factory color of sway bar and brackets
Re: factory color of sway bar and brackets
The front sway bars were painted/factory powdercoated in semi-gloss black. The front sway bar brackets were just bare metal which started to rust from day one giving them a dark brown rusty color over the years.
IIRC, the rear sway bars were bare metal (not painted), but the brackets were either uncoated natural steel or semi-gloss black if it was a G92/WS6 suspension package. Most BW 9-bolt rear axle cars that I've seen had the black rear sway bar brackets.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
I believe that the original sway bar is as described, with Semi-gloss powdercoat.
I believe my rear sway bar brackets were originally gold annodized coated... I did end up powdercoating them Black tho...
I am going off of a 36K mile car...
1992rs/ss
16
01-28-2016 09:58 PM
ProtoMaster22
08-26-2015 07:50 AM
