85 iroc or not?
85 iroc or not?
I jus bout an 85 Camaro-It has the Z28 bading on the body kit and on the passenger side dash, but the guy bought it from swears its an Iroc-Z. How would i go about finding out for sure if it is an Iroc or not? what where the main differences?
Car: 88 IROC-Z
Engine: 5.7 TPI 350
Re: 85 iroc or not?
check the RPO codes their should be a code for the IROC-Z option. I forget what it is, or you could find a RPO decoder and enter all your codes into it and you will know what options the car came with.
Re: 85 iroc or not?
HotRod's right about the RPO. Check for B4Z, which is the IROC package.
JamesC
Re: 85 iroc or not?
Look in your RPO codes in the console box and see if you have the SPID sticker. It should have the RPO B4Z if its an IROC-Z28. If it also has the RPO 1C5 you have a "California IROC-Z28" which they only built 502 of in 1985 and is extremely rare since very few exit today in original condition. To be one of these it will only be in red or black paint. It won't have hood louvers, rear spoiler, no decal striping, or IROC-Z on the doors, if it is still original. It will have only 16" IROC wheels, fog lights, ground effects, LB9 engine, and automatic transmission if still original.
Re: 85 iroc or not?
thanks for the quick responses-im picking up the car tomorrow so i will check it out then-it has aftermarket rims and no fog lights (which may have been because they were making a drag car out of it, i dunno) but i was just curious for basic knowledge
Re: 85 iroc or not?
https://www.thirdgen.org/forums/memb...xer-upper.html
JamesC
Re: 85 iroc or not?
now that you mention it-the holes are there for the fogs-i didnt pay that much attention to it-i just thought it was messed up and was thinking about putting the billet aluminum in its place, but if i get some fog lights, i may not be able to.....it does have the hood louvres tho, i just needa look at the dash badge and the RPO tomorrow-i appreciate the help tho
Car: TRUE BERLINETTA
Engine: 5.0 CARB. ALL DAY
Transmission: 700 R4 TURBO
Axle/Gears: 373 BURN N DWN THE TRACK
Re: 85 iroc or not?
check the camaro web site.it will give you a certain number or letter to check on the vin number and that will tell u exactly what you have and the true engine size type and tranny
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: 85 iroc or not?
The way i usually check on the early ones is the door tag. If it calls out for 16" wheels then its an iroc. If its 15s then its just a Z. That doesnt work after 87 though. It could be either a base or an iroc with 15s after 87.
Re: 85 iroc or not?
I make many trips to salvage yards and always see the center consoles and boxes removed. The RPO sticker in your car may not be original. A VIN match will tell you exactly what you have.
1 Post
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
Re: 85 iroc or not?
[quote=JamesC;, the quarter/rear bumper badging on an 85 reads Z28 (the dash badge, however, should include IROC-Z),
JamesC[/quote]
The dash badge in my IROC reads only Z28 5.0 Liter H.O. I'm sure it is a real IROC because of the B4Z RPO and all of the other indicators. Were all of the L69 cars badged like this? Mine came out of the Van Nuys plant. I just noticed in the white book that it is stated that all Van Nuys cars had vins last six digits started with 500001. My last six start with 46.....! Is there a mistake in the white book or do I have a rare early IROC?
JamesC[/quote]
Re: 85 iroc or not?
Re: 85 iroc or not?
My car is a 1985 RPO 1C5 "California" IROC-Z28. The dash badge on mine and one other I've heard about only says Z-28/ Tuned Port Injection, under it with no IROCZ on the badge, but it does have RPO B4Z. It also doesn't have anything on the driver side rear bumper saying tuned port injected as other irocs do. Also the vin# of the 3 other 1C5 "California" IROC-Z28s I've located and mine all start the last six nimbers with 47, not 50. These were all built at the end of 1985 between May and July. My Camaro White Book,the newest edition through 2002 has the Vin# for 1985 starting at 400001.
Last edited by yo soy el warg; 04-06-2009 at 08:32 PM. Reason: Add one more fact asnd correct the badge discription
Car: 82 Z28
Transmission: BW T-10
Re: 85 iroc or not?
[quote=HankL69;4109318]The dash badge in my IROC reads only Z28 5.0 Liter H.O. I'm sure it is a real IROC because of the B4Z RPO and all of the . Were all of the L69 cars badged like this?
My 85 L69 IROC has the Z28/IROCZ badge, in fact the GM parts catalog does not list a 5.0 Liter HO badge after 84, except it does list the 84 part # for 86 L69 regular Z28s! Since they only made 74 of those, most of which were race cars, I can't imagine seeing one! I'd love to see a pic of your badge! My car is a Van Nuys car produced 12/84, the last 6 is 419XXX. Are there any other 85 L69s on TGO?
Re: 85 iroc or not?
Hank,
Check the following link, second pic all the way to the top in the first column:
https://www.thirdgen.org/forums/inte...sa-badges.html
Is that the badge you have (though difficult to see, it looks like Z28 above and 5.0 Liter HO below)?
JamesC
JamesC
1 Post
Engine: 5.0 / 350
Re: 85 iroc or not?
No, that's not it. Actually it is the third one down in the first picture. I'm trying to include a pic in this message. Lets see if I can.
mustangman65_79
08-11-2015 03:17 PM
