Premium Unleaded Gas Gauge
1 Post
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
i can swear i remember seeing gas gauges that said premium unleaded only instead of unleaded fuel only
can anyone confirm this, my search on here and on yahoo turned up nothing
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: Premium Unleaded Gas Gauge
Cant recall seeing premium on the cluster. Later models, 92+ perhaps or on the inside of the filler cover with a sticker maybe?
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
The Canadian cars didn't even say "unleaded fuel only." They simply said "fuel." We got circles instead of E and F as well.
Can't help you on the premium question though.
Car: 1989 Pontiac Turbo Trans Am
Engine: Buick 3.8liter Turbo V6
Transmission: 4-speed automatic
'89 Turbo Trans Ams say "Premium Recommended" on the tach.
Chris
1989 Pontiac Turbo Trans Am #760 (1955 miles)
1988 Chevrolet Corvette 35th Anniversary #1941/2050
1986 Pontiac Fiero GT V6/5-speed
1983 Delorean DMC-12
1986 Toyota Supra MKII
1987 Toyota MR2 T-Top/5-speed
1985 Kawasaki Eliminator ZL900
Chris
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
AFAIK, The TPI cars recommended (but did not require) Pemium... Actually if you do not hammer on the car to where you get spark knock, I have found that you actually get better milage from Regular, apparently there is more energy.
John
John
The 87 L98 gauge only says Unleaded Fuel Only on it. Premium fuel requires a higher temperature to burn all the fuel. Todays Premium vs. yesterdays Premium may be different and the computer needs to be calibrated accordingly. If the fuel isn't burning the most efficient, then it becomes waste out the tail pipe. Sounds like the Regular is burning more efficiently so you are getting better mileage.
The premium in 1987 was 91 Octane, today it is very common to see 93 octane, and i@ Sunoco I have seen 94 Octane... At least here in MI...
John
John
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
well i messed up last tank and filled up with midgrade.
got a nasty reminder when i floored it to merge onto the highway
(i love flooring this car so much, i dont need to, but hey, its a camaro lol)
that was a bit of a scare, it started knocking and pinging so bad...
needless to say, i use premium.
That is just the thing, The higher the octane the slower it burns and the cooler it burns. So you can advance the timing to get better power. The down side is the fuel is not as efficient so you get worse fuel economy. In short, if you want performance, get premium, if you want economy get Regular. I would never get anything less than 87 Octane hoever I remember some gas stations had an economy 86... At the time I owned a 1977 Buick Electra LTD that with 86 Octane would spark knock at 55 Mph going up a hill on the expressway... If I traveled at 65 it would almost constantly spark knock...
John
John
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
Hotrodboba400
12-10-2019 07:07 PM
