**Project PITA** 86 TA frame up restoration
#1251
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Re: **Project PITA** 86 TA frame up restoration
Rob, that looks SICK, and just in time to be tearing up the streets of CT. Spring is VERY CLOSE.
#1252
Car: 88' White-Black Trans Am
Engine: Trying to find a motor
SO rob when am i dropping mine off? I need a ton of body work done.Mines been wrecked by the PO 3 times. He was a drunk driver in 2 of them. Haha.
#1253
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
You don't want me doing bodywork, trust me! Mechanical work, that I can handle. And sounds like the PO of your car didn't deserve to own it, jeez!
#1254
Haha aw man!): I need a whole new driver side quarter for sure,the rest is just a ton of top coat and sanding! And yeah he was a *Insert every swear word in the book here*
Haha
Haha
#1255
Car: 1986 Trans am
Engine: 5.3 LM7
It was GORGEOUS here in CT today...74 degrees to be exact. Got the trans am pushed outside and got some "warm weather" work done on it. I noticed the the inside bottoms of the doors had a very small amount of surface rust in one or two places. When they were soda blasted, they blasted the bottoms of the doors, but the painter couldn't get into them to paint them. I didn't even notice until recently so I decided to coat the doors inside with some rubberized undercoat. I would NOT want them rusting from the bottoms a year or so down the road! Made sure to mask every little hole off and gave them a good coating. Heres a couple pics..
Came out very nice and I got absolutely no unwanted overspray on anything thank god! Shouldn't rust now for a long time!
Also finally got the IAT sensor mounted since I didn't own a step drill bit to make the hole previously. Went to good old harbor freight to get a cheap one and it worked great.
And a few outside glory shots of the rear of the car together lol...sorry, sun was going down at this point!
#1256
Car: 1988 Firebird
Transmission: 6-speed
Axle/Gears: 2001 ss 10 bolt 342's
Damn man, your almost ready to do MY car .... but seriously, looking great as usual.
#1258
Car: 1986 Trans am
Engine: 5.3 LM7
It's not staying, don't worry. It's a temporary one I borrowed from my brother just to get the car running until I bought a brand new one. It'll be replaced before the tune.
#1259
#1260
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
I was thinking the same thing. Are you putting a spoiler on the back? That is such an awesome color!
#1262
Car: 1986 Trans am
Engine: 5.3 LM7
Yes, it's gotta have a spoiler to be a trans am! LOL, I have a factory 91-92 style wrap around spoiler going on whenever the painter gets it done. Can't wait to see the back end once it's on!
#1263
Engine: cammed LS1
Yes, that's true! Haha. I just wanted to make sure
#1264
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Subscribed!
It took me over a week to read this entire thread, bit by bit, after work every day. The level of detail in this thread is wonderful. I got so many good ideas for the chassis and body for my own upcoming projects, I really appreciate that you shared the details with us all.
Great work, man!
Great work, man!
#1265
Car: 1986 Trans am
Engine: 5.3 LM7
Bit more progress done! PCV catch can setup is almost fully done, and I got the window sweep weatherstrips today so I got the drivers side on. Will be doing the pass side tomorrow. Couple pics...
Heres the RX performance catch can mounted in the drivers side battery tray.
Heres the lines for the catch can. One runs to the intake manifold, and the other runs to the back port on the drivers side valve cover. There will be one more running to the turbo intake once I make it. The catch can has check valves that close off with positive pressure, so that it will have a vacuum source regardless of the engine being in boost or not.
Window sweep on
And now with the mirror back on as well! Also got the lower side skirt on the door while I was at it. Looking like a car slowly but surely.
Window sweep on
#1266
Car: 89 Formula
Axle/Gears: 10 bolt 2.73
i have been watching this for quite some time.. its going to be hard seeing this come to an end.. she is just gorgeous by the way. i dont think any of us could say it enough on here.. so nice
#1268
Engine: 4++,350 & 305 CIs
If its going to be a cruiser, enjoy your fine looking machine !!!
#1269
Car: 1986 Trans am
Engine: 5.3 LM7
I plan on taking it to 140 mph+ but not too often. For what I'm building it for, the 91-92 spoikler should be ok. With my suspension and tires it should be fine. Thanks for that info though! I'm not too up to date with how the different spoilers affect it.
#1270
I also talked with Jim Mattison a few times at the T/A nats about the wings and he confirmed what I found and what I'm telling you.(his son raced 91-2 formulas, semi factory backed, they added a crude lip to the rear of the wing to create downforce). I have a pic of them, they also did it to the racecar Hawks and even Bonneville 3rdgens use the older wing.
I'm not trying to tell you you have to but if you wana drive fast keep it under 140mph unless you go with the older wing..
The 91-2 wing, looks nice but its functionality sucks.
#1271
Engine: cammed LS1
Good information TTOP. What about the fourth gen rear spoiler? Do you have any info on that. Sorry, not trying to hi-jack your thread. I'm just curious.
#1272
Anytime the top side of the wing is longer than the bottom side your going to have lift.
#1273
Car: 1986 Trans am
Engine: 5.3 LM7
TTop, I'll def keep that in mind. This car is mainly going to be a street/cruiser car so I'm not too worried about it at this point in time. If the car does start to feel loose when taking it up to speed once in a while, I will think about my options. I can't see myself going much above 130 or so any more than 2 times a year, if that. And it'll just be those "in the moment" times haha.
#1274
You have a bunch of time and money in your car and I don't want to see it (or any other cars) wadded up at all !
#1275
Car: 1986 Trans am
Engine: 5.3 LM7
OBD 2 anyone? Finally got the diagnostic port wires extended today and mounted it right where the factory OBD 1 port use to be. Also played with my side windows a bit to try to get them adjusted a little better. Made some progress on them, but man I am getting ready to smash them! These windows have got to be by far the worst ones out of any other type of car to adjust!!
OBD 2 port
OBD 2 port
#1278
Car: 1985 Trans am
Engine: 355ci, 91 TPI set up.
Can I say... W O W! Cannot wait to see all the body bad together, looks seriously bad a$$ even just the way it is! I can't even express how jelous I am of the patience you must have had for all the details you've put into this beast. b-e-autiful! Exellent job!! Been following every step of the way, a huge inspiration, and all the rest! =D
#1279
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
was that ls1 brake mc a direct fit? how does your pedal feel? supposedly those help get rid of the spongy pedal.
#1280
Car: 1986 Trans am
Engine: 5.3 LM7
Yup, direct fit. Honestly, I didn't notice a very big difference, but then again, the car has been down for a while. The pedal is definately very firm, but my old one felt pretty good as well. I just really like the way this one looks over the stock setup!
#1282
Car: 1986 Trans am
Engine: 5.3 LM7
I know, I appologize haha. I just got a job which I start monday so I have had a week of hold time on the car. Between interviews and paperwork, I couldn't get much done. That and I just don't have the money yet to get the rest of the body parts from the painter, since it's going to be a bit more than I originally thought. I'm thinking in another week or so you'll see some big progress!
#1283
Car: 1984 firebird trans am
Engine: 383 stroker
Transmission: th350
Axle/Gears: 10 bolt posi with 373 ring and pini
Man what a car i just spent the last 3 hres reading everything and al i got to say is i cant wait to do my 84 firebird im planing on a ls1 swap in mine?
#1284
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I've been following this thread for awhile and I must say I'm totally impressed with the lengths you've gone to restore this beauty. Quick question what is required and how did you rebuild the insides of the doors, Mine rattle badly when the door closes and when i hit bumps in the road. Sounds like things are loose or the rails are deteriorated. Any advice would appreciated. Thanks, and once again great job.
#1285
Car: 1986 Trans am
Engine: 5.3 LM7
#1286
Car: 1986 Trans am
Engine: 5.3 LM7
I'll hopefully have some pics for you guys this coming weekend. I have been working now (thank god!!) so obviously my time has been cut down quite a bit. Good news is that I just met up with the painter and left him a chunk of money towards the rest of the paintjob. He promises I should have the fenders and sideskirts by this coming friday, so MAYBE I'll have a few pics of it looking like a car! Not much left to do, and the tune date is scheduled for the 21'st. Hang in there guys...soon enough!
#1287
Car: 1991 Firebird
Engine: 3.1L V6
Awesome job Rob. That is a lot of time and money put into the car. I will definately refer back to this thread for any future restoration or swaps I may do.
#1288
Car: 1986 Trans-Am
Engine: 305 5.0 TPI
Transmission: 700 R4
Axle/Gears: 2.73 posi
I just read this entire thread and all I can say is WOW!!! Makes me wish I had a garage to tear mine apart and do a total rebuild.
#1289
Car: 1986 Trans am
Engine: 5.3 LM7
Sorry for the extremely long down time, but it was well worth it. Here she is with fenders FINALLY!!
Couple sunlight beauty shots
Heres a shot with the side vent installed.
And the overall shot. Got the sideskirts as well so those should be going on tomorrow!
Also ordered my 80 lbs fuel injectors so when I get them, it's tune time. Have a date scheduled for April 21st. We'll see what the old 5.3 puts down finally! I'll get some more pics up tomorrow with the sideskirts installed.
#1290
Car: 89 Formula
that looks AMAZING!! congratulations on the entire car man! that looks awesome but i must ask you, i know you might have it else where in the thread but what kind of rims are they? they look absolutely gorgeous on your trans am
#1291
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
man you are really making me rethink my paint scheme for my ta.. looks amazing
#1293
Car: 1986 Trans am
Engine: 5.3 LM7
Thanks a lot...I really appreciate it guys. Means a lot to me when people can understand the time, money, and headaches into a project like this
#1294
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
WOW! Definitely worth the wait. But we need MOAR!!! Spoiler, side skirts and bumper. Hood....eh whatever about the hood. LOL. Looking forward to seeing the completed product.
#1295
Car: 84 Trans AM (sold), 87 IROC, 09 C6
Engine: Lt1 in IROC
Transmission: 5 speeds
Axle/Gears: Moser 12 bolt tru tracker 3.42
nice paint match on the fenders. were they painted the same time as the body?
#1296
Car: 1988 Iroc
Engine: 5.7L
SWEET rob. It looks amazing. Part of me kinda likes the non spoiler look. only 2 weeks before you see what that beast puts down, im glad I will be there to witness it.
On the way back from the dyno, we should do a run. Ill ride the brake so its fair for you!
#1298
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
They are a labor of love, your car is looking great, I cannot wait to drop my motor in. I went the other direction with the Paxton SC
#1299
Car: 1986 Trans am
Engine: 5.3 LM7
Superchargers are cool too. I would love to build a supercharged motor at some point too, but can't see changing this setup. I'm hoping my brother will do a roots blower on his 5.3 swap 91 bird project so that we can see what each feels like.
#1300
Engine: 2.8/TBI/TPI
Beautiful job. I can't wait to see the rest of it bolted together and road worthy.
Truly inspiring!
Truly inspiring!
