Chevy vs Ford. old vs new
Old 09-01-2009 | 02:51 PM
mr396's Avatar
Car: 2003 BMW E46 M3 Vert
Engine: 3.2 I6 M power 333 h.p.
Transmission: SMG 6 speed
Axle/Gears: 3.62 posi
This comes from the march 1992 MuscleCar review. I think the IROC would have won it all if they had used a G92.
Attached Thumbnails Chevy vs Ford. old vs new-scan0216-large-.jpg   Chevy vs Ford. old vs new-scan0217-large-.jpg
Old 09-01-2009 | 02:53 PM
mr396's Avatar
Re: Chevy vs Ford. old vs new
pg 3&4
Attached Thumbnails Chevy vs Ford. old vs new-scan0218-large-.jpg   Chevy vs Ford. old vs new-scan0219-large-.jpg
Old 09-01-2009 | 02:55 PM
mr396's Avatar
pg 5&6
Attached Thumbnails Chevy vs Ford. old vs new-scan0220-large-.jpg   Chevy vs Ford. old vs new-scan0221-large-.jpg
Old 09-01-2009 | 02:57 PM
mr396's Avatar
last 2
Attached Thumbnails Chevy vs Ford. old vs new-scan0222-large-.jpg   Chevy vs Ford. old vs new-scan0223-large-.jpg
Old 09-01-2009 | 05:47 PM
TOM-1LE's Avatar
Car: 1992 Camaro Z28 1LE
Transmission: 5-speed
Axle/Gears: G92 Perf. Axle
This test is entertaining (thanks again mr396), but like most articles, it is suspect in a lot of ways and contains inaccuracies.
First, why did they select automatics for the new cars, when the old cars were equipped with manuals? What a handicap. It is well known in 5.0 Mustang circles that equipping a Fox-body with a stock AOD adds nearly a second to its quarter-mile time versus a 5-speed.
Second, as mr396 pointed out, why not use better version of the Camaro -- either a G92/5-speed version or an L98? Why complain about the braking when the test car didn't even have rear disc brakes? Is 3.08 the correct gear ratio for a 305/auto Z28? Wouldn't it be a 2.73?
Finally, 15" wheels are not correct for a '91 Mustang, despite what the article says. Those 10-hole wheels were last used on the 5.0 in 1990. In 1991 the Mustang upgraded to 16" wheels and tires. And 3.08 is the gear ratio for a 5-speed Mustang, not an automatic (with auto it would be either a 2.73 or a 3.27).
While I agree with some of their conclusions, articles like this add to the misinformation that's out there about our cars. I think the MCR folks should stick to writing about 1960s cars...
Old 09-01-2009 | 06:46 PM
aciddrop2804's Avatar
Car: 1984 camaro Z28
Engine: 5.0L H.O. L69
I agree,they should have used manuals and done more than 2 runs each, just to ake sure they got the best possible numbers for each car. I think they used auto's though just for the sake of equality as it seemed they were more comparing the 91's aginst each other more than the old z and boss.
and again, i think they didn't use the G92 or l98 because they were comparing base 5.0 with base 5.0
Old 09-01-2009 | 07:31 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
They can use base 5.0 to base 5.0 and be closer across the board. The gears in a 69 Z28 would be 3.73 or 4.10s and would have had manual only. They could've gotten a 1991 Z28 with the 5.0, 3.42 gears and manual and it would've been closer to the 69 in configuration. The same goes for the Mustang. As was said, give the 91 a 5 speed and the correct 16" wheels, the numbers would be more realistic of what they can do. The 91 Z would've have ben a top performer with much better numbers.
Old 09-03-2009 | 06:13 AM
tekkitan's Avatar
Car: 87 IROC-Z
Anyone else not able to see the attachments?
Old 09-03-2009 | 06:53 AM
subroc's Avatar
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Yup they are not working for me either.
Old 09-03-2009 | 11:07 AM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
Same here. I would really like to read that article
Old 09-03-2009 | 06:36 PM
mr396's Avatar
I can't see it anymore either. What happened?
Old 09-03-2009 | 06:37 PM
mr396's Avatar
I'll post them again if they don't come back.
Old 09-09-2009 | 03:39 PM
mr396's Avatar
123
Attached Thumbnails Chevy vs Ford. old vs new-fc-large-.jpg   Chevy vs Ford. old vs new-fc7-large-.jpg   Chevy vs Ford. old vs new-fc1-large-.jpg
Old 09-09-2009 | 03:42 PM
mr396's Avatar
4,5&6
Attached Thumbnails Chevy vs Ford. old vs new-fc3-large-.jpg   Chevy vs Ford. old vs new-fc4-large-.jpg   Chevy vs Ford. old vs new-fc5-large-.jpg
Old 09-09-2009 | 03:43 PM
mr396's Avatar
last one
Old 09-09-2009 | 05:11 PM
vette9190's Avatar
you forgot a page. Page 17 is missing. But so far pretty good read
Old 09-09-2009 | 05:48 PM
mr396's Avatar
Here it is.
Old 09-09-2009 | 05:52 PM
subroc's Avatar
Engine: 355 TPI
Interesting. Thanks for posting it up again. I found it amusing that even though both camaros did slightly worse than both mustangs, that the driver preferred the feel of the camaros to the mustangs. Slight chevy bias maybe...
Old 09-09-2009 | 06:11 PM
mr396's Avatar
I just noticed they pitted a 69 Z/28 with the 4-speed and 3.73 gears and the 70 boss with 4-speed and 4.11's, pretty much the top of the line. The 91 Z28 had a A4 and 3.08 gears. To me that just makes the 91 Z28 more impressive.
1Aauto
Sponsored Vendors
10-19-2016 09:50 AM
z28venezuela
10-24-2015 09:15 PM
1Aauto
Sponsored Vendors
10-13-2015 04:06 PM
1Aauto
Sponsored Vendors
09-10-2015 03:02 PM
1Aauto
Sponsored Vendors
09-02-2015 02:35 PM
