Firehawk and the ZF Tranny
1 Post
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
I just read a post about the ZF 6-speed tranny and it got me to think about the Firehawks. Seeing as how they were built in 1992, why did they get a ZF 6-speed manual tranny that required massive changes to the center console rather than the T56 that ended up in the 1993 F-bodies? It would still require a different tranny crossmember, but overall seems to be an easier swap. Were absolutely no T-56 units available yet, or was there another reason?
1 Post
Car: 1987 GTA
Axle/Gears: 9 bolt 3.70 posi
Re: Firehawk and the ZF Tranny
It was supposedly the same transmission they used in the ZR1's with the LT5 engines, they probably had an easy way to get them over the T56.
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
You have to remember that the first firehawks were in 91 which was 2 years before the T56 came out in the camaros and firebirds. The T56 was probably still on the drawing boards at that time leaving only the ZF tranny from the corvettes as an option to withstand the power the firehawks would be putting down. By 92 i there "could" have been t56s produced but SLP already had the tooling and the knowledge of how to put the ZF tranny into the birds. If they were to switch to the T56 they would have to fabricate an entirely new crossmember (remember this is WAY before the swap was being done and there was no knowledge of it), and learn a different way of going about putting in a stronger transmission.
Granted the above paragraph is mostly speculation but I can bet that that is the reason they firehawks got the ZF and not the T56.
1 Post
Car: 1984 Trans Am
yeah, with not additional information I would have to assume that the T-56 just simply wasn't available yet. I was just curious if anyone could confirm that or had additional information about why they selected the ZF transmission
Yes, it's sort of the same "FireAm" as from the 70's. This is actually the last FireAm built. It was built by Herb Adams and Pontiac Engineering for the 1986 one lap of America. It's the best handling third gen I've ever driven (except for the IMSA race car.)
It has a worked over TPI 350, ZF 6 Speed, fuel cell, Dana 44, Aluminum hood, brembo brakes and custom two piece wheels. It's a two seater with full custom aluminum frame seats (very kool) and a cheezy mocked up center console. It has 7k original miles.
Here are a couple pics including the experimental tag.
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
omg t_owner that is amazing I love those seats you need to do a photo shoot of all your cars you have so many amazing ones I am jealous
1 Post
Car: 1984 Trans Am
that FireAm looks so sweet! Does it have the factory option spoiler that usually came with the wheel spats? I'd love to get ahold of an aluminum bulge hood and dana 44 rear.
IIRC, the first production car to have the T56 was the 1992 Dodge Viper. I would imagine Borg-Warner was working very closely with Chrysler at that time and probably did not want any other cars to have the T56 until at least a year after the Viper debuted.
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
