**Project PITA** 86 TA frame up restoration
#1651
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Re: **Project PITA** 86 TA frame up restoration
#1653
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Thanks guys! And as far as weight...weight reduction is a pretty important topic when building a fast car. My car makes the HP to be pretty fast regardless, but I have been trying to drop weight here and there to squeeze every last bit of performance out of her. For instance, one of the main reasons for buying these wheels is that they way a measly 17 lbs each over the previous chrome wheels which were 32 lbs each!! Multiply that by 4 and I'm dropping over 50 lbs in not only weight, but rotational mass none the less. It should be a huge difference in acceleration, braking, and turning.
#1654
Or better yet, go all fiberglass. May not be street legal, but you'll achieve wieght reduction in the masses.
http://www.vfnfiberglass.com/8292camaro.htm
#1655
Car: 1986 Trans am
Engine: 5.3 LM7
In that case, dump the glass t-tops and get lexan. A plus would be a fiberglass hood and fiberglass fenders/bumper cover. That'll shed a lot more weight. But there will be more modifications needed with the fiberglass front end.
#1656
Well...I should have said I'm trying to drop weight "to a certain extent." It is a street car after all, so I like the clearness and durability of my glass T-tops. As far as the hood, it was something I thought about off and on before the car was painted, but honestly I just can't tolerate the horrendous fit and finish of most fiberglass hoods so I kept my stocker. I just really hate fiberglass stuff on a street car. The factory parts will always fit 100x better. As it is, I believe the car should be down to about the 3350-3375 lbs range even with the added turbo weight with what I've done. Still a pretty light street car all things considered. I plan on getting it on a real scale this summer to find out for sure!
#1658
Car: 1983 Crossfire Recaro T/A
Engine: 5.0L Crossfire
Transmission: Upgraded 700R4
Axle/Gears: 3:23
You have one sweet ride and that smile you get every time you see it and drive it is worth it!
#1659
Car: 1986 Trans am
Engine: 5.3 LM7
I honestly love the car so much that I don't even think about the money invested, unless it's brought up like that. It was a great experience, and I get to have a car I can enjoy and be proud of now!
#1661
Car: 1985 Trans am
Engine: 355ci, 91 TPI set up.
Whoa that's a lot of money!!! But realistically, all things considered, your car is going to last you YEARS man. Not to mention, you won't find anything faster, sexier, or more suited to you anywhere out there. You couldn't simply go out and BUY what you have here - not for the same amount anyways! You're getting your moneys worth with every shift you make, and every in of rubber burnt =) Thats how I'd be looking at it anyways
#1662
Car: 1989 IROC-Z
Engine: 355, 6.0 (LQ4) soon
Axle/Gears: Borg Warner 2.77 for now
#1663
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
I personally wouldn't answer a question about what i have " invested" in a car, unless it was a real close friend....these projects are not about making money....not even about breaking even...it's more about following your dream to reality....and that almost always cost more than what you could sell it for...I've done it plenty of times in recent years. I won't even add up how much i've spent on any particular project anymore, because it will ALWAYS be more than what i thought i spent! Enjoy the car! it looks awesome!
#1664
Just saying.
#1665
Car: 87 Pontiac Trans Am
Engine: Lapouttre Racing 350
Transmission: Rebuilt 700r4 Mild shift kit
Axle/Gears: 10 bolt 3.23 posi w/disc brakes
The only time I think about how much I have invested in my build is when I run out of money to put into it hahahaha.
#1666
Car: 1986 Trans am
Engine: 5.3 LM7
Looking at your lower sig pic is funny because I remember a time where my car was in the EXACT same state LOL! Looks like it's coming along nicely.
#1667
Car: 1989 IROC-Z
#1668
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 2.77
What was the round about cost to soda blast? I don't think 4 years later will make a big diff. Thanks-Jimmy Nice Work BTW, Inspiration!
#1669
Car: 1986 Trans am
Engine: 5.3 LM7
Thank you Jimmy! Round about cost for everything I'd say was right up around $850-1000. And that is everything...inside and outside of doors, chassis, engine bay, both sides of hood, etc. The local guy that did it is great to work with and once I kept coming back, he eased up on pricing for me.
#1670
Car: 1986 Trans am
Engine: 5.3 LM7
Finally had the car out with the new weld RT-S wheels on it this weekend and snapped a few good shots for you all. BIG difference in both looks and traction over the old blinging 18's lol. These wheels really set the car off and bring it all together, and I couldn't be happier with them! The traction now is amazing, and the car will bite even in 1st gear. It's so nice to be able to use the power now!
And a little vid of me using my new found traction against a modded honda CBR 600 RR bike.
I didn't brake boost the car on the start even though I should have, because it would have helped me out a bit. But oh well, the guys a buddy of mine, and we can always line up again!
#1671
Car: 2000 TRANS AM
Engine: H,C,I LS1
Axle/Gears: 3.42 posi
you Sir, have one beautiful car. love the color and wheels.
makes me wanna sell my 4th gen and go back to a third gen. i miss my 91 formula
maybe when i get stationed in indiana i can start a build of my own lol.
#1672
Car: '84 Firebird
Transmission: 700r4 with kit
Axle/Gears: BW 3.73 Posi
The rims & tires look great. What size tire did you go with? I ordered a staggered set of Boss 338s for my car and ended up returning the rears because it just didn't look right, but yours look great.
#1673
Car: 1986 Trans am
Engine: 5.3 LM7
Went with a 275/40/17 in the front, and a big 295/45/17 in the rear. They hook awesome on the street! And thank you!
#1674
Car: 1984 Camaro Sport Coupe
Engine: RHS/LSx 427
Transmission: Powerglide
Axle/Gears: Fab9 3.00 gears
I just read through 34 pages of this thread and wanted to thank you for being so painfully thorough in documenting your build. This thread will be an invaluable resource for those of us that are crazy enough to follow in your footsteps
It just kills me that I'm only just beginning on mine and have so far to go
#1675
Car: 1989 Trans Am WS6
Engine: SBC+TPI+BOOST
Axle/Gears: Eaton 373
The rim change just made me fall for youre car.. Wasnt crazy about the "Bling". Now it really looks Killer!
#1677
Car: 1989 GTA WS6
Engine: 5.7L TPI
Axle/Gears: Borg 3.27
Any updates on your T/A? Hows it running, any awards, any loss of traction( new tires needed because of burnouts)?
#1678
Car: 1986 Trans am
Engine: 5.3 LM7
The car is doing great! Been driving it a ton when I can, and have just over 2K miles on it since finishing the build. I'd love to drive it more, but I have been constantly improving things with it and it has taken some time to get perfected. It currently has a completely re-designed turbo setup on it since the old one was not ideal. I'll have to get some new pics up. I also won a huge trophy for 1st place in the firebird class at a car show that had over 600 cars. I was stoked about that one! Like I said, I'll have to take some recent pics and post them up, but the car is doing excellent and I am loving every minute of driving it!
#1679
Car: 1986 Trans am
Engine: 5.3 LM7
This is the official photo taken when I received the trophy. This cruise is the largest weekly cruise in New England and will get anywhere from 500 to over 900 cars, and it's held every Monday throughout the summer. People drive from as far as northern MA and NY to come to this show. I won on the official firebird night for best bird. There was probably a total of 500 cars, and 50 or so birds there, and all different generations too....and a third gen won! This is also the first third gen bird to EVER win a trophy at this show since it started, so that alone made me feel pretty freaking awesome! I have been going to this show for the 10 years I've owned my car and honestly this was one of the single most gratifying things that has happened since completing the car!
#1680
Car: 1986 Trans am
Engine: 5.3 LM7
I also ended up completely redesigning the turbo setup. The old one had flaws here and there and the mild steel manifolds kept cracking every few hundred miles. This is turbo setup 2.0, and is worlds above the old design! A few problem areas and flaws I address this time around were...
-Cast iron exhaust manifolds instead of mild steel
-All SS piping for merge and downpipe to hold up better to the heat
-Much more high flow merge pipe and junction where the turbo bolts up - this resulted in decreasing spool time by a full 500 RPM!! I get the full 11 psi now by 3200-3300 rpm.
-Aluminum charge piping instead of the previous steel. This way it doesn't heat soak as much and is lighter in weight.
-Inlet pipe into the throttle body has been moved to the drivers side so that it does not have to travel above the turbo exhaust housing and get heated up.
I have put about 1000 miles on this new setup with lots of abuse and it has help up flawlessly so far. It is so much better flowing that it actually completely changed the pitch of the exhaust note too, and the car sounds like a C5 vette now while cruising. I'll try to get a sound clip up, but for now heres a few pics!
During merge pipe assembly
Closeup of the merge transition into the turbo. LEAGUES above the old design.
Newly designed downpipe with heavy duty flex pipe
And the finished product!
This new setup put down 540 rwhp and 522 rwtq on just 15* timing and a relatively conservative 11.4 AFR. For reference, the old junk setup made 563 rwhp and 546 rwtq at 23* of timing and a very lean 12.3 AFR. Basically on the edge of destruction, where as this setup is only 23 HP down on a hugely more conservative tune! I am very happy with it, and plan on adding boost soon once I get one more thing situated.
#1682
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Looks great. That trophy was well deserved!
#1683
I do believe your Bird is the cleanest third gen I have ever seen. Beautiful.
Congratulations on winning the trophy.
That's awesome.
Man I've just done a suspension swap and battery relo and some other stuff and currently doing heads/cam, and this has been a big enough PITA for me.
It IS a fourth gen, though, which makes it a bit harder in some areas.
Great job on your car!
That's awesome.
#1684
Got a little more work done over the weekend. I cleaned up my interior heater/flapper box assembly and reinstalled that as well as installed the heater box in the engine bay. Also got my LS1 master cylinder and wet sanded and detailed my brake calipers.
All new weather stripping on heater box
And my new LS1 master. It's quite a bit smaller than the fatory one and extra room is always nice in the engine bay. Plus the reservoir looks 100 times better!
#1687
Car: '84 Firebird
Congrtas a winning Bud. You definitely deserve it. I would nominate you for the COTM but you already won that one. Maybe next year I will bring my Bird to the firebird night. I ended up pretty good this year at the shows also. I got a first place, two top 10s, and a top 25. She is away for the winter already and I miss driving her. Hopefully we can hook up next year because I really want to see your car.
#1688
Car: 1986 Trans am
Engine: 5.3 LM7
#1689
Car: 1986 Trans am
Engine: 5.3 LM7
Haven't been on here in some time. Figured my newest news was worth a mention though. After almost a full year of talking back and forth, photo shoots, and lots of conversation, I scored a feature spot in GM High Tech Performance magazine! Not only that, but the editor felt my car was worthy enough of the front cover as well.
I also got this reeeeeaaaaally fancy plaque made.
I accomplished not only one, but both huge goals I set for myself with this car. One was to take home a trophy at the big Mark's cruise night show, and the other was to get a feature in GMHTP magazine. I am blown away that I made the cover and really couldn't have asked for anything more. Now the one thing left is to drive the pants off this car for years to come!
#1691
Car: '84 Firebird
Congrats Bud... Well deserved.
#1696
Car: 1986 Trans am
Engine: 5.3 LM7
Thanks a lot everyone. Every single compliment I get still means a ton to me, and I've probably mentioned this before, but doing this build thread was one of the most fun things I've ever done car related. I have been at an all time high with the mag feature and all, but I always think back to this build thread and remember where it all started. Sometimes I almost think I was crazy for taking this project on LOL! All worth it in the end though.
#1698
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
yeah I got mine this month and I was like heyyy I know that car lol. congrats on the feature, it is well deserved
#1699
Car: 1991 Z-28
Engine: 383 TPI
That's awesome! You earned that cover spot and article! Congrats!
#1700
Beautiful car! Very nicely done.
I await the day my 86 T/A is at least running and just repainted...
