIP
15P: WHEEL COLOR SILVER METALLIC (91)
40U: PRIMARY COLOR, EXTERIOR, WHITE (91)
6DB: SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7DB: SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
8NL: SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
82B: TRIM COMBINATION, CLOTH, MED DK GRAY (91)
82I: INTERIOR TRIM, MED DK GRAY (91)
829: SEAT BELT COLOR, MED DK GRAY (91)
9NL: COMPUTER SELECTED REAR RIGHTHAND SPRING
90A: STRIPE COLOR, ACCENT, TWO TONE
TR9: LAMP, GROUP
T96: LAMP, FOG
V73: ANTENNA, FIXED
X06: CANADIAN GROUP
I guess I should learn to read -- I missed the headers, shifter and non-original rear. I stand corrected!
mustangman65_79
08-11-2015 03:17 PM
