**Project PITA** 86 TA frame up restoration
#551
1 Post
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
Re: **Project PITA** 86 TA frame up restoration
I've been meaning to ask. What kinda paint is that? I like how it turned out and would like to do the same.. y didn't u cover the floors in the dyno matting instead of just patches?
#552
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
Really? WOW thats terrible!! we have a very strong muscle car scene here in CT but I can imagine that if people had to pass emissions in a 75 or newer car we would have a lot less muscle cars lol. MA just passed a law stating that no car OBD1 or older has to go through emmissions which means only 96 and up cars need a sniff test! IMO though emmission tests are BS. My brothers carbed 350 with heads and a huge cam as well as a holley 750 carb passed WITHOUT a cat....no detuning or anything, yet they'll still fail it for not having a cat in place. Honestly if a car can pass, why is it a necesity to have a cat? Such a corrupt test.
A lot of older cars get junked around here because people don't want to try and have to tune up the car so that it can pass smog. I think the only reason I passed last time was because the person put me as a 3.1L instead of a 5L while testing
#553
By mistake or to help a guy out?
#554
Car: 1991 Z28
Probably to help me out because I had already gone through 5 times and I was way off. So then I went through a sixth time and he said I passed. I looked at the little sheet and it said 3.1L. The guy was cool and liked the car so I think he probably rigged it.
This was bad when I first got the car though and needed to get it plated for Oregon (it was originally a Washington car). Since then I've stopped all the vacuum leaks, replaced the EGR (the wrong one was on the car when I got it) and have done a ton of tuning up. I think it should pass this time no problem.
#555
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
And the 2nd reason was that I am trying to make a nice balance of sound dampening and weight savings. If I were to completely cover the floor I would easily add double the weight of the amount of dynamat thats on there now. I'm sure the car will drive much quieter than stock since there was nothing originally from the factory there!
#556
Car: 1991 Chevy Camaro RS w/t-tops
Engine: BBC 396 .090 over (414)
Transmission: LS1 T-56
Axle/Gears: Shortened Ford 9, 3.25, discs, posi
Not to be nosy, but I am, I'm gonna be dynomatting soon... how much did all yours set you back? and how much of what kind did you get? I kinda remeber there being multiple kinds on the summit website. I may be wrong but w/e
#557
If your talking about the black paint on the floors then it's "SEM chassis coat black." Great stuff and it gets nice and hard like POR15. As for the lack of full coverage on the floors with the dynamat, it's because of 2 things. First, I read online in a few places that you do not need to cover anywhere near the entire floor to get the same results as if the floor was completely covered. You only need to cover the flat areas since the areas with sharp edges and/or multiple layers of metal don't need dampening since there is little to no flexing in those areas (IE where the seat bracing is).
Pretty sure I have narrowed down that issue to the window/t-top weatherstripping, its kind of messed up on the corner and I believe thats where I was leaking a bit of water.
#558
Car: 1986 Trans am
Engine: 5.3 LM7
Heres the title along with the part number for the ebay ad I bought mine on. Sellers name was "webdealin." In the quantity, I entered 2 packs but I havn't even gotten through the first one yet on what you see on my car so far (have 2 full sheets left).
Dynamat 10455 Xtreme Car Audio Bulk Pack 9 Sheets NEW
If you just had carpet then probably someone pulled out the matting, my car had rubber backed carpet and a layer of matting under that, pretty much the same stuff used under house carpets, probably shed 20-50 lbs between the two of them, granted some areas were like...frozen to the floor
#559
Ok, sweet. I've gotten a lot of quality stuff on ebay but since I live 5 mins from the Summit HQ in Tallmadge, OH I usually just go buy it right from the store since its a sweet place to kill time, and money. Someone always has a project out there....
#561
Car: 1986 Trans am
Engine: 5.3 LM7
I didn't weld anything on the car, but if you mean the seam sealer that I used on the factory sheet metal seam areas, then it was 3M I believe. I'm honestly not sure what it was called. I just go to the body supply store by me and tell them what I'm doing and they hand me a product lol. They know they're stuff though.
#562
Car: 1986 Trans am
Engine: 5.3 LM7
Got some more dynamating done today and also got new gaskets and all the hardware to put my LS6 intake on. No pics of the dynamat yet but heres a few of the intake. Should be getting my chassis harness sometime by the end of next week and then the fun begins, lol.
I will be selling kits of all the upper LSx engine bolts as well (fuel rail, throttle body, manifold) so if anyone needs anything let me know!
#563
I'm gettin excited..... hahaha. I'm at like the same stage on my camaro. its to the point where I'm so anxious to get it drivable and fry some tires off. I spin em in my civic...when its wet. its just not even close to being the same
#564
Car: 1991 Z28
Your engine is looking really good! I'm not a huge fan of the LS engines but yours sure is clean looking.
Your whole car looks great. I can't wait to see what the finished project looks like
#565
Car: 1986 Trans am
Engine: 5.3 LM7
And as an update, I am VERY happy to say that dynamat is completely finished except for a few small patches on the doors that I will be doing. I have to admit, it was not enjoyable at all to put that stuff in but the whole car just seems so much more solid and the metal does not "tang" at all when you knock on it as opposed to before. I think it will be a noticable in-car difference from stock, especially combined with the neoprene padding. Also bolted in one of my Corbeau LG1 seats just to get a feel of the seating position and i LOVE it. Very comfortable seat and it looks awesome in the car. Heres a few pics.
#567
Hey, man my hat is definitely off to you... been following this since day one.
Question: You involved in aviation? I am a licensed A/P, and my specialty is avionics. You have a safety streamer hanging from the steering wheel that looks like the ones we used to hang from pitot tubes.
#568
Car: 1986 Trans am
Engine: 5.3 LM7
#569
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
Nice to see it coming along. If I'm in CT maybe I'll see your car running around if I'm lucky. NJ has the same deal with inspections, at least with QQ plates. If you have QQ plates on the car then it doesn't matter they don't inspect it. But the catch is you're not supposed to drive it daily. I had no intention of driving my TA daily except in the summer on nice days. Longer trips I'll do too. I agree with what was said on the previous page. If a car passes the sniffer test then it should pass no matter what it has. Hell...I bet your car will blow cleaner than stock with the newer motor lol.
#570
1 Post
Car: 1990 Firebird
Allow me to give you your 1,001st compliment. Amazing job. It is nice to see someone doing the job right and with great detail. I hope to do the same to my Firebird eventually. I'm envious of your garage. (It looks like a 3 car, right?) I have a two car garage without deep sides that the Bird shares with the Vette, so space will be an issue. The hardest part about beginning this project is knowing I won't be able to drive the Bird for a long time! See you on the streets soon
#571
Car: 1986 Trans am
Engine: 5.3 LM7
And as far as starting a project like this, it is pretty hard in the beggining. When I started stripping mine, I knew there was no turning back. You get to a certain point where you even consider if it's worth it. I actually put it on hold for months toward the beggining and contemplated selling it. Then I got bored one day and slowly started working on it and changed my mind. It's at the point now where my freinds stop by on a daily basis to check out the progress and the car has become an image of me and what I would want in a car. It's stuck with me for life now!
#572
1 Post
Car: 1990 Firebird
Well, if you ever get sick of it, drop it by Florida and I'll "take it off your hands!" You can just leave it in my driveway!!!
#573
Car: 1986 Trans am
Engine: 5.3 LM7
And some good news, I just ordered the painless chassis harness and the fittings I needed to get the fuel line attached to the fuel rail. Should be a good next weekend! If I can bang out the chassis harness in a week or so, the entire interior goes back together. FINALLY!
#574
1 Post
Car: 1990 Firebird
One last question, and if this was in your string I apologize, but do you have any background in mechanics? I know you said you didn't as far as body work goes, and the work you did is amazing with no experience. You seem to know how to do a lot that is over my head in terms of mechanical work. (I don't even know how to pull my own engine out to paint the engine bay.) Just wondering if a lawyer who has no mechanical foresight at all should undertake such a project, or if it's best paying someone to do this for me. I've learned as I went for easy stuff such as replacing engine parts (alternator, starter, etc.), but just wondered how much I really need to know before tearing the car apart. Thanks.
#575
not to but in and take his weustion from him, but if your that worried about forgetting where something goes, then use a video camaro, take pictures, organize everything from bolts/nuts/wires etc, document things, and just take it slow, thats how i learned..that and model cars. always take your time and do it good, who cares if something take you a day that someone else could do in an hour. and if you forget where something goes im willing to bet someone could tell you and show you a picture. and as far as tearing it apart, do it in steps if you have too
#577
Car: 1986 Trans am
Engine: 5.3 LM7
I got it on ebay and I bought 2 bulk boxes (9 sheets in each box).
#578
any more progress??
#580
Car: 83 Pontiac Trans Am Recaro
Engine: Crossfire 350
Axle/Gears: 4.10 posi
Can't wait to see the next progress pics.... this thread is like a drug... I have to check it a couple times a day to see if I've missed anything... lol....
#581
#582
Car: 1986 Camaro Iroc Z
Engine: V8 305 TPI
not sure if it was covered here, but how much POR 15 did you use, trying to figure out how much i need for the interior, what other products did you use with the POR?
beautiful project, going to be amazing when complete!!
#583
Car: 1986 Trans am
Engine: 5.3 LM7
Got the chassis harness and my fuel fittings today. Started to play with the harness a little and it seems like it's not going to be bad at all. Hopefully it goes smooth. I Don't know of anyone that has actually documented a painless chassis harness install into a 3rd gen so I guess I'll be the guinea pig lol.
Heres where the fuel line comes up from the tank into the engine bay
And heres the routing to the fuel rails. All -8AN line.
I want this painless universal harness to be as "factory" appearing as I can get it so I modified the stock fuseblock holder to work with the painless fuse block and it came out great!
Ooooooooh, fun! LOL, not.
Also had my brother sandblast my T-top seal rails and re-painted them and installed them. Came out nice.
The paint looks so awesome at night. Almost a candy apple red. For some reason my camera brightens the image even with the flash off so it didn't come out. O well, just take my word for it!
#584
Car: 1986 Trans am
Engine: 5.3 LM7
I bought a quart of SEM chassis coat black (similiar to POR15) and still have some left and I've used it on a ton of stuff like the floorpan, front steering parts, etc. Great stuff. I would imagine you should be fin with just a quart of whatever you go with.
#585
Just out of curiosity how are you liking the nylon mesh fuel hose? I'm torn between nylon braid or SS braid for when I eventually replace my fuel lines, they both have some pros and cons. Does it seem plenty durable or noticeably lighter than ss hose if you've handled it before? (I'm a pretty avid weight **** which has me leaning toward nylon, but SS would be more durable and looks pretty slick)
Also I'm assuming nylon since its the most common non metal mesh, but I know a few other materials are also used, but still curious how you like it if its another material.
#586
Car: 1986 Trans am
Engine: 5.3 LM7
#587
I was already leaning towards nylon heavily on account of being a weight freak, but now theres no question, nylon it is!
#588
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
I hope your gonna insure the crap out of this thing. It would suck if something happened, it got totaled and the insurance company gave you only a couple g's for it.
#589
Man...Im so jealous of how meticulous you are being. I have no patience for that sort of detail anymore haha.
LOVE how things are turning out man.
Really anxious to see how the painless kit works for you. Im a minimalist when it comes to wiring. The factory has so many wires and splits and circuits piggy backed on to each other. And doing your own wiring is VERY rewarding. Not only from an accomplishment standpoint, but if something malfunctions, YOU know where the wires are and how the circuits are laid out. I dont even need a wiring diagram for my car anymore haha.
Ide love to gut mine and go with a new harness though. Ide still need all my lights, wipers, radio, etc...which Im sure isnt an issue.
Im also glad to hear you like the nylon line. I was going to upgrade to all braided stainless on my car at some point, but am now leaning towards the nylon. Can you use existing Russel fittings that are on stainless lines with the nylon line? I imagine you can...
Keep it up!!
J.
Keep it up!!
J.
#590
The fittings to the best of my knowledge work with either braided hose type, ie. if it works for one of ss or nylon, it should also work for the other.
#591
Car: 1986 Trans am
Engine: 5.3 LM7
Keep it up!!
J.
Keep it up!!
J.
And as project 3.4 said the AN fittings work with either nylon or braided line so you should be all set.
As for insuring this car....to be honest with you I am probably going to insure it as just a regular 86 TA and not have it appraised. Theres 2 reasons for that. First, insurance on an 86 TA in good condition these days is around $5-$6K dollars which is pretty good, and 2nd I don't want to pay a premium for insurance. This is my fun car that will come out on weekends and nice days and I don't want to be spending a ton of money for it to be sitting in a garage insured. In all honesty, and I'll cross my fingers it never happenes, but if the car ever was actually totalled, I could probably part it out for almost what I have into it due to all the aftermarket goodies.
#592
Car: 92 Firebird
Engine: 4.8 LR4
I would get collector car insurance if that is the case. I have Hagerty on my 73 Camaro and it is insured for $15,000 and it is under $400 for the year. The only thing you have to provide is that you have a daily driver car so they know you wont be driving that one all the time
#593
#595
I know you don't, though I am pretty sure it makes car insurance cheaper.
#596
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Well if the accident's not your fault then you can just sue the crap out of the other party lol.
#597
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
MAn yor cars coming along good! It's almost a waste to carpet your interior with how pretty it is lol. Whats the max miles per year on classic car insurance anyways?
#598
I'm wanting to say 5 or 10k, but I don't recall for sure, just remember it being pretty damned low.
#599
Car: 1986 Trans am
Engine: 5.3 LM7
Started playing with the chassis harness today and I honestly don't think it's going to be bad at all. The way painless pre-labels everything is awesome and I already basically have all the wiring run to the correct spots in the car. Heres a few in progress shots. Wiring is more complete than the pics show but I'll get farther along shots once it's pretty much completely run.
Starting to lay things out where they will end up
They include much more wire than you'd ever need lol
Dome light wiring run in the factory spot
