Best way to restore the tranny oil pan?
Old 03-04-2009 | 02:34 AM
Mikos_89's Avatar
Car: '89 GTA, '15 Camaro LS 6sp.
Engine: L98, LFX.
Transmission: 4L60, AY6.
Axle/Gears: 3.27's.
I'm currently restoring the chassis on my GTA and would like to know the best way to restore the transmission oil pan? The oil pan has some corrosion forming on the ouside and I'd like to fix it if possible. Were the tranny oil pans painted by the factory? It kind of looks like paint or a thin powdercoat, but I can't be sure.
Old 03-05-2009 | 10:25 PM
Red90IROC's Avatar
Car: 1991 Trans Am
Engine: 5L TPI
Re: Best way to restore the tranny oil pan?
That's a good question. I don't think they were painted by the factory... just seems like a little plating or clear coat. Mine has a little edge discoloration... I'm planning to touch it up with some silver paint. If you want it to retain the original look, you can use steel wool and then paint it with clear coat.
Old 03-06-2009 | 10:20 AM
f1ls1's Avatar
Car: 1999 F-1 Camaro Conv 1990 Iroc-Z
Engine: LS1/L98
Transmission: A4/A4
Axle/Gears: 3.23/3.27
I bought a new one from the dealer it was $22.00 Out the door. They are $28 and change now.
Hotrodboba400
12-10-2019 07:07 PM
Stryker412
09-07-2015 09:11 AM
apie2546
09-05-2015 07:40 PM
IROCZ1989
09-04-2015 11:54 AM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: Best way to restore the tranny oil pan?
