The Wish List,What do you guys want that you can't get
#101
Re: The Wish List,What do you guys want that you can't get
id like the ashtray lid for a 90 camaro in black. a while back the rivet that held the top of the lid to the bottom part fell off, so now when the ashtray is open the left side of the ashtray lid sags down a quarter inch into the console, and to shut it i have to make sure to pull it up so its level and then shut the ashtray (ipod wire is through the ashtray, dont worry i dont smoke)
#102
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '84 Z28
Engine: L69
L69 air cleaner ducts for Camaros.
Stripe kit for '85 Z28 code 68A Russet.
Stripe kit for '87 Z28 code 84A Red.
Stripe kit for '85 Z28 code 73A Red/Orange (found only on red cars w/black interiors)
#103
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
The plastic trim panel that goes between the headliner and the rear window. Every one you find is cracked by the screw holes.
#105
85-90 chinspoilers--no junk--de facto easily mistakable for a NOS piece perfect duplicates, with all proper mounting provisions, made to the same standards/consistencies of the urethane/whatever GM used.
Basically a show quality, restoration-grade piece that would get GMs approval as a restoration-grade piece.
#107
Car: 1989 Pontiac Firebird
Engine: 2.8L
What would be cool is a drink holder in the arm rest in the driver/passenger doors. A custom arm rest that bolts up in factory holes. That's the only thing I would want, but can't get. Or the only thing I can think of.
-Derick
-Derick
#109
Engine: 2.8L
I have no money to start trying to make something work. So don't hold your breath haha.
-Derick
-Derick
#111
#113
Car: 1986 Z28
Transmission: 700
Axle/Gears: Yes
Tony,
Why cant we order package deals? Carpet, door pnl, etc? Also, I ordered some great door panels but need the material that matches for some trim. How do I get the material?
#114
Car: 1986 Z28
Transmission: 700
Axle/Gears: Yes
The plastic trim panel that goes between the headliner and the rear window. Every one you find is cracked by the screw holes. YESSSSS
#115
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
I think searching the junk yards for good parts for these cars adds to the fun of owning one. Ive scored many a great part from otherwise trashed thirdgens. Got a nearly mint centerconsole out of a hurt 89 formula during the height of cash for clunkers. And just recently an overhead console from a stripped and rusted out 86 camaro. That console was in better shape than the one in my car, and I think mine is very nice
That being said there are some things your just cant find in the junk yards. First that comes to mind... Door latches. Theyre always warn out and the ones available though classic industries are pretty pricey.
Next, I would have to say 91/2 T/A front ground effects. I dont think Ive ever seen a good set except on a clean car.
#116
Car: Firebird Formula(1988 changed to 91
Engine: 355 TPI
Axle/Gears: 3.73(needs changed)
I agree with Frank D, the piece behind the headliner is always cracked or the openings are busted out.
All 91-92 Firebird/TA front and rear bumper and associated parts
Cup Holders, Ground effect parts, console parts
ALL years Camaro ground effects, chin spoilers, console parts
Wouldn't it be great if there was a sudden craze for 3rd Gens and a company started selling chassis's for a ground up restoration! Like they do for the older Camaros, Chevelles and Mustangs. Then the restoration companies would get on the ball and make all the parts needed to build a complete(new) car. Why should Chevelle, Mustang and Camaro owners have all the fun?
#118
Engine: 355 TPI
True, but I meant the sub frame from front to rear. Just a brand new shell with no doors, fenders, etc. Similar to the 1st gen Camaro shells that are sold. I forget the company that makes them
![doh](https://www.thirdgen.org/forums/images/smilies/doh.gif)
#120
Engine: 355 TPI
http://www.dynacornclassicbodies.com...m_models2.html
Here's the site for the new GM shells. Kinda high priced but it would be neat to build your own 3rd Gen from the ground up and use any motor/trans combo you wanted.
#122
Car: 83 firebird
Transmission: 700
I have a 78 Chevy Silverado. The aftermarket is so great that all you need is a set of frame rails, a VIN plate from the junkyard, and you could literally build a new old truck from the ground up using just reproduction parts. The details (like interior trim) won't be 100%, but it'll be close enough.
#124
Car: 83 firebird
Transmission: 700
also need front strut towers.
can't seem to find rear calipers for 82 TA
#125
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
1992 Trans Am
05-10-2023 07:19 PM
ambainb
04-25-2016 09:21 PM
Linson
08-21-2015 02:12 PM
